Welcome to the North American Subaru Impreza Owners Club Thursday October 3, 2024
Old 04-02-2006, 01:37 PM   #1
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
Default FAQ Legacy vs WRX Suspension swap questions
So you wanna use WRX/Impreza parts to lower your legacy, well ok.. Here's the down and dirty of it. I will be using specs from 97-99 legacy's and 02/03 impreza's.
What will fit:
From - Any spring/strut combo made for MY02/03 Impreza WRX/RS/L
To - MY97-99 Legacy GT/L/Outback wagon/sedan
Please keep in mind***8230;
Impreza sedan swaps to Legacy Sedan.
Impreza wagon swaps to Legacy Wagon.
Specs:
Ground Clearance:
Legacy = 6.1 (both sedan/wagon)
Legacy Outback = 7.3 (SUS+wagon)
Springs: I don't know the exact spring rates but the curb weight between Impreza sedans and Legacy Sedans are pretty close, same with the wagons with the exception of the Outback.. I think its heavier due to the beefier struts/springs.. but its only off by a few hundred pounds. And lets face it, if you're doing this swap you're looking for a cheap down and dirty drop so it's not gonna make a huge difference in ride quality. But I do know this..
GT springs are 25% stiffer than L model springs.
Outback/SUS springs are taller/stiffer than L/GT springs.
Struts: It's pretty much a KYB world here folks.
GR-2's - 25% stiffer than stock Legacy struts.
AGX's - have 4 settings
Setting #1 this is pretty close to the OEM stiffness
Setting #2 25% stiffer than setting #1 same stiffness as GR-2's
Setting #3 I cant remember for sure but its either 15% or 25% stiffer than setting #2
Setting #4 is the stiffest. Track use only, very uncconforatble street ride.
So what strut is best for you? Well figure out where you're gonna be driving.
Myth #1 The Legacy Outback/SUS uses body spacers to get its height.
WRONG! There are no spacers, the Outback/SUS gets its extra inch from stiffer/taller springs + A beefier longer strut.
*edit* Ok so I was kinda wrong here.. there are body spacers on the Outbacks, I saw them when replacing my rear subframe, but its to keep everything aligned not for any type of lift.
Ok, unless there are any other questions here's the meat..
Question #1 - I want to lower my Legacy Outback/SUS what do I need to do this.
Answer #1 - Get suspension from same model legacy/GT this will drop your outback to 6.1" from 7.3". easiest and best way. If you use GT springs you will get a performance upgrade as they are a slightly stiffer spring.
Question #2 - My cousin/friend/message board said I can use WRX struts/springs is this true?
Answer #2 - YES! Is it true, all rejoice! Now, how do you do it.
Step 1 - Source 02/03 WRX/Impreza struts/springs/upper spring perches/strut tops(tophats)
You will need to get the same parts as what you have. (wagon to wagon, sedan to sedan) this is due to the wagon springs being designed for a wagon. Now you can use wagon parts on your sedan it just may sit a little higher in the rear. Also WRX wagon springs are softer in the rear than sedan springs. So its just better to keep it wagon to wagon***8230;.etc***8230; The upper spring mounts for the fronts are the same between wagon/sedan so that doesn't matter.
Step 2 - Front: You will need to re-use the rubber spring spacer from your legacy upper spring mount. You will need to trim it a bit to fit the smaller impreza spring as they are tapered at the top.
Rear: You can re-use your legacy parts here, as the rear upper spring mounts are the same.
So a quick recap.
Parts: Front impreza struts/springs/upper spring perches/strut tops.
Rear struts/springs
Bolt those on and get an alignment and you're all done.
After Market vs. OEM - So yes any aftermarket springs will work with what ever setup you have. Once you've swapped on your WRX suspension you can use any spring made for 02/03 wrx's.
