#1 |
Member#: 37196
![]() I am not sure what is necessary for timing control for my application. I realize that a JS safeguard is a knock safety, and an ITC can change the timing map. However, how necessary is it? Is the factory Timing map that far off, that you HAVE to have one?
Reason i ask is this. My injectors will be here this week. I have dreams of hitting 10-14 PSI relatively soon. FOr those who dont know: ______________________________ Setup: EJ22na w/ 8:1 internals, O-Ringed. SAFC, WRX fuel pump, EJ22t injectors, rails, FPR WRX Turbo Componants. ______________________________ Main question, can i see 14 PSI w/ my setup, but w/o timing control?
#2 |
Member#: 232
Vehicle:99 RS-T RIP 02 Forster-S |
![]() Not likely. Ditch the SAFC for an E-Manage and J&S or buy a Unichip and have it custom tuned. Both will meet your needs but the E-manage is easily tuned on the street and the Unichip must be tuned on a dyno.
As for your stock timing, the 2.2 is less aggressive than the RS but not designed for positive manifold pressure. Also, the 2.2 N/A block is still open deck... stronger than the 2.5, yes, 2.0 nope. Be very careful w/ your ultimate power goals, you can make big big power but not w/ piggybacks... you're going to get into standalone territory. |
#3 |
Member#: 37196
![]() is emanage a piggy back? Also, why do i need a JS safeguard and E-Manage? Can't e-manage pull timing?
Also, for the time being, do you think i can do 10 PSI or so w/ my current setup...??? I am only running 4psi right now, but as soon as i get the ej22t injectors, i would like to bump it up a bit. -Jake |
#4 |
Member#: 232
![]() The E-Manage is a piggyback but has no knock control... hense the J&S. Its a safety thing, I'm not running a J&S and have been problem free, however I'm running a tiny turbo that doesn't flow that many cfms. The E-manage will allow you to adjust base timing based on MAF/MAP X RPM (16x16 resolution, like all the eman maps... 256 cells/map) but not pull timing in the event of knock. Although your car does have a knock sensor it isn't designed for a turbo, it can be a little overactive at times but it doesn't respond fast enough to prevent castrophe under boost. I wouldn't recomend running even 10psi on the stock timing, 8:1 c/r or not... the stock ignition system was just not designed for boost.
#5 |
Member#: 5349
![]() I run a J&S on top of a Greddy E-manage. Good safety margin even at 10psi.
UTEC Knock Control | TurboRex | UTEC | 21 | 03-03-2006 08:25 PM |
Advance Utec user Help with Timing. Knocks! Confused on Fuel/Timing Knock. | bluesube2000 | Engine Management & Tuning | 8 | 11-21-2005 02:08 AM |
Piggy Back Timing and knock control for NA | G.Subramaniam | Normally Aspirated Powertrain | 3 | 12-01-2004 03:16 PM |
J&S safeguard knock control unit | FLaBrit | Private 'For Sale' Classifieds | 1 | 03-03-2004 09:27 PM |
Haltech E6X w Knock Control | Imprezd | Engine Management & Tuning | 5 | 01-17-2004 03:40 PM |
