Welcome to the North American Subaru Impreza Owners Club Thursday October 21, 2021
Old 03-02-2010, 11:24 PM   #1
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Question Has anyone open source tuned ej22t + wrx heads/manifold?
I may soon have the opportunity to do this swap into a 93 impreza l or 96 obs. I have both cars now.
I found a 91 legacy ss for $500 (whole car)
I plan on just doing a stock swap to start and then aquire the necessary parts to build the hybrid motor. I don't live near any tuners but have a friend who open source tunes his own wrx.
I searched but did not find anything specific to this setup.
Thanks in advance
geronimo81 is offline   Reply With Quote
Old 03-03-2010, 12:13 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Old 03-03-2010, 09:57 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
I tuned an EJ22E shortblock with wrx heads/heads/manifold/ecu. It's no different than tuning any other wrx, make adjustments till it's right. Start conservative on boost timing and fuel and work your way up. That combo liked less timing. With an EJ22T it's going to have really low compression I think 7 to 1 so it may like more timing.
Old 03-03-2010, 11:21 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
open source tunes only work on 2001+ cars
the older ecus are chip based
Old 03-03-2010, 06:53 PM   #5
oldskoolWRX
Member#: 66248
1983 turbo brat
black and white
no, it actually has a bit more compression with wrx heads, chamber size is smaller than the stock 22t head (primarily due to the bore discrepency). if it has forged pistons, it can even be higher as most forged for the 22 are several thousandths positive of deck height and require a specific head gasket.
as for open source tuning, the chip ecus do not work that way. there is a vendor on bbs.legacycentral.org working on a user programmable interface that replaces the ecu "chip", similar to a moates "ostrich", but specific to the ej22. downside is, he hasn't responded to my last 3 emails and the system was supposed to be available at the end of last year. timmy p on here has a user interface on his 94 turbo wagon with ej25d heads and a td04, you may want to pm him.
oldskoolWRX is offline   Reply With Quote
Old 03-03-2010, 08:45 PM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Sorry, I should have been more specific about which ecu I plan on using.
I will be using a wrx ecu along with the heads and manifold.
I definitely want to do forged pistons as this seems to be the weak spot in the ej22t.
Plus I know I will want to keep cranking up the boost on this setup
Old 03-03-2010, 09:46 PM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
EJ22T heads are like 40cc where as WRX are 49cc. WRX heads with stock EJ22T pistons will get you something like 7.7:1 with the 3layer thickness like the WRX.
I had pistons made for my EJ22T block to go with my '06 WRX heads. Very simple. I had them make my pistons with a EJ205 compression height and that sets the pistons at the height I wanted.
Open source tuning anyone? ILEJ20 Mid West Subaru Owners Club Forum -- MWSOC 22 02-17-2009 11:15 PM
Anyone Do Open Source Tuning In NEPA?? Kahn23 Mid Atlantic Impreza Club -- MAIC 3 12-29-2007 11:33 AM
The Official Enginuity Open-Source Tuning Thread qoncept Engine Management & Tuning 188 11-13-2007 08:15 PM
Anyone in Houston running Enginuity Open-Source Tuning? KnightWRX Texas Impreza Club Forum -- TXIC 52 06-02-2007 09:25 PM
Anyone in MLK AO running Enginuity Open-Source Tuning? zman519 Mid West Subaru Owners Club Forum -- MWSOC 2 02-07-2007 12:40 AM
