Welcome to the North American Subaru Impreza Owners Club Tuesday October 26, 2021
Old 02-21-2007, 10:11 PM   #1
rotarydelight
Member#: 125207
2006 WRX STI
ASPEN WHITE
Default Horn, E-Lights, and Cruise Control connected?
i have a 06 sti and wanted to knowif By any chance the horn, emergency lights, and cruise control connected somehow? maybe they are all controlled by a cpu or a fuse. i notice that my horn does not work, my e lights dont either. and i cant seem to get the cruise control to hold my speed.
rotarydelight is offline   Reply With Quote
Old 02-21-2007, 10:46 PM   #2
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Have you checked your fuses?
If you have not modified the electrical system in any way or installed anything that may have caused this, then let a dealer fix it under warranty. This should not be happening.
There is something in common with the horn and cruise, the clock spring or roll connector in the steering column. However this is usually a failure item only on high-mileage cars, and when it goes it is also accompanied by an airbag light since the airbag uses it as well.
If by "emergency lights" you are referring to the hazard flashers they are separate and do not use the roll connector.
Old 07-04-2007, 02:56 AM   #3
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
all due respect, but since I no longer have a warranty and attempted the under-the-hood fuse fix, I will post here & continue my search, thank you
Justin
cellobro is offline   Reply With Quote
Old 07-06-2007, 07:59 AM   #4
antilogick
Member#: 153225
Default clock spring cruise control
i am having this exact problem you describe Mulder, can you tell me more about the clock spring or point me to a thread that describes more about it?
antilogick is offline   Reply With Quote
Old 07-07-2007, 12:17 PM   #5
cellobro
Member#: 91500
hmmm sr-30+640cc=?
bump, wish I had the time recently to crawl under my dash, betcha the issue is HANGING right there...
Old 07-07-2007, 01:31 PM   #6
danmezz
Member#: 126339
2003 WRX Wagon
there's a second fuse panel on the bottom left of the dash behind the coin tray (at least with 03's)... might be worth checkin the fuses in there. Other than that it might be a worn switch or bare wire shorting out or something...
danmezz is offline   Reply With Quote
Old 07-18-2007, 02:04 PM   #7
nuccadave
Member#: 154189
I'm having the same problem. I just purchased a 2000 Legacy Gt which has 110K on it. The hazard, horn and the cruise has worked once. The wiper pump didn't work yesterday, but did about 2 weeks ago. I replaced the fuse under the hood a few times. Switched the horn/hazard relay with a headlamp relay until it blew the fuse again. I think there is something happening in the steering column. I'm looking into the clock spring idea. The seal through the firewall on the steering column was off when I bought the car (very odd I thought). The guy told me his daughter ran up the side of the car accidently. His buddy fixed the front end. I'll look for broken wires under the hood and fuse box.
Any more ideas?
nuccadave is offline   Reply With Quote
Help!!Check Engine Light and Cruise Control Blinking raczs_wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-18-2009 01:09 AM
Check Engine Light and Cruise Control Blinking #17B STI AccessPort 0 11-25-2007 04:27 PM
Check engin light and cruise control light BooSTIn_StI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 04-02-2007 11:18 PM
Help check engine light and cruise control blink islandboy78 North West Impreza Club Forum -- NWIC 16 10-31-2005 09:34 AM
Of fog lights and cruise control... FloridaDude Electrical & Lighting 7 02-01-2005 11:37 PM
