Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 06-26-2020, 09:59 PM   #1
idos
Member#: 516166
Default un common misfire
sooo exactly as the title says i have an un common is fire
02 wrx for refrence
I recently replaced my coolant cross over pipe and it has caused a miss fire in cylinders 2 and 3.
i have since
1 replaced all the plugs
2 replace the entire intake
3 replace the intake manifold gaskets
4 cleaned maf and map sensors
5 checked for compression
6 replaced crank and cam sensors
7 put on a really good ground
8 scanned codes (that detected witch cylinders is firing.)
9 verified that it is in time
10 tried 2 different ecu's
I am really lost on this. All this because i needed to change my cross over pipe.
any thoughts as to what it could be
idos is offline   Reply With Quote
Old 06-28-2020, 11:04 PM   #2
dadubz
Member#: 510171
1997 Impreza L
black
Default coilpacks?
if it fires with coilpacks try rotating the ones from cylinders 1 and 4 to 2 and 3 and see if the codes follow
if its running wires I've had the coilpack mounted to the intake go bad and cause misfires on opposite sides of the engine before
dadubz is offline   Reply With Quote
