10-26-2006, 02:32 PM | #1 |
Member#: 50404
Is the td04 on the 06WRX the exact same as the td04 on the 05WRX?
Could a take-off 06 td04 WRX turbo work as a direct swap to an 05 WRX?
Thanks.
10-26-2006, 02:38 PM | #2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
Yes45
10-26-2006, 02:39 PM | #3 |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
YeS yEs
10-26-2006, 03:06 PM | #4 |
Member#: 54935
NWIC
A td04 is a td04 is a td04
10-26-2006, 03:24 PM | #5 |
Member#: 78118
10-26-2006, 03:25 PM | #6 |
Member#: 29549
TXIC
Vehicle:2003 WRX WRB |
is a 13T
10-26-2006, 03:52 PM | #7 |
Member#: 50404
10-26-2006, 03:57 PM | #8 | |
Member#: 129600
Vehicle:1920 turbo'd donut's ZOMG sprinkels |
TD04 is the TYPE OF TURBO. im not sure on the FXT id assume ya it will fit if not MINOR mods will be needed. TD04 is a TD04 as they said TD04 is a TD04TD04 is a TD04TD04 is a TD04TD04 is a TD04TD04 is a TD04 cool? |
10-26-2006, 04:18 PM | #9 |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
10-26-2006, 06:33 PM | #10 |
Member#: 4955
South East
Vehicle:2004 FXT OffRoadSubarus.com |
I believe Subaru only uses the TD04 13G.
There is a TD04 16G which has a larger compressor. Deadbolt should be able to supply one. Richard |
10-26-2006, 09:35 PM | #11 |
Member#: 29549
TXIC
nope 13T
Is the 00-04 Legacy air box setup same as 2000 Imprza RS???? | Rallly2000 | Newbies & FAQs | 0 | 10-07-2009 03:27 PM |
Are stock wrx headers the exact same as Sti's? | pjones89 | Newbies & FAQs | 2 | 03-10-2007 09:58 AM |
TGV sensor the same as TPS sensor on 04 STi?? | Clark Kent | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 10-20-2006 10:25 PM |
Are 98-99 Rear Brake Assy. the same as a 2k1 on a RS? | Deznuts05 | Brakes, Steering & Suspension | 4 | 04-21-2003 02:29 PM |
is the shifter lever the same on the WRX as MY00-01 RS? | joostin420 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 04-12-2001 08:33 AM |
