Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 06-24-2020, 07:00 PM   #1
ueavi184
Member#: 515602
Default DAM dropped but every thing else is normal
Hey guys. I just installed the Cobb Stage 1 tune on my 2019 Wrx about a week ago and this morning it showed my DAM was 0.625 When I first installed the accessport, it showed DAM was 1.00 Iím new to this and wanted to know what can cause the DAM to go down and how get it back up to 1.00 Thereís also no knocking issues 0.00 and I havenít seen anything abnormal and engine sounds good.
ueavi184 is offline   Reply With Quote
Old 06-26-2020, 11:20 AM   #2
609blk15wrx
Member#: 396932
2015 WRX Premium
Crystal Black Silica
Do you know for a fact that there have been no knock issues? Or did you flash the tune then throw the AP in your glovebox and plug it in a week later?
In terms of raising your DAM, I found that long highway runs worked for me. The ECU needs to see go through the same RPM/Load/etc in the tables to add the timing back. In my 2015 WRX I was able to literally watch the Fine Knock Learn rise until it hit 0 and then climbed to positive numbers, adding timing back. I would give it throttle in 6th gear until the FKL appeared and then hold that position and let it learn. I donít know if thereís any difference for the technique on your EJ, but ECU learning should be similar.
609blk15wrx is offline   Reply With Quote
Old 06-27-2020, 09:06 AM   #3
Sour_K
Member#: 370021
2008 WRX Hatchback
Did you reset the ECU or pull the terminals off the battery? In my 02 the DAM will drop to 12 or lower after a reset, I usually have to drive it ~10 highway miles to get it to go back up to 16. Different values but the method still applies.
Sour_K is offline   Reply With Quote
Old 06-29-2020, 09:37 PM   #4
ueavi184
Member#: 515602
No I didnít reset the ECU yet. I wanted to see if it would go back up after driving it for a few days. After driving it for a few days the dam started to rise back to normal. Itís finally back at 1.00 I think it might have been the gas from Costco. I usually put chevron but I was near Costco when I needed gas. Thanks for the reply tho!
Old 06-29-2020, 09:43 PM   #5
ueavi184
Member#: 515602
Yeah I know for a fact the car has no knock issues. After I flashed the stage 1 tune. It wasnít showing any knock and dam was normal at first. Yeah youíre right about the ecu learning the same rpm/load/etc It slowly started rising as I started driving more, usually on the highway and itís back at 1.00 now. I think it might have been the gas. I read that bad gas can sometimes cause issues with lowering the dam and causing knock. It was Costco gas I used that day lol Only gonna go with chevron and shell from now on. Thanks for the reply!
