Welcome to the North American Subaru Impreza Owners Club Friday April 23, 2021
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Wheels/Tires
Old 04-14-2020, 06:57 PM   #1
APEXRaceParts
Vendor Sales Rating: (0)
Member#: 510521
Default APEX | Flow Formed Lightweight 5x114.3 WRX/STI Wheels - Built to Perform
APEX Flow Formed 5x114.3 WRX/STI Wheels
For over 12 years, APEX has been the go-to wheel for track enthusiasts and club racers looking for the perfect balance between strength, weight, and cost. APEX wheels address the concerns of more and more car enthusiasts: long term durability, optimized chassis-specific fitments, and enhancing performance. Whether you are are a street customer looking to upgrade your stock wheels, or a hardcore track enthusiast/racer who needs wheels that can withstand track abuse, we have you covered.
Perfect fit without spacers
Designed to clear all factory STI Brembo brakes & a variety of aftermarket BBKs
100% OEM compatibility, no extra hardware required
Unbeatable warranty & 50% replacement program
Designs, Finishes, & Specifications
Bolt Pattern: 5x114.3mm
Center Bore: 56.1mm
Weight: 21.7 lbs
VIA Registration: VIA-22-1495
MSRP: $339.00 ea.
+ Order Your Wheels by Clicking the Link +
Fit Matters
The right solution for every application.
The EC-7 wheel includes details specifically implemented to enhance the WRX/STI owners' track day and street performance experience. An optimized car setup begins with the right wheel and tire fitment, and without model-specific attention, maximum performance is compromised. These wheels were developed exclusively for the WRX/STI chassis in a square configuration which promotes a neutral handling experience while allowing drivers to efficiently rotate wheels and tires on all four corners of the car. This dramatically reduces the cost of tires over time. Simply put, our wheel was designed for long-term durability without sacrificing performance and fit, while also adhering to APEX mission of maximizing value. Corner carving & track enthusiasts: this is your wheel.
Massive Brake Clearance
Engineered to clear factory Brembo brake options, as well as a variety of aftermarket BBKs.
The curved spokes of the EC-7 serve many purposes, both in terms of form and function. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Their curved design increases brake calipers in almost every application, allowing the EC-7 to fit where many competitors cannot.
Designing a wheel with spokes that clear a Big Brake Kit, is only half of the battle. The inside of the barrel needs to be large enough to physically fit large calipers and rotors. Be warned; not all wheels are made equal. The barrel of the EC-7 wheel offers unmatched caliper clearance because wheels shouldn't limit your choice of factory or aftermarket big brake kits, and big brake kits shouldn't force you to run heavier, oversized wheels. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn't improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren't. That's like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan's JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below; yet they still claim to be JWL. Always verify load ratings before you buy. Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX WRX/STI wheels with a 5x114.3mm bolt pattern are purpose built featuring a 56.1mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps. All wheels come with our gloss Black APEX caps included.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn't equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Unbeatable Support
Warranty: All APEX wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Learn more
Replacement program: Let's face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX360° Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error.
View our fitment guides.
APEX Flow Formed Wheel Gallery
Wheel & Tire Packages
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we've priced them competitively.
All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touch-less equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
Questions?
Call: 925-245-0773
Email: [email protected]
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
__________________
Product Specialist | Phone: 925.245.0773 |
APEXRaceParts is offline   Reply With Quote
Old 04-14-2020, 07:12 PM   #2
APEXRaceParts
Member#: 510521
LEARN MORE ABOUT APEX
For those whom we have not yet had the pleasure of working with, since 2007, our focus at APEX has been to produce high-performance wheels with extreme durability and unprecedented value for the performance driving community. Combining proven Motorsport design features, vehicle specific optimizations, and advanced flow forming and forging technology, we've created wheels that have taken BMW performance driving enthusiasts by storm. As a grassroots Motorsport oriented company, comprised of a diverse group of auto enthusiasts, we understand that enthusiasts from all corners of the car community seek quality products at an affordable price point, and that these should not be mutually exclusive.
