Welcome to the North American Subaru Impreza Owners Club Monday April 28, 2025
Old 12-28-2004, 02:09 AM   #1
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Default How to use high-level inputs on my 2 channel amp for a single sub?
Hi all,
I'm going to try using high level inputs on an amp I have for a single 10" sub. It's a 2-channel amp that can be run in mono by bridging the channels. My main question is whether I can do this...the high level inputs on the amp require both a left and a right channel speaker input. Since I don't care about left vs right, can I just run a single wire from a right rear speaker, then split it into two for the high-level inputs? Will there be any problems from splitting this source wire? Also, am I right in assuming that I can just splice into the existing positive wire going to the speaker? The amp's high level input connections have a ground wire built in so I don't need to splice into the speaker's negative wire at all. Thanks for your help! BTW, before people tell me to use a LOC...I am going to run RCA cables while I install this, so if the quality is not good enough with the high level inputs, then I'll switch to using a LOC with the RCA's.
ImportVenom is offline   Reply With Quote
Old 12-30-2004, 12:02 AM   #2
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Bump
Old 01-06-2005, 01:30 AM   #3
ImportVenom
Member#: 34204
2004 WRX
WR Blue
After the holiday bump...anyone know?
Old 01-06-2005, 09:14 AM   #4
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
you should really bring both signal. it's not that complicated and will lead to better bass. What if there's only bass on one side? you will miss it.
NicEJ25 is offline   Reply With Quote
Old 01-06-2005, 11:28 AM   #5
Brock
Member#: 10797
2011 STI sedan
Definitely use both channels. What he said about cutting a stereo signal in half. You could be missing half of the bass.
Brock is offline   Reply With Quote
Old 01-07-2005, 03:20 AM   #6
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Thanks guys! Hadn't thought about that L vs R issue.
How to install 2007 AUX Input on 2006 WRX? GooseMan Car Audio, Video & Security 5 08-15-2011 05:27 PM
I never learned how to use the shift key with my right hand. coop119 Off-Topic 24 11-19-2007 02:48 PM
speaker level input on an old Clarion amp RR Car Audio, Video & Security 2 06-05-2007 04:47 PM
best 2 channel amp for ~$150 nic Car Audio, Video & Security 5 05-21-2003 04:53 PM
How to wire Greddy turbo timer on a 2.5RS? bigbird Interior & Exterior Modification 3 06-10-2002 12:49 PM
