Welcome to the North American Subaru Impreza Owners Club Wednesday July 9, 2025
Old 08-02-2005, 03:32 PM   #1
hooptywrx
Member#: 92673
Default no boost only 5psi
I can only get 5 psi from my turbo. All of the vac lines look fine. No leaks found. The wastegate actuator can be physically moved. The car has aftermarket exhaust,bov, intake. Any ideas??
hooptywrx is offline   Reply With Quote
Old 08-02-2005, 05:19 PM   #2
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Boost solenoid is probably fried. Try that as a source. Get (or borrow) a cheap MBC and if it works, that's yo problem
Kreeger is offline   Reply With Quote
Old 08-02-2005, 05:58 PM   #3
WRX-CBR
Member#: 82197
03 WRX
Have you tampered with the vacuum lines lately?
WRX-CBR is offline   Reply With Quote
Old 08-02-2005, 08:46 PM   #4
23b_Rex
Member#: 79394
02 gda
wrb
^ same question
if not, yep your bcs is gone.... you sure there's no mbc on there????
23b_Rex is offline   Reply With Quote
Old 08-02-2005, 09:03 PM   #5
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
How long has it been doing this for?
Do you have any CEL's? If so what are they?
Does the car drive fine besides having no boost?
If not what other problems are there?
Let us know,
William T. Knose Jr.
Lead Programmer
I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 08-03-2005, 10:29 PM   #6
hooptywrx
Member#: 92673
Have not messed with any of the vac lines this year. Only have tapped in for a boost guage. Since the problem I disconnected it. Tried putting on a mbc. No difference. I am stumped. Any ideas?
Old 08-03-2005, 10:45 PM   #7
b0dh1
Member#: 35269
2011 WRX
Might sound dumb but just to cover everything here.....you said you disconnected the boost gauge. Did you plug the vacuum line it was tapped into?
b0dh1 is offline   Reply With Quote
Old 08-03-2005, 10:58 PM   #8
hooptywrx
Member#: 92673
Yes it was a t fitting. It is eliminated.
Old 08-03-2005, 11:06 PM   #9
b0dh1
Member#: 35269
2011 WRX
OK just checking. I had this same problem before. Problem turned out to be my TXS RBV was stuck open. Check your valve since it's one of the easier things to check.
Old 08-03-2005, 11:08 PM   #10
BilW
Member#: 62003
02 WRX
No EM? Did you check the boost guage?
BilW is offline   Reply With Quote
Old 08-04-2005, 11:06 AM   #11
hooptywrx
Member#: 92673
Not sure what an em is. Guage is fine.
Old 08-04-2005, 12:29 PM   #12
subaru mike
Member#: 30749
2002 wrx
em = Engine management
subaru mike is offline   Reply With Quote
Old 08-04-2005, 01:33 PM   #13
Randoramma
Member#: 60649
00RS EJ205 swap
You'd think there would be a code if the wastegate solenoid was toast?
Randy
Randoramma is offline   Reply With Quote
Old 08-04-2005, 01:57 PM   #14
jmc9809
Member#: 33344
2015 WRX
stock UP? Maybe the cat got sucked into the turbo from the UP. Turbo making any noise?
jmc9809 is offline   Reply With Quote
Old 08-04-2005, 02:11 PM   #15
hooptywrx
Member#: 92673
Catless up pipe. Turbo sound fine.
Old 08-04-2005, 02:54 PM   #16
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if it was ELECTRICALLY toasted, yes.
it could also be mechanically fubar, or pneumatically dead.
three failure modes, really.
Old 08-05-2005, 08:10 AM   #17
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
I am willing to bet you have a BIG boost leak somewhere
Old 08-05-2005, 08:01 PM   #18
hooptywrx
Member#: 92673
I had installed some test piece that I hooked up to the air inlet tube going into the intercooler to pressure test the system. I could not hear any leaks. The pressure did drop slowly which may have been the fitting. I did get a cel with the car running when I was pissing around with the vac lines. I did have a problem back with the egt sensor setting a cel, but no egt code. I used one of the scanners from work and pulled a code p1091 bank 2 sensor mix rich limit exceeded. I do have a catless exhaust system with some things wired in to take care of the cel. If you clear the code the light will stay off for about 10 seconds which in that time I can rev the car and get about 10 psi boost. Better but not like it was. This car is pissing me off!!! O ya I work at a chevy, caddy, vw dealership and nobody has a damn clue. Help me
Old 08-05-2005, 09:17 PM   #19
skivdz
Member#: 82181
02 WRX
silver & black
Default problem
Burnt Valve perhaps?
skivdz is offline   Reply With Quote
Old 08-05-2005, 10:08 PM   #20
Greek_Pulan
Member#: 92183
2017 WRX
Sounds like the same problem i'm having now, and i can;t solve it either. The only difference is that I get 8 psi instead of 5. Will check the solenoid thing and post back if i find anything.
Greek_Pulan is offline   Reply With Quote
Old 08-05-2005, 10:14 PM   #21
WRX-CBR
Member#: 82197
03 WRX
If its 8psi your probably missing the brass restrictor.
Old 08-07-2005, 09:40 PM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
put an mbc on it for testing purposes.
Old 08-07-2005, 10:15 PM   #23
reconracer
Member#: 86279
04 WRX
wrb
has the wastegate actuator arm come disconnected
reconracer is offline   Reply With Quote
Old 08-07-2005, 11:21 PM   #24
Jon [in CT]
Member#: 2992
02 WRX Sedan
Exactly. The little hose that attaches to the turbo's compressor outlet nipple is missing the restrictor.
Jon [in CT] is offline   Reply With Quote
Old 08-08-2005, 03:10 AM   #25
Greek_Pulan
Member#: 92183
2017 WRX
When I ordered the new t-hose, the guy at the dealer took the liberty to put it together before giving it to me. The problem is that he forgot the restrictor. Problem solved.
max boost only 15.5psi? vnmvx-0 AccessPort 12 10-21-2007 03:24 AM
wont boost over 5psi v8eaterWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-25-2006 06:06 PM
No boost creep, but only 13.8PSI in 5th Gear. Jard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 08-23-2005 12:33 AM
Stock 04 WRX max boost 13.5psi, but..... AWDrifter21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-20-2005 01:53 PM
No boost controller, and I am seeing 16.5psi Mitsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-30-2003 01:55 PM
