06-03-2012, 06:38 PM | #351 |
Member#: 321899
alright guys, thanks much for the help! i think i'll just be getting 02-03 wrx suspension
07-02-2012, 09:41 AM | #352 |
Member#: 323439
Vehicle:2001 Outback 2004 Forester XT |
So someone help me, what's all th bg, bc, gg, gc and every other letter combination mean? If got a 2001 outback , base line w/ the winter package and I'm trying to modify it to how ever I want. Just trying to do some homework and figure everything out that I can. Mines a 2.5l with an automatic. I guess I should have done this before and went for an impreza vs an outback. Any help would be great, thanks all.
07-02-2012, 02:11 PM | #353 | |
Member#: 160325
Vehicle:09 Legacy 3.0R SWP |
07-02-2012, 04:51 PM | #354 |
Member#: 323439
Ok, is there any suspension set ups that will work for my ride? Thanks for helping me out, now I know u have a bh.
07-02-2012, 08:11 PM | #355 |
Member#: 323439
Oops, I have a bh. So any front will work then if I have the whole strut, spring and tophat.
07-02-2012, 08:24 PM | #356 |
Member#: 323439
Ok another question, since my rear suspension is different, can I swap the rear sub-frame with something better that's a direct bolt up? It's not easy finding the rear parts. Mines stock and just about wore out, time for modifying.
07-03-2012, 05:59 AM | #357 |
Member#: 323439
So from this whole thread I've figured out I have a third generation and from all these posts every either has a first or second gen. So what gives. I will figure something out, even if I have to custom make my own rear suspension.
07-04-2012, 01:48 PM | #358 |
Member#: 5211
SWIC
Vehicle:2007 Outback XT Ltd. Diamond Gray Metallic |
I don't know for sure, but it seems to me that suspension parts from an '08 or newer Impreza model would work without too much difficulty. I know the Forester guys use multilink STi rear suspension bits on their cars...
Doug |
07-04-2012, 02:04 PM | #359 |
Member#: 65823
NWIC
Vehicle:2018 Impreza Sport Pearl White |
07-05-2012, 07:28 AM | #360 |
Member#: 323439
My end goal, not for sure. This is my first ever import and I just want to see how far I can go. For looking at the pics online of the 08+ impreza and foresters, the third gen outbacks have different length lateral bars and a shock vs strut.
The car is due to a bushing change and I would like urathane over rubber ones. I like taking corners fast. The second and thirds rear body looks the same that's why I asked about swapping out rear subs to the second if the mounts match up. I just made the start of a cold air kit the other night and put it on. Next plan is tune up, then exhaust. From there I'm looking at suspension and engine. Thanks for the help and I will keep digging and learn more. |
07-05-2012, 10:45 AM | #361 |
Member#: 65823
NWIC
well to start with you have a 3rd gen legacy. the only other subaru's that share your rear setup are the 09+ foresters, 08+ impreza's. they are not exactly the same as the 2000-04 legacy's use a narrower rear lower control arm, so if you get anything other than 00-04 suspension you'll need to shave down the lower mounting point. Your best bet is to get a suspension that's made for your car. you have quite a few options in fact. You have the fattest Subaru made, so trying to use srings/struts from another car will not work to well.
07-06-2012, 11:03 PM | #362 |
Member#: 323439
So having a fat ass means I can take corners faster right? Just kidding. Well I'm all ears. Point me to the right direction of who makes parts for my car.
08-13-2012, 12:24 PM | #363 |
Member#: 192815
Vehicle:2003 Outback Regatta Red Pearl |
I've got an 03 outback from what I've found you can get jdm b4 bilstine for around 500$ on eBay they will be used but jdm parts are normally low mileage, h&r makes one or two lowering spring kits if you just want to lower your stance. Best bet to really lower a bh chassis is to use be suspension parts there are a few companies that make full coil over kits I know tein, kw, super stance, bw,k sport, d2racing, xyz sport, yellow dps... You get the picture. Keep in mind if you're wanting a coil over kit plan on spending atleast a grand on the cheapest one.
