Welcome to the North American Subaru Impreza Owners Club Thursday October 21, 2021
Old 10-22-2001, 08:32 PM   #1
REDOO2000
Member#: 9829
2002 PLATINUM
WRX
Default turbo timer with aftermarket alarm
what wires do u cut to make the alrm arm itself
does anyone have this problem?
REDOO2000 is offline   Reply With Quote
Old 10-22-2001, 08:37 PM   #2
trboCIVIC&WRX
Member#: 6426
do you mean, how do you get the alarm to arm, while the car is still running with the TT??
Because, I had to modify my civic to do that.
all you have to do is find the wire at the key, that turns off with the key out. then supply that as the switched to the alarm, rather than the switched it is getting (that stays on while the car is still running)
does that make any sense??
trboCIVIC&WRX is offline   Reply With Quote
Old 10-22-2001, 08:44 PM   #3
REDOO2000
Member#: 9829
2002 PLATINUM
WRX
i got the Lo jack alrm with my car
when u shut the car off and get out and shut the door, the car arms automatically.
but when i get out the car while its still running and then shut the door it doesnt arm even when i hit the arm button on the remote because it still thinks im in the car
there has to be an overide
Old 10-22-2001, 08:52 PM   #4
trboCIVIC&WRX
Member#: 6426
thats what Im talking about!!
it doesnt think you are in the car, it thinks that the car is still ON, which it is, otherwise you would be able to arm your car while you are driving....
Old 10-30-2001, 10:40 PM   #5
wy_wrx
Member#: 9484
2002 Impreza WRX
WR Blue
trboCIVIC&WRX
I installed a HKS TT Type1 a few weeks back.
http://i-club.com/forums/showthread....threadid=99447
The TT had a wire go to the E-brake just for this reason..... I wasn't sure at the time, but basically the TT does not kick in unless the E-brake is up. I turned off my car couple times accidentally with the E-brake down and the car just turns off. When the E-brake is up, the TT leaves the car running. I Cut the 2 wires to the security & remote entry and I'm able to just turn my car off and walk away and arm the Alarm now.
REDOO2000
I'm not sure how this would work with an aftermarket alarm. I guess it depends on the alarm itself. Can the alarm installers help you with this?
wy_wrx is offline   Reply With Quote
HELP! Turbo timer to aftermarket Alarm Install (arming problem) UpTown I-TS Car Audio, Video & Security 2 05-07-2007 02:08 PM
Turbo timer and aftermarket alarm question litlechina Electrical & Lighting 2 04-04-2006 01:12 AM
turbo timer & aftermarket alarm ? billy boi Electrical & Lighting 2 03-09-2004 06:24 PM
turbo timer & aftermarket alarm ? billy boi Car Audio, Video & Security 1 03-09-2004 05:07 PM
updated single relay for turbo timer and aftermarket alarm!!! netZ Car Audio, Video & Security 3 06-03-2003 10:01 PM