I have a 1999 legacy outback with a 02/03 wrx struts with Tein S-tech springs. My car is low.. really low. I get rubbing in the rear fenders which if I roll the fenders would prob fix this problem. But I did also pay $150 for the whole setup and it does handle very well. If I could do it all over again I would prob go with this setup..
GR-2's + (GT/aftermarket springs) swapping on GR-2s will drop my outback down to stock legacy height (6.1) then any other drop would be from the springs. The only reason for this would be legacy springs are made for legacy's.. So the rates would be closer to perfect. But I do flip-flop on this every week or so. I have rallycross'd this setup quite nicely for over a year as well, but I did break a Y-pipe and trash my OEM exhaust due to being so low.
I hope this helps out, and feel free to send me updates or anything I might have missed and I'll add it.
spdracr00 is offline   Reply With Quote
Old 04-02-2006, 01:45 PM   #2
DLC
Member#: 1964
2012 Fit Sport 5MT
Orange Burst
This has been added to the forum FAQ in the BD/BG area. If it is expanded to encompass BC/BF, it should be moved to the General section.
DLC is offline   Reply With Quote
Old 04-02-2006, 01:53 PM   #3
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
They changed the rear setup in the BE/BH so you cant use WRX suspension parts. FYI.
Old 04-02-2006, 02:17 PM   #4
sha_zapple
Member#: 41012
1998 Legacy L
Awesome! so what about aftermarket Impreza top hats. Will they work with both Impreza and Legacy suspension?
sha_zapple is offline   Reply With Quote
Old 04-02-2006, 02:38 PM   #5
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
Impreza springs must use impreza (upper spring mounts)tophats and vice versa.
Old 04-02-2006, 03:21 PM   #6
DLC
Member#: 1964
2012 Fit Sport 5MT
Orange Burst
Yes, BE/BH and BL/BP are entirely different in the rear. The next Impreza will probably have something similar to the Legacy suspension in the rear, but that's a ways off.
Old 04-02-2006, 03:31 PM   #7
Wiscon_Mark
Member#: 94945
2015 Dodge Charger
AWD
A ways off? The impreza gets changed every two years
So they completely changed the suspension from BE/BH to BL/BP also?? I know it went to multilink from BD-BE, what is it with the BL?
Wiscon_Mark is offline   Reply With Quote
Old 04-03-2006, 04:21 AM   #8
jamal
Member#: 71875
Well, the chassis doesn't, but I feel like a new one will be coming within the next 2-3 years which would probably have a different rear suspension design.
Anyway, is the BD/BG track as wide as the GD? I feel like it's not, which will cause the same issues as when swapping to 1st gen Impreza or Legacy. I'm using 04 STi stuff and I'm not happy with how the camber turned out.
I was also under the impression that the rear strut tower bolt pattern was the same for 95-99 Legacy and 02+ Impreza, so you would be able to swap entire assemblies instead of trimming spring seats or whatever.
I'm working on it.
jamal is offline   Reply With Quote
Old 04-03-2006, 05:09 AM   #9
jamal
Member#: 71875
Okay here goes:
Since front suspension is basically a direct swap between all Subarus, I'm going to focus on the rear because that's where most problems come in.
There are two different 90-94 Legacy rear suspension designs, and two different 02-06 Impreza rear designs.
The 90-91 Legacy has a tapered rear spring with an integrated spring perch and top, like this:
thanks for the source image, THAWA
The 92-94 Legacy has straight spring and a separate top and perch, like this:
(This is also identical to the 93-01 Impreza)
The 02-03 Impreza has a straight spring and an integrated top and perch, like this:
thanks for the source image, oakos
The 04-06 Impreza has a tapered spring and an integrated top and perch like this:
The neat thing is that the tapered springs and the straight springs have the same top and bottom diameters so you can switch tops.
A 90-91 Legacy top/perch will fit on an 04+ Impreza spring.
A 92-94 Legacy (and 93-01 Impreza) perch will fit on an 02-03 Impreza spring.
