Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 06-29-2020, 09:28 AM   #1
OverLabyss
Member#: 516233
Default Possible causes of valve noise!!
Hi! My '05 Impreza RS (automatic transmission, 160k+ miles) has developed what I understand is valve chatter/noise/pinging/rattle, which happens when the car is being accelerated between 40-60 MPH. If I let go of the accelerator, the noise stops. I have not changed gas octane ratings (always 87), and there's no ECU light on when it happens. The car is up to date with regular maintenance. I have not taken it to a mechanic yet.
Any help or opinion on what may be the causes is appreciated!
[size=8pt]ไฮไลท์บอล[/size]
OverLabyss is offline   Reply With Quote
Old 06-29-2020, 11:11 AM   #2
Jack
Add Lightness
Member#: 13699
not my president
(From General)
The absolute easiest thing to do is run 93 for a couple tanks to see if that rids the pinging. If it does, you're getting some pre-detonation. If it does nothing, play on.
Injectors in these cars are wicked noisy, but would not tend to change from engine speed or load.
Old 07-04-2020, 11:22 PM   #3
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
The fact u have no CE lite puzzles me
Also
Drive train/valve train noises are.....for most.....are consistent
‘They don’t come and go’
The noise will be heard at startup and then get louder as the engine RPM gets higher
How did u come to understand the noise is valves?
