Welcome to the North American Subaru Impreza Owners Club Thursday October 3, 2024
Old 03-08-2011, 01:48 PM   #301
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
Can wrx sedan struts be used for a wagon if wagon springs are used?
Thread gets confusing, then i feel like i got it.then i dont.
PMDSOA is offline   Reply With Quote
Old 05-11-2011, 10:22 PM   #302
MNWagon
Member#: 282411
This might be off-topic, it depends on the meaning of "complete WRX suspension swap".
My 97 GT wagon is mechanically wore out but the body still looks great. Is it feasible to swap the entire drivetrain and suspension from a '02 WRX donor onto this body?
What does feasible mean to me? No welding and less than 100 hours of labor.
Thanks
MNWagon is offline   Reply With Quote
Old 05-12-2011, 04:31 AM   #303
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
yeah you can, but not sure why. the 02 wrx has the weakest tranny of any subaru.... ever! as far as axles and stuff, might as well just get new legacy stuff.
spdracr00 is offline   Reply With Quote
Old 05-12-2011, 07:49 AM   #304
MNWagon
Member#: 282411
Originally Posted by spdracr00 View Post
... might as well just get new legacy stuff.
The problem is I need everything - rebuilt engine, rebuilt tranny, bushings, bearings, ....
Is there a better donor car to give the old wagon another 5 years of fun?
Old 07-31-2011, 02:49 PM   #305
John93
Member#: 264032
2012 wrx
white
so can i use the 02/03 wrx sedan suspension on my 98 ob wagon or would i be better off geting an 02/03 wrx wagon suspension for it. the only reason i ask is because i have the wrx sedan suspension from my buddies part out of his car with is an 02 wrx, and yes i know it says sedan to sedan and wagon to wagon but im just double checking. thank you
John93 is offline   Reply With Quote
Old 07-31-2011, 04:11 PM   #306
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
you can totally use the 02/03 sedan stuff. might even be able to get more camber in the rear, or maybe too much depending. the big thing is that the sedan springs are shorter in the rear so you'll get more of a saggy butt look, but some strut spacers like from primitive racing will help level it out and give you an even look. that's what i did on my forester when i lowered it on 2.5rs stuff.
Old 08-05-2011, 09:29 AM   #307
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
Thanks spdrcr, that cleared it up
Old 08-05-2011, 04:02 PM   #308
Azlegacy
Member#: 279837
The wrx suspension is a way better option than the legacy . It's a sports suspension as the legacy is not. I'll be picking up a set soon for my wagon along with saggy butt spacers.
Azlegacy is offline   Reply With Quote
Old 08-19-2011, 02:21 PM   #309
MAXSUBARU
Member#: 265444
06 WRX
any good options for the first gen legacys??
throw on some ground controls or platform specific coilovers seem to be the only options =[
MAXSUBARU is offline   Reply With Quote
Old 08-19-2011, 03:33 PM   #310
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
best thing and cheapest. 2.5rs stock struts/springs. otherwise you can use any impreza suspension. you just need to swap out the front upper spring perches if you're gonna reuse your legacy parts.
not the best pic, but here's my 91 rallycrossing on stock 2.5rs suspension.
Old 08-19-2011, 04:36 PM   #311
MAXSUBARU
Member#: 265444
06 WRX
so could i use racelands with the tophats from my first gen wagon?
Old 08-19-2011, 06:33 PM   #312
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
sure, that should work with what you already have.
Old 08-22-2011, 12:28 PM   #313
MAXSUBARU
Member#: 265444
06 WRX
do you have a pic of the actual suspension??
i see the racelands for the 02-07 wrx
and i wana fit them on a 94 and or 96 wagon
im just not sure if they would be a direct swap or
id just have to change the tophats and throw them on?
sorry for all the questions this is all new to me
Old 08-22-2011, 12:53 PM   #314
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
do the racelands come with camber plates? cause if they do, just throw them on. if they don't you'll need to reuse your stock rear strut tops.
Old 08-22-2011, 01:05 PM   #315
MAXSUBARU
Member#: 265444
06 WRX
oh its only the rears that are different? no racelands dont have camber plates in the rear
so ill just have to change the tophats on the rears then? sick!
i just didnt realize the subaru suspensions were so compatible
too bad i couldnt just use cx racing coils from the 02+ legacy cus they are only 650
Old 08-22-2011, 07:55 PM   #316
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
there's a good chance those 02+ wrx rears will bolt up just fine. even though there are two styles of strut tops the bolt pattern is the same. but thats really only an issue when swapping springs.
Old 08-24-2011, 01:20 PM   #317
MAXSUBARU
Member#: 265444
06 WRX
sick then i should just need some camber bolts and get it all aligned right?
Old 08-24-2011, 05:15 PM   #318
240benzo
Member#: 292412
1997 Legacy Wagon
Green
getting a set of 02 wrx raceland coils to throw on my 96 legacy
thanks soo much for this thread! now i know i wont have to modify anything =D
240benzo is offline   Reply With Quote
Old 08-24-2011, 05:52 PM   #319
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
ill throw this up there
i am running 04 wrx struts/prodrive springs on my 96 legacy they mount perfect
and the 96 legacy struts/springs mount up perfect on my girls 98 forester
maybe this helps someone
thegonz is offline   Reply With Quote
Old 08-24-2011, 11:54 PM   #320
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
yeah the foresters all use 02+ impreza suspension.
Old 09-24-2011, 12:43 AM   #321
Azlegacy
Member#: 279837
Any more side views of 2.5rs suspension on a legacy?
Old 09-24-2011, 10:55 AM   #322
240benzo
Member#: 292412
1997 Legacy Wagon
Green
racelands
Old 10-11-2011, 10:42 PM   #323
integra_drk
Member#: 117907
95 Legacy Wago
Didnt see this question in here anywhere but is there a difference with 95-96 legacys compared to 97-99 as far as suspension wise and using components from a wrx? Im hopefully picking up this 95 wagon tomorrow and just want to know what route Ill have to go to drop it. Thanks!
integra_drk is offline   Reply With Quote
Old 10-11-2011, 11:53 PM   #324
Azlegacy
Member#: 279837
No not that I have ever heard of. Post pics of ur wagon here tomrw! Congrats. I have a '95 L wagon .
Old 10-13-2011, 02:18 PM   #325
240benzo
Member#: 292412
1997 Legacy Wagon
Green
just ordered some racelands for my 96
hopefully i can get the bolts broken loose ha
should be here by monday =]
WRX Suspension Swap onto BD Legacy Ride Height Issue RallyLegacy Legacy Forum 12 04-03-2012 03:03 PM
Suspension options for '02 WRX suspension-swapped BD mattwalters Brakes, Steering & Suspension 10 12-06-2007 12:32 PM
Three-Way Suspension swap question, menage a toi if you will mattminer Brakes, Steering & Suspension 8 11-28-2006 11:33 AM
FXT To STi Suspension Swap Questions SoyRacer Forester Forum 12 06-30-2004 07:30 PM
STI vs WRX suspension Question IJust8Chris Brakes, Steering & Suspension 26 09-06-2003 09:34 PM
