Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 10-19-2013, 02:55 PM   #576
xXOli450Xx
Member#: 362238
Intake camshaft gear parts number for version 4 sti engine ( the 2 of them)
timing belt tensioner parts number for version 4 sti engine
anyone have them?
thank you
xXOli450Xx is offline   Reply With Quote
Old 11-08-2013, 09:26 PM   #577
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Just want to confirm if the part number 11810AA000 that was posted earlier is the correct pcv for the 97/98 ej20k engine. I want to be sure and get the correct one in case the turbo models had a different spring rating or some other internal difference. This part number also crosses to sixty katrillion na subarus, just wanted to double check.
2slofouru is offline   Reply With Quote
Old 11-28-2013, 04:29 PM   #578
subi400
Member#: 216984
1996 Impreza outback
Green
Glad I found this thread again but read through the whole thing this time.
This may sound a little crazy, but here is something I have been thinking of the last day or so.
I know that the ej20k wrx none sti cams fit in the usdm ej25D 96-early 99 legacy, 98 rs and forester heads depending on if it is HLA or bucket with shim over or under.
Now I have a 96 usdm impreza wagon 5 spd and been looking at getting a later 90's phase 1 ej20 DOHC NA none avcs longblock. I already know the ej25D intake manifold will fit as I have like a 97 legacy gt longblock sitting in my parents garage right now.
If the ej25D cams will fit in the ej20 DOHC none avcs heads, then that means the ej20K wrx none sti cams will fit in the ej20 DOHC NA heads. I realize the buckets/shims will have to be adjusted, but would these cams be an upgrade in the ej20 DOHC NA none avcs heads? What about the overlap characteristics or would it matter in this case? I have a 98 rs 5 spd ecu in my wagon so I already have the 6500 redline. Will be using an obx 4-1 EL header.
Thanks guys.
~Josh
subi400 is offline   Reply With Quote
Old 12-02-2013, 12:51 AM   #579
subi400
Member#: 216984
Green
Bumping this up. Need to know this information since the jdm stuff is difficult to get certain bits of information.
Old 12-02-2013, 03:07 PM   #580
Dan7140
Member#: 228950
Originally Posted by i_c_the_light View Post
Same as any AWD GC Impreza.
Wrong, they could be the VLSD (NOT a MLSD) that uses the dual splined rear axle and the other side is normal. Hard to find those.
Dan7140 is offline   Reply With Quote
Old 12-02-2013, 06:50 PM   #581
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
This is more of a question for the swaps / conversions and built motor forums. In this thread it could take a while. Did you try the RS25 swaps forum yet? I would help but don't know anything about the differences in overlap, duration and lift on these cams. :/
Old 12-02-2013, 07:16 PM   #582
subi400
Member#: 216984
Green
I'll take a look in there and see if I can come up with something.
Would you happen to know what the compression is of the subaru jdm ej20 DOHC NA none avcs motor is? I am about to buy one and was just wondering.
Old 12-05-2013, 10:34 PM   #583
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Could I please get the part number for the check valve and O ring under the Idle air motor in the jdm ej20k engines? They sit in the intake manifold and are held in by the idle motor. Thanks!
Sorry, I'm not sure.
Old 01-04-2014, 03:53 PM   #584
xXOli450Xx
Member#: 362238
Default ej20k
Anyone know where i can find ej20k (Sti v4 ) intake gasket?
Old 01-07-2014, 11:14 PM   #585
WelDun1
Member#: 249130
1999 Ver5 STi RA
Yes, Contact Dave over @ RalliSpec and he will definitely take care of you!
WelDun1 is offline   Reply With Quote
Old 01-29-2014, 07:31 PM   #586
flyerpope
Member#: 207024
87 GL-10
trying to part a 92-93 JDM EJ20G V1/V2 intercooler (non STI). Any part numbers or leads would be amazing! thanks
flyerpope is offline   Reply With Quote
Old 08-10-2014, 03:49 PM   #587
chemtek
Member#: 310710
2008 Impreza WRX
Any chance to find out model number from 1996 chassis code GC8-041457?
