Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-13-2000, 08:06 PM   #1
uktena
Member#: 1267
Question Cusco Rear Lower Arm Bar
Just installed the Cusco rear lower arm bar and noticed that the packaging states "This product is designed for use in japan only. It must not be used in any other country". So what's up with that?
uktena is offline
Old 07-13-2000, 08:48 PM   #2
pwrup25RS
Member#: 1011
2004 Impreza WRX
Rally Blue
Post
thats one pic I forgot to take! But I got it too and i didn't notice jack *****. But it looks cooool tho.
Well worth the money!
BRB with the pic too!
Here it is!
http://www.geocities.com/pwrupmr2/pics/cusco.jpg
[This message has been edited by pwrup25RS (edited July 13, 2000).]
pwrup25RS is offline
Old 07-13-2000, 09:15 PM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
Do you think the bar will still fit if there is a diff protector installed? From the pic I can't tell how much clearence there may be.
Peaty
Peaty is offline
Old 07-14-2000, 07:40 AM   #4
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Post
I had the same question, so I asked Mrs. Pam D. from Isr, and this was she answer:
"Hi,
The arm bars came in & it cleared an Impreza with a rear diff protector
Pam"
So It will fit I think, I will order one for me.. then I will post results.
I got sti ver. 5 suspension with 20 mm rear bar, I really wonder if this bar will make any change...
DJIMPREZA is offline
Old 07-14-2000, 08:01 AM   #5
Opie
Floresbian
Member#: 470
2018 Canyon Denali
'18 FXT, '16 XV, '13 BRZ
Post
Mine should be arriving this afternoon! I will post a review as to its "improvements" as soon as it is done
Opie is offline
Old 07-14-2000, 08:07 AM   #6
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Thumbs down
Opie,
thanks
its a shame theres no different with that bar..
ahh well
[This message has been edited by STi Sev (edited July 14, 2000).]
STi Sev is offline
Old 07-14-2000, 08:49 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
IIRC, someone had said that there was pretty much no point in doing this unless you had a full suspension setup in the car, then it might help a little bit.
Also, by the pics that someone posted on this topic on the General board, it looks like there is no way that it'll clear the rear diff protector. If it does, I bet it is just barely...
8Complex is offline
Old 07-14-2000, 09:33 AM   #8
ravent
Member#: 500
00/+ RS/OBS
white
Cool
The bar will not help at all, going to the store or church on sundays...this is for serious suspension stiffening for rallys, rallyx and maybe track days or autox. Soccer moms need not apply, but it does look great and the weight is towards the rear,if you need some ballast. Get the rear strut tower bar first and if that is noticeable, you may deserve the lower bar. ymmv
ravent is offline
Old 07-14-2000, 11:21 AM   #9
uktena
Member#: 1267
Exclamation
Yes, the bar clears the differential protector, just barely. I was concerned that it might hit during some maneuvers; but I have made four high-speed runs through Boulder Canyon and it has not hit, yet. I really can't tell any difference; my suspension is STi v6 springs over AGX's (with front bump stops cut in half), Cusco 21mm rear bar w/Whiteline links (front and rear), and Pirelli P7000 Supersports.
[This message has been edited by uktena (edited July 14, 2000).]
uktena is offline
Old 07-14-2000, 11:38 AM   #10
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
Thanks for the info guys. I have one on order from Dale. He said if it dosen't fit he'll take it back It looks like it will though.
Peaty
Peaty is offline
Old 07-14-2000, 12:04 PM   #11
SubePwr
Member#: 140
1999 RS 2.5
Question
UKT, why would you cut the stops? I have the AGX'x coming in and the STi springs off of a Type R STi car from Jpn.
Just waiting on the struts that have been lost in the mail.
Jim
SubePwr is offline
Old 07-14-2000, 12:17 PM   #12
Opie
Floresbian
Member#: 470
2018 Canyon Denali
Post
SubePwr - KYB recomends cutting the stops if you are using a lowering spring with them to give the strut more travel. I think it says not to cut off more than 1/2, just check the instructions before you do it.
Opie is offline
Old 07-14-2000, 05:48 PM   #13
uktena
Member#: 1267
Post
Opie is correct 1/2" is the maximum recommended by KYB.
uktena is offline
Cusco REAR Lower Arm Bar for '02 WRX Wagon? SilverAP1 Brakes, Steering & Suspension 7 03-07-2002 10:03 PM
Cusco Rear Lower Arm Bar for Impreza ChAi Brakes, Steering & Suspension 4 11-17-2000 04:03 PM
Cusco Rear Lower Arm Bar ...anyone have experience with this? kevinsUBARU Technical Forum Archive 6 09-16-2000 10:15 PM
Cusco Rear Lower arm bar questions M a t t Technical Forum Archive 1 09-16-2000 04:35 PM
Cusco Rear Lower Arm Bar Templar General Forum Archive 10 07-23-2000 02:04 PM