05-20-2013, 03:38 PM | #364 |
Member#: 307775
NWIC
Vehicle:1997 Legacy |
Hey can anyone tell me if I order suspension for 99 legacy if it will fit my 97
05-20-2013, 03:46 PM | #365 |
Member#: 199333
97 what? Legacy? 96-99 legacy/outback parts are interchangeable although outback is higher. all subies have the same top mount holes in body and bottom strut mount to spindle from 95-05 wrx/legacy/forester/outback/impreza/wrx. thats why people call them lego cars. ex; my 95 legacy L wagon has 03 wrx suspension/lowering springs, direct bolt in if you take everything from top to bottom mounts, except the brake line mount bracket on strut.
05-20-2013, 05:40 PM | #366 | |
Member#: 160325
05-21-2013, 10:58 AM | #367 |
Member#: 199333
Well there are exceptions, thanks for the correction.
05-31-2013, 11:27 PM | #368 |
Member#: 355734
Vehicle:97 legacy |
how difficult would a control arm swap from a wrx to a 1997 legacy be? and what model wrx would give me the best results?
12-08-2013, 04:01 PM | #369 |
Member#: 328326
Vehicle:2018 WRX Lapis Blue |
Hey guys, I can get a killer deal on Ksport coilovers that came out of an 02 legacy, anyone know if they will fit into an 03 WRX wagon? I know Subarus are like legos but I wanna make sure so I don't buy anything that won't fit.
12-08-2013, 09:04 PM | #370 |
Member#: 65823
NWIC
Front will work, but in 2000 the Legacy's all went to a multilink rear setup.
07-28-2014, 01:00 PM | #371 |
Member#: 373261
Vehicle:2015 Forester XT SWP |
I want to thank you guys for all the info contained in this thread. It's been awhile since there's been any posts, but I used all the info to get my 1999 Legacy SUS sitting pretty on 2005 WRX suspension and 2007 WRX wheels. So thanks again for this thread!!!
08-25-2014, 01:28 AM | #372 |
Member#: 393554
Vehicle:1997 Legacy L Silver |
I swapped my 97 legacy with 07 wrx struts and springs. Its not much lower but it still rides nice and looks good i think at least!
12-02-2014, 10:57 AM | #373 |
Member#: 407635
Vehicle:1997 legacy gt wagon green |
1997 legacy gt wagon suspension upgrades
I have a 97 LGT wagon (with blown struts) and I have a buddy that has Tien H springs on 2005 wrx struts I know that the only year that my legacy is capable of swapping suspension into is 02-03 wrx. he said the struts would work on a bug eye which is the 02-03. Is this true?
12-02-2014, 10:58 AM | #374 |
Member#: 407635
12-02-2014, 11:09 AM | #375 | |
Member#: 388083
RMIC
Vehicle:1997 Legacy Outback Red |
Yes, it will work. 02-07 WRX suspensions are all compatible. Also, I have a 97 outback limited with 04 wrx struts and Tein springs, all I did was swap the top hats and then it was a simple strut replacement. Sent from my iPhone using NASIOC |
WRX Suspension Swap onto BD Legacy Ride Height Issue | RallyLegacy | Legacy Forum | 12 | 04-03-2012 03:03 PM |
Suspension options for '02 WRX suspension-swapped BD | mattwalters | Brakes, Steering & Suspension | 10 | 12-06-2007 12:32 PM |
Three-Way Suspension swap question, menage a toi if you will | mattminer | Brakes, Steering & Suspension | 8 | 11-28-2006 11:33 AM |
FXT To STi Suspension Swap Questions | SoyRacer | Forester Forum | 12 | 06-30-2004 07:30 PM |
STI vs WRX suspension Question | IJust8Chris | Brakes, Steering & Suspension | 26 | 09-06-2003 09:34 PM |
