Welcome to the North American Subaru Impreza Owners Club Wednesday July 15, 2020
Old 06-24-2020, 09:14 AM   #1
hjhof
Member#: 514927
Default Accessport cable management?
Morning all, first post here!
Picked up an AP for for 2019 WRX a few months back, I currently have it mounted just to the left of the steering wheel on that small piece of dash before the drivers side window, I like the location and the mount I have, but I don't like the cable just laying there near the clutch anyone have their AP in a similar place and how do you keep the cable from getting in the way?
Thanks!
hjhof is online now   Reply With Quote
Old 06-24-2020, 10:15 AM   #2
SoFlaRRRex
Member#: 407565
2015 WRX
Red
I wrap mine around the steering column a few times. It tucks in there quite nicely.
SoFlaRRRex is offline   Reply With Quote
Old 06-24-2020, 10:55 AM   #3
hjhof
Member#: 514927
Thanks! is it super noticeable as it moves over to where the AP is? Not too worried about that but the more hidden the better
Old 06-24-2020, 11:46 AM   #4
rtv900
Member#: 428511
2016 STI
why don't you bundle it up down by the obdII port and zip tie the excess down there?
that's what I did for the 2 weeks I left that plugged in before I got tired of looking at the same numbers eternally
rtv900 is offline   Reply With Quote
Old 06-24-2020, 12:49 PM   #5
dannyq86
Member#: 416919
you could buy one of those dialed mount defroster vent mounts, the cable will then be routed through the dash and you wouldn't have to mess with it.
dannyq86 is offline   Reply With Quote
Old 06-24-2020, 01:18 PM   #6
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
I route it through the gap in the steering column with the excess zip-tied and tucked in there. so it does not hit my leg. Fits pretty nicely.
2018wrx_newbie is offline   Reply With Quote
Old 06-25-2020, 03:42 PM   #7
raulz888
Member#: 509899
2017 WRX
I have a window mount that i put on the little window on the driver door. I bundled the cable under where the ODB port is and then drilled a small hole in the side of the little plastic hatch down there and fed the cable through it. When I don't have my AP hooked up I push the cable back into that hole and just the connector is visible. When I need it I just pull it out again.
raulz888 is offline   Reply With Quote
Old 06-26-2020, 11:23 AM   #8
609blk15wrx
Member#: 396932
2015 WRX Premium
Crystal Black Silica
I second the Dialed Mounts vent mount. Easy install and very clean.
609blk15wrx is offline   Reply With Quote
Old 06-29-2020, 11:25 PM   #9
casey_jones
Member#: 511807
I do the same thing, if you get it wrapped around evenly then it doesn't touch anything and looks fairly clean
casey_jones is offline   Reply With Quote
