Welcome to the North American Subaru Impreza Owners Club Thursday October 3, 2024
Old 10-14-2011, 01:57 PM   #326
integra_drk
Member#: 117907
95 Legacy Wago
Originally Posted by Azlegacy View Post
No not that I have ever heard of. Post pics of ur wagon here tomrw! Congrats. I have a '95 L wagon .
Was a pile of **** so I didnt end up getting it haha. Still on the hunt for a clean specimen!
integra_drk is offline   Reply With Quote
Old 10-14-2011, 11:43 PM   #327
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Question
There is a lot of stuff in this thread and clearly some folks put in some time and effort. That said, my take-away from it is that the WRX sedan to Legacy sedan swap is great and the wagon to wagon not so much. However, based PMs exchanged with several guys who've lowered BG Outbacks with WRX wagon stuff they all seem pleased with it. Am I missing something? It also seems that WRX or STi rear struts allow keeping the stock Outback size rear tires while going with regular Legacy struts requires requires a 205/55-16 or equivalent to clear the rear spring seats. After owning it since new, I finally want to lower my '97 LOB and with what I know right now, my cost matters ideal would be a complete low mileage '07 WRX wagon take-off set...
Doug
dvancleve is offline   Reply With Quote
Old 10-15-2011, 04:41 AM   #328
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
there isn't really anything "wrong" with a wagon to wagon swap, it just looks like you have a saggy rear end, even though you really don't. That's all due to subaru's bigger front fenders. you can now get saggy butt spacers from places like Primitive Racing to help even out the gaps. just remember sedan rear springs are shorter and have a softer spring rate, so always keep wagon to wagon, sedan to sedan.
spdracr00 is offline   Reply With Quote
Old 10-23-2011, 03:35 AM   #329
outbeezys11
Member#: 294312
Can you use 02 wrx wagon springs with 99 legacy outback struts?
outbeezys11 is offline   Reply With Quote
Old 10-23-2011, 02:07 PM   #330
Azlegacy
Member#: 279837
Anyone have pics of stock wrx suspension on Legacy L model with srock 14" wheels? The closest I have seen was the outback above but they have a 75 series tall tire on.
Azlegacy is offline   Reply With Quote
Old 10-23-2011, 05:08 PM   #331
granny
Member#: 283145
1997 LEGASTi Wagon
Instagram-@grannywagon
Legacy
How much will wrx suspension lower a 97 legacy L?
granny is offline   Reply With Quote
Old 10-23-2011, 06:07 PM   #332
dvancleve
Member#: 5211
Question
I have not found any instances of somebody admitting they tried this or any pictures, but it should work. The pre-03 WRX springs are not tapered, so it should be possible to just replace the OB springs with the WRX springs and reuse everything else (or put in new OB KYBs and reuse the rest). If you try this, please report back and include some pictures. It seems like this should lower an OB, just not sure how much... Doug
Old 10-24-2011, 01:37 PM   #333
dvancleve
Member#: 5211
Question
Is there consensus on what spacer thickness makes things look even? I am pretty much locked in on getting either a complete WRX wagon take-off set or everything but the struts themselves and getting KYB GR-2/Excel-Gs. Obviously, it would be best to do the swap then drive it a while before measuring, but it would sure be nice to avoid pulling the rears twice if I can just order the correct thickness spacers first...
Thanks, Doug
Old 10-27-2011, 02:29 PM   #334
240benzo
Member#: 292412
1997 Legacy Wagon
Green
i put on 16" rs wheels but still stock wheels with wrx coilovers
nothing modified-straight simple swap
240benzo is offline   Reply With Quote
Old 10-29-2011, 06:12 PM   #335
Azlegacy
Member#: 279837
Damn it looks low. I want it a bit taller. Makes me second guess getting this set up. I want to be able to go off road and not worry about scraping.
Old 10-29-2011, 06:28 PM   #336
dvancleve
Member#: 5211
Lightbulb
[IMG]http://farm7.static.flickr.com/6098/6284418844_be9c5954e2_b.jpg[/IMG
Notice, 240benzo says they are WRX coilovers. I assume the car is lowered a lot, looks like it to me... Doug
Old 10-30-2011, 11:01 PM   #337
240benzo
Member#: 292412
1997 Legacy Wagon
Green
true. stock struts wouldnt reallly be much different than legacy stocks
these coils are for a wrx and i had to extend them out alooot from the bottom mounts just to fit right
i can easily go like 4" lower if it were something reasonable to do ha
in this pic of the rears im about 1.5" lower than this and all the way up in the front
Old 11-01-2011, 07:59 PM   #338
Djdownfall43
Member#: 292156
I have Koni's with GT springs on mine,
Sorry just throwing what I have out there.