YOU ARE IN THE DRIVERS SEAT
APEX does not view the car community through a traditional lens. Since inception, this company has worked hand in hand with enthusiasts through many channels, but much of what we have accomplished stems from our unique ability to incorporate forum members into product development. Rather than sitting around a conference table internally brainstorming a list of products that we feel are relevant to a specific community, we have made it our mission to enlist enthusiasts in the decision making process. Tell us where the market is currently missing the mark for you, and how we can employ our core competencies to fill the current pitfalls. The action of putting enthusiasts at the forefront of product development ensures that APEX delivers satisfactory products.
THE BIGGER PICTURE
We guarantee a different customer experience. Car nuts come in all shapes and sizes, and it is imperative to recognize that enthusiasts have different priorities, as well as short and long term goals for their machines. It is not until our product specialists have completed a needs assessment, that we can suggest a valuable and meaningful solution to our customers. Anything less would be a disservice. Manufacturing wheels that complement the multitude of suspension, brakes, alignment settings and tires specifications instills confidence in our customer interactions.
SHOW US WHAT YOU CAN DO!
“All of this sounds great, but show me what you can do.” When track enthusiasts took delivery of their new BMW F8X M3/M4, they quickly realized that the standard 10” rear wheels were not cutting it, regardless of how sticky their 275mm wide tires were. Drivers had to cautiously modulate the throttle out of mid-corner with the threat of upsetting the car, and therefore lap times were not an accurate depiction of what this new powerful platform was capable of. Correspondence poured in from the community, and after some validation from the community, a lightweight EC-7 18x11” ET44 was born. A strong 18" wheel that offered enough brake clearance for the massive OEM BBK, check. Precise and proven width and offset to support a 305 or 315 r-compound or slick without extensive modifications, check!
The following article should give you an insight into our process, and our devotion to the details: APEX Test Fitment - Squeezing a 315 R-Compound onto a stock F8X
In that spirit, we'd love to hear from you - the Subaru community. Start by having a one-on-one fitment consultation with an APEX specialist, or simply provide us with feedback in regards to new fitments, designs, or finishes that you would like to see from us.
APEX One-on-One
__________________
Old 04-15-2020, 05:22 PM   #3
akahenry
Member#: 401922
2018 STi
Any plans for the ARC-8's (forged or flow formed) to be introduced into the WRX/STi platform?
akahenry is offline   Reply With Quote
Old 04-15-2020, 06:49 PM   #4
APEXRaceParts
Member#: 510521
Thank you for your interest. ARC-8 (flow formed) or ARC-8R (forged) wheels made specifically for the WRX/STI chassis are certainly a possibility. Putting something like that in motion would be based on demand from the community.
Right now I'm asking our engineers to broaden our WRX/STI EC-7 line by working up a 19x9" and/or 19x9.5" fitment. This would be for enthusiasts predominantly enjoying their car on the street that prefer the aesthetics of a larger diameter wheel.
- Ryan
__________________
Old 04-21-2020, 12:37 PM   #5
APEXRaceParts
Member#: 510521
__________________
Old 04-21-2020, 12:59 PM   #6
Chief_WRX
Member#: 369934
2018 STI Limited
Heritage Blue
Apex, couple of questions, these do clear the 18+ Brembo brakes? Second, on your website and the "Showroom Gallery Thread" you have posted a white STI with a silver colored EC-7 wheel. Is there any chance that color will come back out in addition to the anthracite, black or bronze wheels?
Chief_WRX is offline   Reply With Quote
Old 04-22-2020, 07:52 PM   #7
APEXRaceParts
Member#: 510521
Appreciate your interest. Yes, our 18" EC-7 WRX/STI wheels clear all of the factory Brembo brakes, including the 2018+ fluorescent yellow brakes (see photo in post 2 above )
The white STI (see images below) has our Hyper Black finish mounted, which is a very cool multi-stage paint process that looks different depending on the lighting. It was a limited run for our dealers SubieSpeed and Rallysport Direct, and they may still have some units available.
