Welcome to the North American Subaru Impreza Owners Club Wednesday July 16, 2025
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 04-16-2025, 08:30 PM   #1
mattmattmatt
Member#: 494268
Default VA: 2008 Subaru WRX STI Hatchback, 136k, $10 OBO
2008 Subaru WRX STI Hatchback - Silver
NOVA - Northern Virginia
$10k OBO
136,000 miles and going up, daily driven
6 speed stock transmission
Local shop (Mach V Motorsports) checked it out recently, notes available. Passes emissions and safety. Have listed everything to the best of my knowledge, can provide additional receipts if requested.
Good:
- New coil packs and a rear wheel bearing just replaced ~FEB 2025
- Mach V - IAG stage 2 block with full rebuild, done 30k miles ago, at 106k - original spun a bearing, all parts recommended by shop were replaced + new clutch and flywheel
- Dyno tuned with cobb downpipe at 298HP wheels (sheet attached)
- Now detuned to cobb stage 1 off the shelf and stock down pipe, in order to re-pass emissions
- VA model steering rack, with faster turning ratio replaced a few years ago
- New rear subframe and all suspension components outside of struts/springs, new bushings all around - ~2021
- Front lower control arms upgraded to 2011+ style
- Gas tank replaced with a used/rust free
- Replaced alternator, power steering pump and belt within past few years
- Refurbished calipers all around + stainless steel lines + flush in 2022
- Tomei Equal length headers, SPT cat back, up pipe COBB cat less
- COBB intake and air box
- Newer tires from 11/2024 (receipt attached with model)
- I have receipts form it all, most work was done either by Mach V or Moore Auto
Bad:
- Worst part is the rust - radiator support (just the piece running under, radiator still mounted solid for now), strut mounts, spots around body and hood and bubbling on door trim, pictures of the more noticeable available
- Front bumper cracked near bottom + driver side front fender scraped, and starting to rust
- AC compressor grinds, belt removed (but all hoses and condenser recently replaced), so no AC
- Strut top hats worn, original coils and struts work but likely need replace
- Clutch pedal creak
- Ambient temp sensor and rear diff temp sensor offline, bad grounding
- Broken arm rest clip on driver side door
- Driver rear wheel seems to slow leak (even though brand new, and asked the shop to take care of it)
- TPMS not functioning
Some pics and video:
https://www.facebook.com/marketplace...22843431527871
https://m.facebook.com/marketplace/i...22843431527871
mattmattmatt is offline   Reply With Quote
Old 04-20-2025, 02:49 PM   #2
mattmattmatt
Member#: 494268
Default Price lowered - plus pics and videos
Old 04-20-2025, 02:50 PM   #3
mattmattmatt
Member#: 494268
and receipts...
Receipts
Old 04-26-2025, 10:06 AM   #4
mattmattmatt
Member#: 494268
Default Sales market seems frozen...
Bump
Old 05-05-2025, 06:25 AM   #5
mattmattmatt
Member#: 494268
Marking down to $11k
Old 05-08-2025, 04:55 PM   #6
mattmattmatt
Member#: 494268
Still available.
Old 05-11-2025, 03:39 AM   #7
Lagunagreen
Member Sales Rating: (6)
Member#: 410537
2002 Wrx Sedan
Wrb
PM me if you might have some availability in the next couple days to show the car.
Lagunagreen is offline   Reply With Quote
Old 05-11-2025, 03:27 PM   #8
mattmattmatt
Member#: 494268
Done.
Old 05-14-2025, 05:37 AM   #9
mattmattmatt
Member#: 494268
Still for sale.
Old 05-31-2025, 07:48 AM   #10
mattmattmatt
Member#: 494268
For sale still.
Old 06-10-2025, 08:31 AM   #11
mattmattmatt
Member#: 494268
Price lowered to 10k
Old 06-14-2025, 09:15 AM   #12
mattmattmatt
Member#: 494268
Weekend check-in.
Old 06-20-2025, 02:11 PM   #13
mattmattmatt
Member#: 494268
Still for sale.
Old 07-09-2025, 05:42 AM   #14
mattmattmatt
Member#: 494268
Reducing to 9k.
