Welcome to the North American Subaru Impreza Owners Club Wednesday September 26, 2018
Old 11-20-2007, 03:55 PM   #1
NothnButTheFacts
Member#: 65876
06 WRX Wagon
CGM
Default JDM STi Steering Rack on a 02 WRX?
can it be done? i have to replace my steering rack and would like to put an sti one in there because i know they are slightly more responsive, my question is this: Are there going to be any fitment issues with a JDM STi rack? I know the JDM cars are rhd but does that have any bearing on the steering rack?
NothnButTheFacts is offline   Reply With Quote
Old 11-20-2007, 04:05 PM   #2
NothnButTheFacts
Member#: 65876
06 WRX Wagon
CGM
additionally-- will the 06-07 USDM STi racks swap in?
Old 11-20-2007, 04:39 PM   #3
stoney98
Member#: 65888
2010 FXT
Um... yeah, not so much. The mounting for the steering column is on the right. The USDM should fit, others can confirm
stoney98 is offline   Reply With Quote
Old 11-20-2007, 04:47 PM   #4
Blue5spdWRXWgn
Member#: 93606
2002 WRX Wagon - WRB
2005 9-2X - SGM
The steering gear mounting system changed in '05. You can use a 2004 USDM STI rack with your current crossmember. AFAIK it should be a direct swap.
Blue5spdWRXWgn is offline   Reply With Quote
Old 11-21-2007, 01:55 AM   #5
NothnButTheFacts
Member#: 65876
06 WRX Wagon
CGM
so the 2005 and above STi's steering racks are not able to fit directly on the MY02-03 WRX... does anyone know what extra steps would need to be taken in order for it to be usable on my car? Thanks in advance for any further info...
Old 11-21-2007, 02:19 AM   #6
jamal
Member#: 71875
you'd need a new crossmember to use an 05+ rack.
jamal is offline   Reply With Quote
Old 11-21-2007, 10:58 AM   #7
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
...and there's no way to use a JDM rack of any type in your car (unless you are also going to convert to RHD that is).
CTKAG is offline   Reply With Quote
Old 11-26-2007, 07:50 PM   #8
DirtstyleWRX
Member#: 18212
I recently put in an 06 sti rack into my 02 wrx. As others have posted, all it requires is the matching crossmember. I purchased my rack already attached to the crossmember. So, all I had to do was unbolt the subframe, remove the sway bar, then drop the crossmember with the rack attached. Pop in the new crossmember with rack attached and you're good.
DirtstyleWRX is offline   Reply With Quote
06 STi steering rack into an 02 WRX? Arnie Subaru Conversions 0 12-23-2009 06:26 PM
05 sti steering rack on a 02-03? possible snwboard4life69 Brakes, Steering & Suspension 9 12-11-2008 10:53 PM
FWD impreza steering rack on an 02 WRX Skoobie Brakes, Steering & Suspension 0 02-15-2008 11:26 PM
04 Sti steering rack into an 02 WRX Don Arm Brakes, Steering & Suspension 2 01-31-2007 02:32 PM
Installing JDM STi steering wheel/airbag in 02 WRX superg Electrical & Lighting 2 02-02-2004 02:46 PM
