Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 05-06-2016, 04:32 PM   #1826
whiplash willy
Member#: 424843
2016 WRX Limited 6MT
ISM
Originally Posted by MATR6 View Post
Just noticed this yesterday.
The moonroof has one touch open but it doesn't open all the way.
If you press on it after it stops it goes an inch or two more back.
Or maybe mine is defective.
Most new cars with sunroofs do this. The open to the first position, which is the most "aerodynamically efficient", then the second touch opens them completely. You can thank the Germans.
whiplash willy is offline   Reply With Quote
Old 05-15-2016, 12:23 PM   #1827
SpeedHoles
Member#: 339900
Anyone know maximum capacity for a USB drive for inside the center console? It's USB 2.0, correct? Not 3.0...?
Looking at some right now, the little tiny USB drives the size of your thumbnail that I can plug in and forget.
Want to put my music onto one and wondering if the Subaru has a limited reading capacity before I spend money on a 32GB just to find out it won't work...
SpeedHoles is offline   Reply With Quote
Old 05-15-2016, 01:40 PM   #1828
rahulkentonn
Member#: 446980
Thanks for the effort ! I just bought 2005 STI and I need all the help !
rahulkentonn is offline   Reply With Quote
Old 05-18-2016, 03:59 PM   #1829
Rob8716
Member#: 445520
Anyone know if the 15/16 sti steering rack bolts directly to the 15/16 wrx? Sorry if this has been addressed but I can't find an answer.
Rob8716 is offline   Reply With Quote
Old 05-18-2016, 04:36 PM   #1830
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
wouldn't you need to convert to hydraulic steering?
Celery GT-5 is offline   Reply With Quote
Old 05-19-2016, 01:34 AM   #1831
Rob8716
Member#: 445520
Default 2015 WRX & STI Epic Thread of Knowledge
Didn't realize that the sti didn't get the electronic assist haha, so that's a no, thanks!
Old 05-19-2016, 07:03 AM   #1832
SpeedHoles
Member#: 339900
To answer my own question - 16GB max capacity, and either USB 2.0 or 3.0.
Old 05-19-2016, 07:14 AM   #1833
raven1231
Member#: 427206
2016 WRX
My USB drive worked the first drive and then wouldn't connect after that...
raven1231 is offline   Reply With Quote
Old 05-28-2016, 10:24 AM   #1834
Bluemachine
Member#: 302496
2016 STI LIMITED
I have not owned an STI in 3 years., and im finally back. Picked up a 16 limted with 6.9 miles!
So its break in time, but i have a concern or two.
Is it normal for the clutch to feel knotchy at times ? Meaning a tiny bit of resistance ?
This normally occurs at start up or first 5 minutes of driving.
And I'm guessing the 1000 mile break in rule still applies? (keep it under 4k rpm, no wot?)
And break in oil change still do as dealer suggested 1400 miles???
Thanks guys!
Bluemachine is offline   Reply With Quote
Old 05-28-2016, 06:41 PM   #1835
ekoreds
Member#: 445834
Thank you for this, it has become my go to guide for things like torque specs and nut sizes, awesome!!
ekoreds is offline   Reply With Quote
Old 06-02-2016, 12:35 AM   #1836
SubieScott77
Member#: 277050
2015 STI
Lightning Red
Thanks guys!
I broke mine in little different. Drove under about 4,500 RPMs & no WOT for 3,000mi. I then changed the oil. I've since been on a 3,000mi oil change routine to keep her blood clean! Enjoy the new ride. Those limited wheels have grown on me, look easier to clean too. Haha. Oh and the notchy shifting is totally normal. Sometimes it may even be a little more difficult to push it into a gear...but that's normal regardless.
SubieScott77 is offline   Reply With Quote
Old 06-09-2016, 01:49 PM   #1837
WRXtoCustom
Member#: 448610
2004 WRX
Very interesting information.
WRXtoCustom is offline   Reply With Quote
Old 06-10-2016, 02:28 AM   #1838
SkyeC
Member#: 94323
2016 STI
The crap shifting went away after I did the shifter bushing upgrade.
SkyeC is offline   Reply With Quote
Old 06-28-2016, 11:12 PM   #1839
hmunzing
Member#: 321555
2015 WRX
Dark Grey Metallic
Anybody know the prices of replacing the base headlights versus the limited headlights? I smacked a deer pretty well and trashed both.
hmunzing is offline   Reply With Quote
Old 06-29-2016, 08:48 AM   #1840
Obviously Tyler
Member#: 395955
2018 Mazda 3 GT
2018 Crosstrek
Could be well over $1000. But supposedly they're plug & play (minus the auto leveling) and worth the upgrade.
My suggestion, if you can wait, Subarupartswarehouse.com sells everything and they do insane discounts around the holidays.
I would imagine they're having a 20-30% off sale this July 4th, and yes that means 20-30% off those $700 (a piece) headlights.
Obviously Tyler is offline   Reply With Quote
Old 07-01-2016, 09:22 AM   #1841
hmunzing
Member#: 321555
2015 WRX
Dark Grey Metallic
That sounds like a good idea! Thanks for the information!
Old 08-02-2016, 09:33 PM   #1842
eyekyu
Member#: 183670
2002 Bugeye
sorry for the n00b question, but whats up with the truck. its super light and flys open and whats up with not having shocks in the trunk wtf!
eyekyu is offline   Reply With Quote
Old 08-03-2016, 11:05 AM   #1843
Obviously Tyler
Member#: 395955
2018 Mazda 3 GT
2018 Crosstrek
Would you rather have a heavy trunk that requires dampers to hold it up?
Did you not look at the trunk before you bought the car?
Old 08-03-2016, 12:11 PM   #1844
eyekyu
Member#: 183670
2002 Bugeye
True, im just big dealing ha
And no i didnt look at the trunk
Old 08-30-2016, 08:31 PM   #1845
eyekyu
Member#: 183670
2002 Bugeye
can anyone confirm for me, stock turbo.
Garrett MGT2259S, I've come across the specs. The inlet side is 62mm so 2.4in. can anyone confirm, i wanna preform a boost leak test.
thanks
Old 10-19-2016, 12:23 PM   #1846
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
thanks
I can tell you that's not the correct schematic for our turbo. Both the compressor inlet and outlet use a 2 bolt flange. You're most likely going to want to attach your tester to the part usually refereed to the compressor inlet pipe, that has a barbed slip on and is where the air intake attaches
uofime is offline   Reply With Quote
Old 11-07-2016, 11:26 AM   #1847
liquidimpulse
Member#: 361392
2016 WRX
Lapis Blue
does anyone know if the +15 STI seats(front/rear) can be swapped into a +15 WRX?
I've tried combing through the forums but can't seem to find any guidance on this...
liquidimpulse is offline   Reply With Quote
Old 11-15-2016, 08:12 PM   #1848
jw4902
Member#: 436758
Sorry, I can't answer your question, but how'd you manage to f*ck up the stock seats?
jw4902 is offline   Reply With Quote
Old 12-18-2016, 04:23 AM   #1849
Dek 715
Member#: 204018
'16 WRX Limited
CWP
would it be possible to swap in the memory seat buttons if your powered already?
Dek 715 is offline   Reply With Quote
Old 12-30-2016, 12:03 PM   #1850
hallfleming
Member#: 87196
2019 STi
Pure Red
Trunk torque values from a Subaru tech. Helps with trunk swaps.
Trunk lid arm 14 ftlbs
Lower anchor of seat belt 22 ftlbs.
Trunk lid 10ftlbs
Rear spoiler 5.5 ftlbs
hallfleming is offline   Reply With Quote