Thanks
chemtek is offline   Reply With Quote
Old 08-10-2014, 05:14 PM   #588
chemtek
Member#: 310710
2008 Impreza WRX
Default EJ20G/EJ20K part number thread
Did some digging around and found this site
http://www.carrol.ru/_pages/subaru/i...Fya2V0PT11c2E=
Put my mind at rest, I have a 1996 version 2 STi with EJ20G (model GC8C4ED) on its ways to me. I was worried because I found new photos and the intake wasn't painted red. Thought maybe I bought an untruthful car from auction.
Old 08-21-2014, 09:43 AM   #589
fozzylumpkins
Member#: 399582
Hey all. I have a jdm my01 forester s/turbo. I have ej205d non avcs...is it possible to get the maf part number for me?
fozzylumpkins is offline   Reply With Quote
Old 08-26-2014, 08:41 PM   #590
onurba32
Member#: 203150
1996 gf8
red
I cannot find the v1 v2 dccd viscous part number
is it possible to find the part number?thanks
onurba32 is offline   Reply With Quote
Old 08-31-2014, 03:28 PM   #591
BillyMagnum
Member#: 219892
00' RSTi (Sold)
17' PRD WRX CVT
97 ej20k
all 3 timing cover pieces part numbers?
All of mine are cracked and have holes
Also trying to identify this part number and where I can get a replacement?
Circled below. Has something to do with Vac Lines.
As you can see some sort of gel/glue has leaked out of it and into my engine bay
BillyMagnum is offline   Reply With Quote
Old 08-31-2014, 03:56 PM   #592
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
That is the boost solenoid, maybe try Grimmspeed for a bolt in replacement.
Old 08-31-2014, 04:03 PM   #593
BillyMagnum
Member#: 219892
00' RSTi (Sold)
17' PRD WRX CVT
Yes just figured that out. BCS
It has 2 ports on it and GS one has 3?
HMMM
Old 08-31-2014, 04:18 PM   #594
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
My 97 ej20k boost solenoid has three ports...hmmmmm
Here's a pic of when I was first installing everything, you can see the top nipple on mine has a broken piece of hose on it. (where they start melting/leaking)
The three port design has seperate connections to the turbo, wastegate, and the inlet pipe. Even if you have a two port, you can use the three port style.
Old 08-31-2014, 05:33 PM   #595
BillyMagnum
Member#: 219892
00' RSTi (Sold)
17' PRD WRX CVT
Gotcha ok thanks. Do you have a pic of it after install? For reference please. You can pm me since we're getting off topic here. Will I need a tune?
Old 08-31-2014, 05:39 PM   #596
chemtek
Member#: 310710
2008 Impreza WRX
I believe the older Jdm ecu can adjust to different mods a lot better then newer cars. I think you could just get a decent MBC and set to desired boost setting. But leave the electronic connector still plugged in on your old boost solenoid as to not throw a check engine code.
http://forums.jdmvip.com/How_to_Inst...Impreza-3202-t
Old 08-31-2014, 06:07 PM   #597
BillyMagnum
Member#: 219892
00' RSTi (Sold)
17' PRD WRX CVT
I have apexi power fc
Old 09-02-2014, 05:06 PM   #598
flyerpope
Member#: 207024
87 GL-10
Can I get a part number for the MAF on a 1992 JDM EJ20g?
Sent from my iPad using NASIOC
Old 09-02-2014, 09:47 PM   #599
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I have a pic off the net of the routing of the lines, will try and find it. Mine is now an aftermarket 3 port. I ran the jdm 1S ecu for a long time with 93 octane fuel zero problems, ran like champ.
I am now using a powerfc as well, its been untuned except for boost duty cycle adjustments and preliminary idle setup. I ran it on my previous ej20k setup and am still running it with my modded ej20k heads/ ej257 bottom end setup and it runs smooth but I need to tune it to get the most out of the build. It can build boost quickly and go into boost cut if the outside temps change a lot.
Old 09-02-2014, 09:50 PM   #600
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
If you are talking about the ones from the manifold to the head, they are the same as usdm ej25dohc na 96-98. PN 14035AA281
The four mounting bolts are all inline. If you are referring to the one that connects the throttle body to the manifold...my bad.
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