Djdownfall43 is offline   Reply With Quote
Old 11-03-2011, 01:14 AM   #339
dvancleve
Member#: 5211
Going way back to this vintage post on spring rates: http://forums.nasioc.com/forums/show...&postcount=128. If I assume Outbacks had similar spring rates to same year Legacy wagons (132 F, 190 R) or at least a similar front to back balance, going to WRX wagon springs will result in a much lower spring rate in back (132 man, 144 auto). STi springs would be a better match with 194 lb/in in back. Any thoughts on any of this? I assume that the stock Legacy wagon springs are stiffer in back for load carrying rather than for any handling related reason and that the STi springs are the way they are (224 F, 194 R) for handling reasons. Not sure how the WRX wagon ended up with 163 F, 132/144 R other than it is a bit stiffer than the sedan in back...
Doug
Old 06-01-2012, 03:44 AM   #340
ivanwakeup
Member#: 321899
ok, kind of bringing this back from the dead but i just want a definitive answer, i've found a lot of conflicting info:
i have a 99 outback limited wagon
this is i think i'm pretty certain of so far:
-02-03 wrx struts and springs absolutely fit with no problem
-is it the same for 04-07 wrx as well? would those springs/struts also fit with no modification?
thats pretty much it though. my other questions are:
-can i just buy a coilover meant for the 02-07 wrx and have it fit perfectly? this would be the best thing for me if possible
-does the 92-01 impreza stuff fit at all? it sounds like no to me at this point but i want to be sure.
-what other options do i have?
i pretty much want to go as low as possible while still having the car be DDable.
thanks for the help!
ivanwakeup is offline   Reply With Quote
Old 06-01-2012, 08:21 AM   #341
98legwag
Member#: 160325
09 Legacy 3.0R
Make sure you get top hats to fit what ever year spring you are using. That is where the differences are.
98legwag is offline   Reply With Quote
Old 06-01-2012, 08:23 AM   #342
98legwag
Member#: 160325
09 Legacy 3.0R
Here is my 98 L on 17s with 205/45/17 with 02 wrx GR2s and springs. Rolling diameter is very close to what it is with the stock 14s.
The front is about a 1/4 in lower and the back is about 1/2 in lower. The front has settled a little more than in that picture which was after about 40 miles of driving so it could be more than 1/4 in lower now.
Old 06-01-2012, 02:03 PM   #343
ivanwakeup
Member#: 321899
so if i were to get coilovers even for a 93-01 impreza, they would fit (because a coilover is all 1 assembly anyway)? based on what i was reading it was looking like they WONT fit, but now you have me second guessing.
would 02-07 wrx coilovers just be a direct swap-in?
or do i need to use my OB top hats on whatever suspension setup i get?
Old 06-01-2012, 09:08 PM   #344
98legwag
Member#: 160325
09 Legacy 3.0R
If you use the wrx top hats they need to be switched side to side. Left on the right and visa verse. 02-07 wrx should bolt right in. I got my info from www.sl-i.net
Old 06-01-2012, 09:13 PM   #345
ivanwakeup
Member#: 321899
sweet so if i just bought a set of wrx 02-07 struts and springs rather than coilovers they would just bolt up with my OB top hats?
Old 06-02-2012, 01:15 PM   #346
98legwag
Member#: 160325
09 Legacy 3.0R
Im not 100% sure about using the OB top hats. I used the wrx top hats. SLI will have a lot more info.
Old 06-03-2012, 02:49 AM   #347
Azlegacy
Member#: 279837
If you use wrx suspension, use the complete assembly including tophat. They fit.
Old 06-03-2012, 04:48 AM   #348
ivanwakeup
Member#: 321899
do you know if the OB tophats would work though? i only ask because i'm buying aftermarket stuff (not OEM wrx struts/springs) so i wont have the top hats for the wrx- i'd have to source them from elsewhere.
Old 06-03-2012, 09:23 AM   #349
98legwag
Member#: 160325
09 Legacy 3.0R
According to this your top hats work, but it was a sedan:
http://sl-i.net/FORUM/viewtopic.php?t=3405
Old 06-03-2012, 12:34 PM   #350
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
Ok, it's really simple. The front strut top is the same on every Subaru from 1990-2007. You will just need the smaller impreza upper spring perch. (metal dish looking thing) The rear's will require matching strut tops to whichever year WRX springs you're going to use. either 2002-2003 style or 2004-2007 style depending on which springs you're using.
WRX Suspension Swap onto BD Legacy Ride Height Issue RallyLegacy Legacy Forum 12 04-03-2012 03:03 PM
Suspension options for '02 WRX suspension-swapped BD mattwalters Brakes, Steering & Suspension 10 12-06-2007 12:32 PM
Three-Way Suspension swap question, menage a toi if you will mattminer Brakes, Steering & Suspension 8 11-28-2006 11:33 AM
FXT To STi Suspension Swap Questions SoyRacer Forester Forum 12 06-30-2004 07:30 PM
STI vs WRX suspension Question IJust8Chris Brakes, Steering & Suspension 26 09-06-2003 09:34 PM
