Welcome to the North American Subaru Impreza Owners Club Tuesday April 22, 2025
Old 05-02-2021, 11:16 AM   #151
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
*Stickied ..as I am about to do this on my STi.
Bill
Old 05-04-2021, 03:04 AM   #152
Owen H
Member#: 522491
Originally Posted by snake2332 View Post
Snake I also have a 2016 STI running the AEM UEGO. I don't think I explicitly saw you state which wire you connected to the back of the AEM gauge.
Which wire on the TGV plug do I connect the white wire on the AEM gauge? I have everything installed except I am waiting to determine which wire to tap into for the signal. Thanks dude.
Owen H is offline   Reply With Quote
Old 05-17-2021, 04:20 PM   #153
JSR84
Member#: 469585
2009 STi
Delete
JSR84 is offline   Reply With Quote
Old 05-24-2021, 08:14 PM   #154
AndrewD5418
Member#: 366602
What are the sensor voltage settings you've used? I believe I have the same gauge, the uego x.
AndrewD5418 is offline   Reply With Quote
Old 06-19-2021, 10:50 AM   #155
anotherfrostback
Member#: 524583
Hey,
I know I want to connect the 5v for signal, 12v for power and the ground. I don't know if I missed anything right in front of my face but I dont seem to be able to figure out which wires correspond with which pins on the plug.
I am looking at getting this pigtail kit to go with the AEM 30-0310.
I am hoping to wire up to a connector to avoid cutting any factory wiring. any help is greatly appreciated
anotherfrostback is offline   Reply With Quote
Old 06-14-2022, 07:51 PM   #156
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Default Plx wideband?
I have a plx controller and wideband sensor and was told I could install the plx sensor in place of the front oem sensor, then use the 5v output from the plx box to send signal to the pin of the oem sensor that the oem sensor normall uses.
This way I could use the plx gauge to watch. Would the accessport be able to use the front sensor input for logging?
I messed up and bought a single bung downpipe, so I'm trying to find a way besides having an extra bung welded in. Local welders suck and it's my daily vehicle.
2slofouru is offline   Reply With Quote
Old 12-29-2022, 11:19 AM   #157
JohnSub2013Sti
Member#: 531737
Can i leave the Rear o2 sensor plugged in for this
(Just with the required wire for the wide band unplugged)
Or would this damage the rear o2 sensor long term
JohnSub2013Sti is offline   Reply With Quote
Old 01-21-2023, 12:09 AM   #158
kimcheefists
Member#: 513239
Default How does this work with Cobb’s Greenspeed?
I’m looking to getting an Etune in the future and I‘m wondering if this procedure is still applicable with Cobb’s Greenspeed. How does this work when an emissions sensor (secondary o2 sensor) plug is being used to send the 5v signal from the wideband to the ECU?
kimcheefists is offline   Reply With Quote
Old 02-16-2023, 07:21 PM   #159
Nick banta007
Member#: 510336
Default Same issue
I am wondering the same thing!!!
Nick banta007 is offline   Reply With Quote
Old 03-03-2023, 09:02 AM   #160
Router Rob
Member#: 466327
2017 WRX STI
CWP
It doesn't work with greenspeed. You would have to get tuned on the old system.
Router Rob is offline   Reply With Quote
Old 05-20-2023, 10:40 PM   #161
ForestHer
Member#: 534332
Originally Posted by my9999 View Post
does this affect to way the rear O2 functions? If hooking up to TGV wire i take it they have to be deleted?
I'm thinking you would be able to log wideband with btSsm.
nah i don't think so, could be wrong
ForestHer is offline   Reply With Quote
Old 09-09-2023, 01:04 AM   #162
PSM2002wagon
Member#: 535457
Default Gauge not working after wiring it up
I know this is an old tread but worth a shot… I tried this on my 02 forgot to ground the brown wire so it didn’t work but that’s not really the issue. My gauge isn’t reading any value at all now. When I turn the car on it shows (0300) then (L1.84) and holds that. Anyone know what the issue could be? (I didn’t change any of the previous wiring other then adding to the white 0-5v output)
PSM2002wagon is offline   Reply With Quote
Old 09-28-2023, 06:54 PM   #163
spoolinsti05
Member#: 108051
2005 WRX STi
Buy an innovate or a ngk ntk
Sent from my moto g 5G (2022) using Tapatalk
spoolinsti05 is offline   Reply With Quote
Old 09-28-2023, 06:55 PM   #164
spoolinsti05
Member#: 108051
2005 WRX STi
Or a plx
