05-27-2008, 05:13 PM | #1 |
Member#: 128161
Vehicle:2006 wrx limited wrb |
oem oil filter=how long can it last?
bought new oil from amsoil
https://www.amsoil.com/storefront/sso.aspx got the 0W-30 Synthetic web site says the oil can last atleast 17,500 under severe conditions. im not gonna let it go that long, probably 5-7k but how will the oem oil filter hold up? thanks for your help
05-27-2008, 05:28 PM | #2 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
I Change the filter every 6,000km/3,800Miles and change the oil & filter every 12,000km/7,500Miles... Seems to work for my car, it now has 277,000km/173,000Miles. With never anything done to engine or transmission.
05-27-2008, 05:55 PM | #3 |
Member#: 141672
Rated for the normal PM as common sense dictates.
7500 miles max for warranty purposes on an 06'. |
05-28-2008, 09:10 AM | #4 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
What mikey said.
I have run mine to 8,000 miles because I couldn't get around to changing the oil at 7,500 miles. My Blackstone uoa was fine. Another member here, drees, consistently ran the OEM filter to 8,000 miles in his WRX. Do a uoa with Oil Analyzers between 5-7k to find out for sure. -Dennis |
05-28-2008, 05:01 PM | #5 |
Member#: 16827
SCIC
Vehicle:2003 WRX(Sold), Z4 Aspen White |
I thought that if you take off the filter, oil would gush out. How are you changing your filter without changing the oil? Do you just drain it and add it back? Am I missing something?
05-28-2008, 05:27 PM | #6 |
Member#: 79222
W. Canada
No the filter is higher than the oil pan.. Wait 10 minutes after shutting engine off and you can change the filter and you only have to top off the oil for the little bit lost that was in the filter.
05-28-2008, 05:37 PM | #7 |
Member#: 16827
SCIC
cool info, i guess i assumed since it leaks a bit when i remove it. Good stuff.
05-28-2008, 06:15 PM | #8 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
it doesnt matter what the oil companies say, do yourself a favor and follow Subaru's oil change interval. If you however are out of or dont care about your warranty do what you will.
05-28-2008, 07:55 PM | #9 |
Member#: 16827
SCIC
just changed my oil (mobil 1 5w30syn) and oil filter (fram) at 6,400 miles. Time for a wash
05-28-2008, 11:18 PM | #10 |
Member#: 128161
does any one know what subaru's oil chagne interval is? i think the manual says 7500 but I heard they changed that.
can some one confirm this please? thanks! =D |
05-28-2008, 11:47 PM | #11 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
Read the sticky thread titled Oil FAQ and it tells you what the oil change interval is. Sticky threads.....read them BEFORE posting.
05-29-2008, 08:07 PM | #12 |
Member#: 128161
3750 it is
05-29-2008, 10:02 PM | #13 |
Member#: 767
05-29-2008, 10:31 PM | #14 |
Member#: 128161
05-29-2008, 11:12 PM | #15 |
Member#: 147776
Vehicle:2001 Forester 2013 Scion FR-S |
Sooo... I thought for a wrx, you need to change every 3750
Is that from the oil or filter? If filter, can I do the filter change, then oil/filter? |
05-30-2008, 08:59 AM | #16 | |
Member#: 767
Whether or not the oil can last to 7,500 depends on many factors and a used oil analysis is a great way to see how the oil is holding up. Whether the OP runs his oil to 500 miles or 5,000 miles, may not matter anyway. Amsoil gets into the gray area for warranty coverage because it's not "API certified" (except for the XL line). sony - Keep track of the numbers from the Amsoil bottle in case you have to invoke the Amsoil warranty. -Dennis |
05-30-2008, 09:17 AM | #17 | |
Member#: 120057
Vehicle:2018 WRX (base) 6spd WRB |
I thought Amsoil was a great oil for our cars. |
05-30-2008, 09:37 AM | #18 |
GC84Ever
Super Moderator Member#: 301
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
read your owners manual or see the stickies here...
I change mine every 3500 with no exception on my DD I change mine every race on the rally car. http://www.subiegal.com/subarugirlie...iper-paint.jpg |
05-30-2008, 10:05 AM | #19 | |
Member#: 120057
I dont think my owners manual is gonna tell me about Amsoil |
05-30-2008, 11:26 AM | #20 | |
Member#: 767
Just because an oil doesn't have API certification doesn't mean that it's not good. It just means that the companies haven't spent the money to get an oil certified and/or they have higher additives than allowed under the current API ratings. Amsoil and Redline are both great oils, but are not API certified.
There are Subaru dealers that use Motul 8100 5W30, but it meets API SL (the older classification). Quote:
05-30-2008, 11:38 AM | #21 |
GC84Ever
05-30-2008, 12:29 PM | #22 |
Member#: 120057
05-30-2008, 01:27 PM | #23 |
GC84Ever
05-30-2008, 04:03 PM | #24 | |
Member#: 128161
hey i called amsoil to check about this, subaru not covering for warranty. they tech rep. said that they would have to prove it was the oil that caused the problem. i dunno if thats true. or is it that if you do not use an api certified oil, that in it self can be used to justify a denial of a warranty claim? ughhhh i just bought 12 bottles of this stuff. i dont want any problems. |
05-30-2008, 05:02 PM | #25 |
Member#: 41070
Vehicle:2005 Black Tiger (Black Turbo Baja) |
Have you read your warranty statement so you know what it says? Amsoil is probably right, but it'll be your legal bill to force Subaru to cover any failure. Presuming you win, you should be able to get that bill back, unless of course your warranty forces you to use arbitration instead of a lawsuit...
Basically, if you did have a major engine failure AND the dealer decided to claim it was your fault for using Amsoil, the dealer would sit back and claim the Amsoil caused the failure, Amsoil would sit back and claim that Subaru has to prove it was the oil's fault... you see where this goes? Back to you having a big bill to force one or the other of them to pay up and/or make the repair. Now, why you would presume the dealer would automatically know Amsoil was in the crankcase, why you would assume they'd blame the Amsoil, etc., is not clear to me. Take proper care of your car. Don't worry about stuff that's not going to become an issue OR ELSE just don't use something that might maybe perhaps cause you an issue. |
Similar Threads | ||||
How long can she last without a tune? | purduephigam | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 10-03-2006 02:52 PM |
How long can you last | mvstype | Off-Topic | 65 | 03-11-2004 03:41 PM |
How long can you last....(Teh sequel) | Mud Pig | Off-Topic | 37 | 06-09-2003 12:24 AM |
Oil Filter - How Long? | phred's RS | Normally Aspirated Powertrain | 14 | 07-03-2001 04:19 PM |
How long can Impreza last? | WRX-T | Newbies & FAQs | 3 | 05-29-2001 02:15 AM |