Then you can just get the tops that correspond to the set of suspension you want to put in, and you're all set. You probably need washers to prevent clunking while using 04+struts with 90-91 tops because the shoulder on the top of the strut is slightly different.
Since BD/BG tops are all the same pattern as an 02-06 Impreza, fitment there is pretty simple. I'm curious as to how different springs fit on different upper perches and struts between the two though. From what I can gather the springs all fit on any strut, so the only conflict comes with the upper perches and rear tops.
The next issue that comes up is the alignment. The GD has a wider track than a GG, which comes from longer lateral links and control arms. This changes the geometry slightly and the angle of the mounting holes on the bottom of an 02+ Impreza sedan strut. This basically means that if you put Impreza sedan struts in a Legacy, there will be less negative camber. The most camber available seems to be about -1 degree in the front and it will be about half a degree positive in the rear. However, the difference between the cars is not simply an issue of track width. There is also a slight difference between a GG and the Legacy, so the angles of the holes on the flange on BC, GD, and GG struts are all different. I suppose it's all close enough to get away with switching things. I'm sort of working on figuring out the exact differences.
I have 04 STi suspension with camber bolts maxed out in the rear and I'm at about -1.5 degrees. I don't want to touch them to avoid slippage, and I'm happy with the amount, so I need to get more up front. Camber/caster plates seem to be on the menu, or I could go the route THAWA is taking, and convert to the wider track. Rolled fenders seem to take care of most of the rubbing, but you'll need to change control arms, lateral links, and axles.
There is also the possibility of ride height issues. My car is about 3/4" lower, and I'm happy with it. Other people run into other problems, and putting any rear spring not made for a Legacy wagon on one is going to cause a lower rear because they have fat asses.
If you're not interchanging entire strut/spring assemblies, you'll also need to make sure you have the right spring perches for the front springs. Also 05+ STI front struts don't fit without some serious ghetto-rigging because the knuckle/hub/bearing was beefed up.
Old 04-03-2006, 04:40 PM   #10
subydude22
Member#: 108043
97 legacy outback
navy
so if I put some Leg GT stock OR aftermarket springs on my gr2's I will acheive the same ride height as a stock legacy?
subydude22 is offline   Reply With Quote
Old 04-03-2006, 09:41 PM   #11
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Spdracr - can you elaborate on "Step 2 – Front: You will need to re-use the rubber spring spacer from your legacy upper spring mount. You will need to trim it a bit to fit the smaller impreza spring as they are tapered at the top."
My WRX suspension will be here Wednesday. Do I need to remove the front strut tops from the WRX suspension and put this spacer in, or does it just plop in between the top of the tophat and the strut tower?
Thanks,
Ryan
MYfirst00 is offline   Reply With Quote
Old 04-03-2006, 10:18 PM   #12
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
if the strut/spring combo you're installing is already in one peice with the tophat installed you wont need to do anything. jsut take out the legacy one and install the wrx one. if its in peices then you just need to make sure you install the rubber bushing/grommet thingy that goes between the spring itself and the upperspring mount. It helps take up shock and prevents that "clunk" of metal on metal. Hope that makes sense.
Old 04-05-2006, 09:45 AM   #13
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
10-4 captain, loud and clear. My set is already assembled, going in this weekend. I guess I can post pics of the install if I remember to document it. Thanks!
Old 04-14-2006, 07:50 PM   #14
revhigh96
Member#: 60023
Ok so I have a 97 2.5 GT, I want to go over to an adjustable strut but want to keep my same springs, can I just bolt in 02+ WRX struts without any modification? or do I have to also do WRX springs and tophats?
revhigh96 is offline   Reply With Quote
Old 04-03-2006, 10:13 PM   #15
Sleeper20t
Member#: 62824
'06 STI
I was planning on putting 04 STi suspension on my BD, now im a bit afriad. Is this going to mess things up bad in the rear?
