Welcome to the North American Subaru Impreza Owners Club Thursday October 21, 2021
Old 02-28-2010, 04:41 PM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default EJ20K vs EJ20G Maf Scaling?
So originally I was going to get a Z32 MAF to just give my car some headroom, but a EJ20K MAF w/ pigtail showed up for a good price. Since both of them are 80mm, the 20k MAF should plug in. The 20k MAF also has the pigtails so that makes soldering it in easier.
My main question is, is the EJ20k MAF scaled to the same degree as the EJ20G MAF? I'm going to get my car tuned with my PowerFc soon and I am wondering If the MAF scaling will need to be changed? It looks like this is an extremely common swap over in the UK, but information is lacking here. I know with the Z32 MAF, the ECU needs to be rescaled, but does the EJ20K MAF necessitate the same thing?
Edit: Is it the same as the Z32 Maf?
JDMFLCL is offline   Reply With Quote
Old 02-28-2010, 06:41 PM   #2
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Isn't there a specific setting in your PFC for a Z32 MAF? I could have swore it had that option!
DuoMaxwell is offline   Reply With Quote
Old 02-28-2010, 07:45 PM   #3
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
there are two different 20k maf's...the EDM is 80mm but the JDM is 90mm...the 80mm version is comparable to a z32 but the 90mm version is comparable the Q45
Cbgrandtheftauto is offline   Reply With Quote
Old 02-28-2010, 08:00 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
Is it also true that the usdm ej22e maf is similarily scaled to the ej20g?
Would like to use a z32 in my Eg33 with an SAFC.
Old 03-01-2010, 12:31 AM   #5
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Jdm what PFC are you running??
Old 03-01-2010, 11:44 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The Ej22e MAF is the same part as the Ej20G one.
Old 03-01-2010, 11:56 AM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
PFC l-jetro
After doing more research, the Z32 Maf would be plug and play, but it isn't worth it.
Old 03-02-2010, 09:14 AM   #8
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I thought they only had the D Jetro for the EJ20R?
EJ20K VS Late Ej20G Cbgrandtheftauto Pre-2002 Factory Turbo Powertrain 64 12-14-2018 05:27 PM
EJ20G vs EJ20G Old vs Late w/Pictures bape-ape Pre-2002 Factory Turbo Powertrain 10 04-14-2017 04:46 AM
Dual MAF VS. Big MAF VS...... R4ND0M_AX3 Engine Management & Tuning 2 10-13-2009 04:25 PM
Anyone have the maf scaling values for an Perrin Big MAF. Stock WRX injectors NITROS Open Source Reflashes 1 02-05-2008 06:57 PM
MAF Scaling 3.5" Blowthrough vs Stock Division By Zero Engine Management & Tuning 2 06-15-2006 12:03 PM
