Welcome to the North American Subaru Impreza Owners Club Wednesday July 9, 2025
Old 03-31-2006, 12:24 AM   #1
mtxfrk2k1
Member#: 103401
2015 STI
Default wont boost past 10psi
i have:
vf22
asp front mount
stock modded injectors to 740cc
walbro 255
erz turbo back
erz up pipe
tuned with enginuity.
i try to set boost map up to 20psi but it still only goes to 10psi.
i switched guages from the stock boost guage to an autometer CF
the old one with my old map showed .12 bar
this guage only shows 10 psi.
what all can it be?
it doesnt feel like its completely boosting.
mtxfrk2k1 is offline   Reply With Quote
Old 03-31-2006, 01:20 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
wrong forum
Old 03-31-2006, 08:02 AM   #3
Aphex28
Member#: 11506
2010 Legacy GT
1999 10AE Miata
Try the Factory 2.0L Turbo Powertrain subforum...
Aftermarket Forced Induction Powertrain (3 Viewing)
Tech. discussion of powertrain parts & problems for any NON-FACTORY TURBO Subaru that is turbo/supercharged.
(Any turbo/supercharged US Subaru that was naturally aspirated from the facto
Aphex28 is offline   Reply With Quote
Old 03-31-2006, 09:57 AM   #4
qoncept
Member#: 44762
2013 BRZ
Sounds like your boost solenoid is hooked up backwards. 10psi is probably wastegate pressure. It might also be your IAM, have you logged that? If its <= 4, the ECU won't control boost at all.
qoncept is offline   Reply With Quote
Old 03-31-2006, 11:12 AM   #5
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Originally Posted by mtxfrk2k1
i have:
vf22
asp front mount
walbro 255
erz turbo back
erz up pipe
what all can it be?
I hope it wasn't .12 bar, thats 1.7 psi of boost. Even if it was a mistake and you meant 1.2 bar, thats 17.4 psi of boost. Alittle closer to your boost target.
Old 03-31-2006, 11:49 AM   #6
mtxfrk2k1
Member#: 103401
2015 STI
i meant 1.2 bar.
i havent touched the soleniod ever so i dont see how its backwards.
how do i log the IAM?
where do i do that at?
Old 03-31-2006, 01:24 PM   #7
qoncept
Member#: 44762
2013 BRZ
What are you logging with? Tari has a parameter called advance multiplier. If you can't find that, look at knock correction. If you're seeing a lot of negative values, there's something wrong with your tune.
There is a T in the vacuum line that goes from the wastegate to the boost solenoid. If that's backwards you'll only see wastegate pressure. You definately would have messed with it during the turbo install.
Old 03-31-2006, 02:50 PM   #8
johnnyb
Member#: 57593
2015 Crosstrek XV
Exhaust leak?
Check all the little hoses around the turbo, when I had a TMIC installed, one had a small crack and had to be replaced. Easy fix with some vacuum hose. They dry up from all the heat and become brittle.
johnnyb is offline   Reply With Quote
Old 03-31-2006, 03:11 PM   #9
Aphex28
Member#: 11506
2010 Legacy GT
1999 10AE Miata
can a mod please move this thread to the correct forum...
Aftermarket Forced Induction Powertrain (13 Viewing)
Old 03-31-2006, 05:50 PM   #10
qoncept
Member#: 44762
2013 BRZ
Originally Posted by johnnyb
Exhaust leak?
You'd have to have a huge leak to be losing 8psi.. That would probably be pretty apparant.
Old 04-02-2006, 04:01 AM   #11
johnnyb
Member#: 57593
2015 Crosstrek XV
Defintely a good point qoncept, but still the hoses are worth a look. If the wastegate manifold hose is cracked, your turbo will not operate properly.
wont boost or rev past 4k Rainy Day WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-09-2014 12:48 PM
02 wont boost past .5 bar?!? stock map F ur PONY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-31-2010 06:23 PM
Wont boost past WG pressure MS WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-15-2008 01:32 PM
18g wont go past 14.7 psi moorebl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-24-2005 01:01 PM
cant get past 10psi cml899 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-17-2003 05:53 PM
