10-19-2010, 10:56 PM | #1 |
Member#: 248479
RMIC
Vehicle:2000 sti'ish outback and something german |
good shops for safety and emissions & how to make a ej20t run cleaner?
k so ive always had issues with safety and emissions on my cars. looking for a shop that isnt going to hassle me. i want them to do the safety and on the emissions if it passes the test (obd1 - sniffer, obd2 plug in reading) it passes. catless or not. i have a cat now but its wrapped in heat wrap and dont really want to put the stock dp on. so where do you catless guys go?
K so i have a OBD1 car and its a ej20t in it. i need it to run cleaner with out putting all the stock stuff on. it passed everything but the ideal test. it was running rich. how do i fix this? and any tuners out there that want to help me tune it so i pass then tune it back when im done? cause im clueless! and i did search, but didnt want to page through the bro hooks up. sorry i apologize for my laziness. thanks, kyle
10-19-2010, 11:08 PM | #2 |
Member#: 169211
International
Vehicle:into a gearhead." Goin' Back Old Skool |
why are you worried about stock dp if your aftermarket one has a cat regardless if it is wrapped?
Cant help you dont know of any in utah county. |
10-19-2010, 11:23 PM | #3 |
Member#: 248479
RMIC
i can get it tested in slc county cant i. and im just going to get it tested, and if it doesnt pass ill go back to stock and test it again. its a obd1 vehicle. and subr-man come to CnC this weekend i want to see the wideload!!!
10-19-2010, 11:38 PM | #4 |
Member#: 220158
RMIC
Vehicle:02 bugeye medamullet tuned |
^what did you buy??
10-19-2010, 11:45 PM | #5 |
Member#: 248479
RMIC
secret ill post some pics tomorrow.
10-20-2010, 12:53 AM | #6 |
Member#: 220158
RMIC
fine
10-20-2010, 04:00 PM | #7 |
Member#: 248479
RMIC
info added at top. i need someone to make me run clean!!!
10-20-2010, 04:10 PM | #8 |
Member#: 35276
RMIC
Turn the idle screw up to 1199 and put some evervlear in the fuel
10-20-2010, 04:31 PM | #9 |
Member#: 248479
RMIC
^ everclear as in the alcohol? whats the idle screw? ha im not smart. i can install headers and turbos and intake manifolds and do head gaskets, but i have no idea how to tune.
10-20-2010, 04:33 PM | #10 |
Member#: 256727
RMIC
Vehicle:2007 2.5I Wagon Silver |
Yes, everclear as in the booze... rubbing alcohol will also work. Basically the same thing that is in every "fuel treatment" out there.
The idle screw is the thing that sets how far your throttlebody goes closed when you let off the gas. |
10-20-2010, 04:54 PM | #11 |
Member#: 21764
RMIC
Vehicle:Some GDM V8, JDM Flat 4 X2 |
Throw in 2 gallons of e85, or use the SAFC to lean it out.
The SAFC would be the easy way to go about it. If u use e85 dont drive the car hard or it can start knocking |
10-20-2010, 07:57 PM | #12 |
Member#: 248479
RMIC
^ I'm going to hopefully figure it out tonight. Im gonna play with it a little. He also said if the car has been sitting and it has been a little so ya =/ ha I'm too lazy to return to stock, I will probably use the safc and the idle screw just to b extra safe? Or is that a bad idea?
10-20-2010, 08:14 PM | #13 |
Member#: 21764
RMIC
Idle screw...dont touch that. Thats a 1/2 *** way of addressing the issue. The SAFC should have enough adjustment in it.
10-20-2010, 09:36 PM | #14 |
Member#: 35276
RMIC
It may be half ass but it gets the job done. And you can set it back easier than fiddleing with a safc. Asuming thers a safc already in the car. If the car runs fine there's no reason to make major changes tuning just for an I'M test
10-20-2010, 09:48 PM | #15 |
Member#: 35276
RMIC
Btw the rich spots at idle that cause you to fail the idle speed test are very small. Take which ever path is easiest for you. Id you do use the idle screw method make sure to mark the position dof the screw with whiteout so you can return it to its original location
10-21-2010, 12:34 AM | #16 |
Member#: 248479
RMIC
im just going to use the safc and put it back to stock. ive already got the stock exhaust off and am working on intake.
know a safety and emissions inspection places in fair oaks? | Voltron Force | Mid Atlantic Impreza Club -- MAIC | 5 | 09-21-2010 11:05 AM |
Bellingham: Good shop for alignment and camber | Laugh Damon | North West Impreza Club Forum -- NWIC | 22 | 12-03-2009 07:15 PM |
good rim shop for repair and dismount. | ovedrivex | Texas Impreza Club Forum -- TXIC | 9 | 04-27-2007 03:28 PM |
You CAN safety shop for auto and home loans | metoo | Texas Impreza Club Forum -- TXIC | 0 | 02-15-2007 09:55 PM |
Safety and Emissions for New Cars | stimpy | General Forum Archive | 1 | 03-03-2001 11:09 PM |
