#1 |
Member#: 54688
Vehicle:1988 XT6 White |
![]() Okay......... So I Received This STi Suspension And Am Curious As To What, If Anything, I Will Need To "Bolt This Into" Our 04 FXT.
Are The Top Hats The Same Front And Back As The FXT ? Do I Just Bolt Them In As-Is, Align It And Go ? Any Advice From The Gurus Would Be Helpfull . Thanks !!!
#2 |
Member#: 2272
BAIC
Vehicle:2025 I5N & ND3 too 1993 Impreza FWD WRX swap |
![]() Im not 100% certain, but you might need to swap the top hats.
Otherwise, its not a hard job at all, just make sure to have a big breaker bar for the bolts on the hub/strut ![]() |
#3 |
Member#: 34056
![]() Hey SoyRacer,
My buddy with XT done same swap few month back. It's plug and play. Just take your stock strut out and put STi one in. Hope you enjoy them, and post up pic when your done. ![]() |
#4 |
Member#: 3102
NESIC
Vehicle:2018 Mazda CX-5 Storm Trooper White |
![]() Just bolt it up, it is the easiest swap going. I loved mine and I'm going to miss it.
There are no modifications required Bry. |
#5 |
Member#: 12065
Vehicle:08 evo x mr wicked white slow pos |
![]() be very careful on the front drivers side,unbolt the sway bar endlink or something.when i did mine,the suspension would not lower enough,i popped out my inner cv joint acouple of times and i tore my outer cv joint boot.what a greasy mess.the two bottom bolts on the front struts,make sure you mark the top ones before you remove anything.
#6 |
Member#: 54604
Vehicle:2004 FXT Cayenne Red (sold) |
![]() Hmm. I didn't need to unbolt the sway bar endlink when I did mine.
Frank |
#7 |
Member#: 54688
![]() I Really Appreciate Everyones Advice But I Think That I'm Going To Wait Till We Can Afford A New Set Of Wheels (17") To Compliment The Suspension, As Well As A Rear Sway Bar Upgrade.
How Is The Ride? The FXT Ride Is Pretty Good At Absorbing Most Road Imperfections. What Is It Like WIth The STi Suspension? Thanks Again !! |
#8 |
Member#: 53021
SCIC
Vehicle:'04 Forester - sold '72 Datsun 240Z |
![]() Um, be prepared for an entirely different car. I hated the stock FXT suspension; once the STi bits were installed, I could actually test the handling limits of the car. Don't bother waiting for wheels and tires, do the swap first and see what you think. Adding the rear bar makes less of a difference with the STi setup vs the stock mushy suspension. Once you get used to the suspension, get your wheels and tires and kick it up to a whole other level.
#9 |
Member#: 18861
TXIC
Vehicle:2020 STi WR Blue |
![]() Granted, this isnt an XT....but here is the link to my TXIC post right after I did it to my Wife's X. (17"s)
http://forums.nasioc.com/forums/show...hreadid=576752 Scott |
#10 | |
Member#: 25215
![]() Quote:
How are you liking the set up? |
#11 | |
Member#: 25215
![]() Quote:
#12 | |
Member#: 54604
![]() Quote:
Frank |
#13 |
Member#: 25215
![]() excellent! I am glad you are pleased with them.
Will '05 STI crossmembers (both) fit a '00 GM6 + suspension swap questions | kumanchu | Subaru Conversions | 4 | 11-09-2009 01:37 AM |
wrx to STi suspension swap | haloseven | Texas Impreza Club Forum -- TXIC | 10 | 11-04-2007 09:44 AM |
wrx to sti intercooler swap question? | wade869 | Subaru Conversions | 4 | 08-15-2007 12:01 PM |
WRX to STI Tranny swap question | Highway Drifter | Transmission (AT/MT) & Driveline | 3 | 03-04-2007 02:30 PM |
JDM 03 STi suspension swap to WRX 01 Wagon | Blue Dragoon | Subaru Conversions | 1 | 11-06-2006 11:10 AM |