We currently do not produce that finish or our standard Race Silver finish for this line, but we can certainly bring either of those to fruition if demand is there from the community. On that note, the next production run of these wheels will also introduce a new gold finish, as you can't have a Subie focused line of wheels without gold.
- Ryan
__________________
Old 05-05-2020, 04:31 PM   #8
APEXRaceParts
Member#: 510521
Grab a set of our lightweight EC-7 wheels engineered specifically for your WRX/STI.
__________________
Old 06-15-2020, 06:20 PM   #9
APEXRaceParts
Member#: 510521
Here is a closer look at our EC-7 wheels on the Subiespeed shop cars.
__________________
Old 06-17-2020, 06:17 PM   #10
APEXRaceParts
Member#: 510521
New finish alert!!
Satin Gold has officially been addd to our list of finish options for the EC-7 wheel design. This is a must-have finish option for the Suby community and the first production batch is limited in quantity, so be sure to place a pre-order before they sell out.
__________________
Old 07-10-2020, 04:01 PM   #11
APEXRaceParts
Member#: 510521
To make things as convenient as possible, we're broadening our tire offering and we include free mounting and road force balancing with all wheel & tire packages.
__________________
Old 07-30-2020, 07:12 PM   #12
APEXRaceParts
Member#: 510521
Satin Black EC-7's are in stock and ready to roll!
__________________
Old 09-25-2020, 09:22 PM   #13
APEXRaceParts
Member#: 510521
Nice to see our new Satin Bronze finish out in the wild.
EC-7 18x9.5" ET38 in Satin Bronze
265/35-18 Michelin Pilot Sport A/S 3+
__________________
Old 01-06-2021, 06:37 PM   #14
APEXRaceParts
Member#: 510521
18x9.5" ET38 APEX EC-7s in Satin Gold finish are in stock and ready to ship!
__________________
Old 01-06-2021, 06:48 PM   #15
murrdogg24
Member Sales Rating: (48)
Member#: 50586
2020 STI
Crystal White Pearl
you don't' even have an STI fitment guide on your website...booooo
murrdogg24 is offline   Reply With Quote
Old 01-11-2021, 11:57 AM   #16
ntg44
Member#: 510765
2020 WRX STI
Would have loved SM-10 in STI fitment, but for the price, really hard to beat what you have offered. May pick up a set of these instead of ponying up for Volk ZE40s. Really good bang for the buck wheel that can actually be used on the track.
ntg44 is offline   Reply With Quote
Old 01-19-2021, 05:27 PM   #17
APEXRaceParts
Member#: 510521
If you ever have questions about fitment, we are always here to help! Feel free to give us a call, email us at [email protected], or fill out a fitment recommendation form.
We do hope to eventually offer the SM-10 in 5x114.3 WRX/STI fitment, but it will not be available anytime soon. Thank you for the kind words however, you certainly won't be disappointed if you decide to go with a set of EC-7s!
__________________
Old 01-28-2021, 01:43 PM   #18
APEXRaceParts
Member#: 510521
We do now!! Checkout our GR WRX STI Fitment Guide as well as our VA WRX and WRX STI Wheel and Tire Fitment Guide.
We've taken the time to figure out what fits and what doesn't so you don't have to. We have nearly every available tire listed as well as fitment information for a variety of aftermarket BBKs.
__________________
Old 02-10-2021, 06:14 PM   #19
APEXRaceParts
Member#: 510521
Our 18x9.5" ET38 5x114.3mm EC-7 fitment is perfect for track and street use. Depending on your chosen tire size, it can be a direct fit upgrade or you can slap on a 275/35 and kill it at the track!
__________________
Old 04-06-2021, 07:11 PM   #20
APEXRaceParts
Member#: 510521
Satin Gold 5x114.3mm EC-7s are in stock and ready to ship!
__________________
