Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2025
Old 04-07-2006, 10:29 PM   #26
XyKo
Member#: 23560
The best bet for you is:
Go sell that WRX, buy a used 99-01 2.5RS and swap the whole drivetrain. You'll get the whole STI package, with transmission, engine, etc... And this might just be the whole price of your WRX, and you don't have to shell out anymore dough.
XyKo is offline   Reply With Quote
Old 04-07-2006, 10:33 PM   #27
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
^^^^ pure sex.
-Kevlar- is offline   Reply With Quote
Old 04-08-2006, 12:34 AM   #28
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
I was just gonna recommend this. I know a guy who did this and you really can't tell outside the loud exhuast that he's got anything powerfull running under there. It truely is pure sex to have a GC8 body and an STi engine/trans. It's like a US B22 basicly.
EtoS is offline   Reply With Quote
Old 04-08-2006, 12:42 AM   #29
prometheum
Member#: 92003
04 bicycle!
yes you should definately swap the 2jz-gte motor into your car
prometheum is offline   Reply With Quote
Old 04-08-2006, 01:39 AM   #30
2ndGearFling
Member#: 64466
05, STI on green
There is no point to swap the sti engine or block into your car. That would be like swapping an L67 into an SE. The trans support isnt there, along with all of the other factors. Your best bet, dollar for dollar would be to get a 16g turbo, modified stock fuel injectors, a cobb accessport (like your DHP), and a walbro fuel pump. Once you get tuned you'll be about at the max safest power for the tranny.
-Evan
2ndGearFling is offline   Reply With Quote
Old 04-08-2006, 02:46 AM   #31
veightkiller
Member#: 78967
2011 335i
Originally Posted by affinity1
yeah, i came from a grand prix gtp (L67). when i came into that community (www.clubgp.com) it was fairly small and only a few key people were starting to make go fast mods for the L67. i spent 3 years learning about the GTP and basically following the come up of the L67 aftermarket. im having a really tough time learning about the wrx because the community has soooo many members and there seems to be sooooo much to learn about the impreza. searching has its limits because there are sooooo many topics and its hard to find exactly what i need but im trying
start with the basic's before going to the next level.it will be more easier that way and so you wont get confuse on which one you need and you dont need.
veightkiller is offline   Reply With Quote
Old 04-08-2006, 03:22 AM   #32
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
You seem to have very little knowledge, and normally I wouldn't spell out everything I would do if I had a good amount of money, but I'm bored, so here you go:
With an '03 WRX you have a few options:
Option #1 Typical Stage 4 Setup
Catless uppipe and downpipe (can leave or replace third catalytic converter depending on your preference and your state's emissions laws)
Intercooler hoses (Samco's or Perrin)
Cobb Accessport or Turbo XS Utec (Engine Management is a must)
VF series, 16G, 18G (VF30, VF34 for AP, any for Utec, have it ported and coated by Deadbolt, will help your spool and top end)
Walbro fuel pump (255lph size)
Upgraded fuel injectors (Most likely STi Pinks, but >650cc if you're going with large 16G or bigger)
Quality custom tune (Helps you to much smoother and safer, better gas mileage with it than without)
Bigger Intercooler (Not a neccessity, but stocker is only good for about 300whp, but it would be beneficial to swap it out if you're looking to make about that much power)
Option #2 JDM Motor Swap
JDM V7 STi motor (2.0L with 8K redline, AVCS[helps spool], semi-closed deck compared to open deck of USDM motors)
RA, Kaaz, or PPG gearset (Wise move, or you're going to grenade your tranny)
Standalone engine management (Hydra, or AEM, although I don't know too much about either)
Quality tune (always neccessary when you're modding to this extent)
Option #3 JDM Motor + Tranny Swap
JDM V7 STi Motor + Tranny (will cost you a lot of $$)
JDM ECU or Standalone EM (you won't go anywhere without it)
Of course, you still have a WRX, which presents a few problems. You need to control that power, both in turning and in stopping. You'll probably want to bump up to 17" rims and some Subaru 4pots, or maybe some Wilwood 6pots or Brembo take-offs from an STi.
You're going to need basic suspension mods, such as swaybars and bushings, and some springs and struts(KYB AGX's seem to be very popular, springs are your call depending on drop, just stay away from Tein S-Techs)
A short shifter from Kartboy is never a bad thing to have(mine is like sex) and a nice shift knob might make driving a tad more enjoyable.
So, there's a ton you can do to the car. I suggest going into the vendor section with an idea of how much power you want to make, how much you want to spend, and what areas you'd like to improve upon, and go from there. You might even find that you're better off just selling your '03 WRX and getting an STi, and that's fine if that's what suits you.
Good luck in your quest for whatever it is.
wrxfactor is offline   Reply With Quote
Old 04-08-2006, 03:24 AM   #33
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Originally Posted by speedDman1
do a built internals on the 2.0...upgrade the gears, then put a ball-bearing turbo on it, and get a good dyno tune. Money well spent...
Swap > Build, thanks for playing.
Can I put a sti turbo on my 04 wrx? obxtoy Subaru Conversions 8 03-09-2025 11:31 PM
Can UTEC run an 06 sti engine in my 02 wrx w/ AVCS? breathinez UTEC 2 02-13-2010 10:15 AM
trying to swap an 05 sti engine into my 02 wrx chinpocoman Subaru Conversions 8 02-11-2009 09:25 AM
Can I put an STi cat-back on my 06 WRX? LXguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-27-2007 05:20 PM
Swapped a Complete 06 STi Drivetrain into my 03 WRX this weekend TROLL Subaru Conversions 20 04-26-2007 10:04 AM
