Welcome to the North American Subaru Impreza Owners Club Wednesday October 5, 2022
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-30-2000, 08:28 PM   #1
tmaler13
Member#: 1992
Question help..S-AFC Blue wire O2 sensor??
Yes i searched first, but there does not seem to be an agreement on where the blue wire from the apexi S-afc gets spliced into on the ECU harness to measure the O2 voltage . I need the wire number and the color for a MY99 Impreza RS, US spec ej25
I know there's 2 o2 sensor wires front/rear
Please help...tuning will be so much easier.
p.s i checked lagging.com
Terry
tmaler13 is offline
Old 08-30-2000, 08:56 PM   #2
[email protected]
Member#: 67
1999 Outlasting
the competition.
Post
B136 #7
dont know the color tho
tom@kartboy is offline
Old 08-31-2000, 06:53 AM   #3
Nat
Member#: 759
2012 Regal GS
2000 SV650
Post
I can't really remember what the color is either, but I hooked mine to whichever one is the front O2 sensor. Reading O2 voltage after the cat will change the results and not be accurate.
Nat is offline
Old 08-31-2000, 01:08 PM   #4
tmaler13
Member#: 1992
Smile
Thanks, i'll hook it up tomorrow morn.
tmaler13 is offline
Old 08-31-2000, 07:41 PM   #5
Avenger
Member#: 1234
Post
I have a 2000 RS what should I set this voltage to when tunning? Thanks!
Avenger is offline
Old 09-01-2000, 08:03 AM   #6
tmaler13
Member#: 1992
Post
I believe its between .85-.87.... from what i remember when searching...I know there's alot of posts about them.
tmaler13 is offline
Old 09-01-2000, 09:26 AM   #7
Mumbles
Member#: 248
Post
BTW- Lagging is working again;
http://lagging.com/cgi-bin/pic.pl?fi...s/safc2000.jpg
-Brendan
Mumbles is offline
Old 09-01-2000, 09:29 AM   #8
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
If you have a 2000 RS, you shouldn't set it to .85-.87 because
1. if you connected the afc to the front O2 wire, it's a wideband sensor that reads from 0-2.2V instead of 0-1V, so you'll destroy the motor if you try for .87V.
2. if you connected the afc to the rear O2 sensor, it will give you a delayed and inaccurate reading that you have to compensate for.
Do what I did & invest in an EGT gauge!
~G
RidinLow is offline
Old 09-07-2000, 04:51 PM   #9
JayB
Member#: 208
_ _
_
Question
Okay guys, I just received my S-AFC tonight from the UPS man. I searched all over this site, for info on how to install it. Everything seems clear..except this blue wire. I have seen some posts that say to put it on B136 #18, and others saying to put it on B136 #7.
Kartboy, are you sure its #7?
What wire are you guys using?
One more thing, did most of you solder the S-AFC wire onto the wiring harness? It seems like a much nicer thing to do than using those crimping things supplied with the S-AFC.
I have a 99 RS, if that makes a diffence. What is the correct wire to use for O2 sensor?
Thanks a million!
Jay Boudreau
JayB is offline
Old 09-07-2000, 09:54 PM   #10
tmaler13
Member#: 1992
Post
On the 99RS, it is B136 #7, i just did the mod last week. It will be a white wire on the 99. And yes i soldered all the connections on the ecu.
any ques...just email me
[email protected]
tmaler13 is offline
Old 09-08-2000, 01:31 PM   #11
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
OK... if you connect said blue wire to the front o2 sensor wire, which view shows the voltage?
Moochass Grassyass
Chuck is offline
Old 09-09-2000, 12:21 AM   #12
Wannabeturbo
Member#: 2328
Talking
If you have a 2000rs listen to RidinLow he knows what he's talking about. If you want you can also add another O2 sensor to your already sensored out exhaust. Rallispec told me that's what I had to do to get my rich/lean meter to work properly with the 2000rs's.
Wannabeturbo is offline
Old 09-09-2000, 07:11 AM   #14
tmaler13
Member#: 1992
Talking
ETC.
Check Sensors.
Sensor #2
tmaler13 is offline
Old 09-11-2000, 06:20 AM   #15
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
Thanks!
Chuck is offline
WTB: 4-wire O2 sensor clsmooth VIC Private Classifieds 2 05-07-2010 12:21 PM
Who makes the best 4-wire O2 sensor? camshaftprelube Off-Topic 14 01-29-2010 11:24 AM
Difference between 4 & 5 wire O2 sensor Petersubaru Normally Aspirated Powertrain 9 12-14-2006 06:42 PM
Help! I can't find my O2 sensor plug gregsatt Texas Impreza Club Forum -- TXIC 5 11-10-2006 02:58 PM
EJ20G TWO wire O2 sensor AsphaltsCry Subaru Conversions 3 03-30-2005 01:01 PM
