Old 06-02-2010, 05:56 PM   #1
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
Default Catch can maybe reduce oil use?
I burn or use about 1/2 to 1/4 qt. Of oil about every 800 or so miles and I know this has been asked 1berrrzillion times before, but has anyone noticed they use less oil with a catch can on there setup? If so which can are you using? Thanks
leighton1245 is offline   Reply With Quote
Old 06-02-2010, 06:29 PM   #2
GrimmSpeed
Member#: 136396
2020 STI, 2022 WRX
Both catch cans and air oil separators have been proven to dramatically reduce the amount of oil consumption on subarus. I'd call around to a few vendors on here and see what they recommend for your situation and budget!
Mike
GrimmSpeed is offline   Reply With Quote
Old 06-02-2010, 07:21 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
using the right oil reduces usage
if yoar using oyl you are likely using the wrong oyl
Old 06-03-2010, 12:59 AM   #4
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
thank you for that but not likely I have went through almost every brand out there synthetic, non-syn, syn-blend almost all the same. My leak down test showed less then 6% loss on 2 cyl. And less then 10% on the other 2 so I know no issue there. Thus the reason asking about a catch can in hopes of stopping most of the oil usage.
Old 06-03-2010, 06:47 AM   #5
Uncle Scotty
OK buy Nates beans
then you are doing something else wrong
how about changing the pcv valve
and 5w30 is NOT 'required' either
Old 06-03-2010, 07:21 AM   #6
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
I changed the PVC valve about 300 miles ago is there any other componets that might effect oil use? I have also tried 5w30,5w-40, 0w-30 didn't know about 0w-40 or going 10w-30 since it is like 90 degrees here? Thanks for all the help
Old 06-03-2010, 01:54 PM   #7
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
A quarter quart of oil every 800 miles? How do you recognize cup (8 oz) being lost??? That represents a significant amount but strange how you can tell.
Anyway you need a compression test also. If the oil is not leaking away it's burning/blowing away. There could be a number of issues from rings to headgaskets to turbo seals to valve lash. If the oil is blowing out the crankcase a catch can won't stop the consumption it will just catch it. And if you change your oil on intervals longer than 200 miles you don't want what ends up in the catch can back in your crankcase.
Before adding an apparatus to the car to catch oil you should eliminate the possible sources of the problem you are having.
Oil is not your issue unless you are using the wrong oil; one which is too thin or not strong enough to protect and properly cool a tuned Subaru motor.
How many miles on this car?
-soobaviator
soobaviator is offline   Reply With Quote
Old 06-03-2010, 02:37 PM   #8
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
-soobaviator
The only way i can measure 1/4 to 1/2qt. of oil is I check it everytime I fill up and sometimes its just a little ways down the dipstick and other times its to the hole in the bottom of the stick, So really its just a estimate. I will recheck the IC pipeing tonight and just recently had my DP off the exhaust side looked fairly clean. Also there is about 80k miles on my car. I recently had a leakdown test done at subie had a max of 10% loss but if I need to do a compression test also I can do that myself, arent they almost the same thing but a leakdown test gives more info? Could be wrong on that but idk. Thank you for the info on checking stuff out.
Old 06-03-2010, 02:41 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Try an aos. It worked for me.
hybrid gti 2 is offline   Reply With Quote
Old 06-03-2010, 07:31 PM   #10
GrimmSpeed
Member#: 136396
2020 STI, 2022 WRX
An aos is an extremely effective unit at preventing oil consumption, while a catch can works its still taking oil out of the engine and essentially throwing it away.
Will
Old 06-03-2010, 07:39 PM   #11
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
Will
thanks Will the grimmspeed one is 299 right? Easy install?
Old 06-03-2010, 08:27 PM   #12
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Easy install
Old 06-04-2010, 01:05 PM   #13
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Oil consumption on a subaru, you got to be joking
I burn a qrt every 700mi but I do know where mine is leaking
I can see it in my rearview
Turbo seal has been leaking for a while now started at 97k now at 124k
The freaking turbo will not die.
kevin2.5rs is offline   Reply With Quote
Old 06-04-2010, 01:12 PM   #14
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
^The turbo is dead, it just has not stopped working... Why don't you get it fixed? New seals on a TD04 is not an expensive deal, better yet at current prices you could get a used one in decent working order for about the price of a years worth of the extra oil you are shooting out the exhaust... Assuming you are running a TD04
Old 06-04-2010, 08:37 PM   #15
Uncle Scotty
OK buy Nates beans
neither one of my wrx's has burned any oil
wonder why
Old 06-04-2010, 08:38 PM   #16
Uncle Scotty
OK buy Nates beans
and as asked above......how can you be so sure that you are using 8oz of oil with such precision???
Old 06-05-2010, 03:24 PM   #17
rexblake
Member#: 178426
2010 S4
Gray
It's a guess, as he mentioned. Technically, it would be extremely easy to measure if 8oz are being blown out the engine. Check you oil every time you run it and simply measure the oz off the quart bottle you use to fill it up. Simple.
Old 06-05-2010, 03:33 PM   #18
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
Lol excatly! For some I guess this concept or method wouldn't be accuarte enough for some, but as long as I don't run low on oil I'm happy. I will be getting a AOS to help fix the issue thank you Grimmspeed always very very helpful. As for Uncle Scotty thanks for trying to help on checking the compontes.
Old 06-05-2010, 06:38 PM   #19
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Buying an AOS to solve an oil loss issue is like taking a Tylenol for a backache. It may help the symptoms, pain, but it won't heal the muscle or bone that is causing the pain. In the same sense the AOS will only take the oil (also the fuel and whatever heavy crap that's in it) out of the blow by gas and put it back in the pan. It does nor fix the reason the oil is escaping. And it will only capture stuff that comes out of the crankcase. If your oil is burning in the combustion chamber an AOS will do absolutely nothing.
The first thing to do is source where the oil is getting out and why. Then you buy parts to fix the actual problem, not put a band-aid on it and kick the can down the road on solving the issue.
I've owned four Turbo Subarus and one N/A Subaru. None of them used oil to any significant degree. If an engine is using oil there is an issue with the engine or component on the engine. The problem is not that your engine does not have a cleverly designed aftermarket piece of kit.
oil catch can or air oil seperator??? jaytech Newbies & FAQs 11 09-21-2009 12:03 AM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 09:01 PM
FS:OH: 3" flat flange, perrin catch can cover, fp oil outlet flange mikkellucci Engine/Power/Exhaust 3 08-16-2006 08:50 PM
have oil catch can, but still oil in IC TyranosaurusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-05-2005 11:46 PM
DO oil catch cans help with oil consumption? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-10-2005 02:57 AM