Sleeper20t is offline   Reply With Quote
Old 04-14-2006, 08:29 PM   #16
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
Yep, you can mix and match.. just make sure your tophats match the springs.
My new setup is Legacy GR-2's with WRX wagon Springs/tophats vs my current setup "WRX struts/Tein S-Tech wrx springs"...
Old 04-15-2006, 11:46 PM   #17
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Actually that's not wrong. There are spacers, but they're spacers for the other suspension components. There are spacers above the engine crossmember, the front part of a manual transmission crossmember, the outrigger mount, the rear diff crossmember, and other mounts are extended for the extra height. So yes there are spacers, and leaving them in when lowering the car isn't the best way to do things.
THAWA is offline   Reply With Quote
Old 04-26-2006, 01:54 PM   #18
Sleeper20t
Member#: 62824
'06 STI
Im going to bump this real quick.
Im seriously thinking about ordering up AGX and H&R' springs for my legacy today. My friend will be selling his 04 STi suspension soon, and i am considering buying it, although im afraid from what i hear that the rear camber will be whack. Is this true? Do you think i would be better off going after market on this one, even though its going to cost twice as much?
Any opinions will be helpful, thanks
Old 04-26-2006, 01:57 PM   #19
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
Sti stuff wont work.. rear struts are different.. only 02/03 wrx struts will work.
Old 04-27-2006, 05:07 PM   #20
etam
Member#: 439
www
what's the difference? camber? hub attachment? people put 04 sti suspension (completed with tops) on 02/03 and then 02/03 would fit our BD...
etam is offline   Reply With Quote
Old 06-22-2008, 03:14 PM   #21
iluvdrt
Member#: 46248
82 Brat
Tan
I have 04 STi struts on my LGT WGN. They are different, but they bolt on. I had a problem with camber, but adj camber bolts, some strut bolt hole widening, and a rubber mallet on the inner fender gave me the clearance. You cannot tell the inner fender was pushed in either. The strut and under coat hides it. It only had to get bashed in about 1/8" and that was due to the spring seats on the bottom.
Sounds like a lot of work, but it wasnt. I can get -2 degrees in the rear now.
Ride is stiff, and sits about 1/8-1/4 lower in the rear, but not terribly noticeable. Front 04 STi went right in no probs.
I am getting sway bars and end links soon, but it already handles beautifully. hardly no body roll, and a blast at the track.
iluvdrt is offline   Reply With Quote
Old 04-26-2006, 02:05 PM   #22
Sleeper20t
Member#: 62824
'06 STI
Ok, thanks
Old 04-27-2006, 05:14 PM   #23
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
I thought they changed the bolt pattern or somethign like that. when you buy oem and after market stuff its always 02/03 or 04/06 stuff.. I dont know for sure, but it stands to reason that if it works on an 02/03 wrx than it should transfer over..
Old 04-27-2006, 05:18 PM   #24
etam
Member#: 439
www
read jamal's post above... the difference of 02/03 and 04+ is the tapered rear springs and new rear top design... if you match the spring with top, it will fit.. how much camber adjustment? I don't know.
Old 04-27-2006, 10:18 PM   #25
Sleeper20t
Member#: 62824
'06 STI
So i cant use the STi top, but if i put say, BD lowering srings on the STi struts with the legacy tops, then it would work??
WRX Suspension Swap onto BD Legacy Ride Height Issue RallyLegacy Legacy Forum 12 04-03-2012 03:03 PM
Suspension options for '02 WRX suspension-swapped BD mattwalters Brakes, Steering & Suspension 10 12-06-2007 12:32 PM
Three-Way Suspension swap question, menage a toi if you will mattminer Brakes, Steering & Suspension 8 11-28-2006 11:33 AM
FXT To STi Suspension Swap Questions SoyRacer Forester Forum 12 06-30-2004 07:30 PM
STI vs WRX suspension Question IJust8Chris Brakes, Steering & Suspension 26 09-06-2003 09:34 PM
