Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 06-18-2018, 12:25 AM   #1
DirtyBugeye02
Member#: 431475
2002 Impreza WRX
Default Force Readiness Accessport Question
Hey guys,
was wondering if anybody could help me out with this.
I have a 2002 WRX that is protuned with the Cobb Accessport. Before that it was open sourced tuned with Romraider by the PO, which utilized the force readiness function. The issue I have is that the PO took out the downstream 02 sensor, so I have multiple "Not ready" monitors. This obviously makes inspection a pain in the ass.
I understand there is a way to Force ready through the accesstuner software? My tuner didn't seem to want to help me out here, so I was wondering if somebody with the software could lend me a hand. Is it a possibility that if I emailed my map (assuming it's not locked) to somebody with the software, they could force readiness for me?
Thanks,
Mike
DirtyBugeye02 is offline   Reply With Quote
Old 06-24-2018, 05:25 AM   #2
DirtyBugeye02
Member#: 431475
2002 Impreza WRX
So Iím assuming this is something Cobb took away then, I havenít seen anything about it within the forums in the past 4 years
Old 06-24-2018, 11:04 AM   #3
PVNRT
Member#: 483821
2004 WRX 2.0 18g
Looks like they stopped releasing the software to the general public around 2016. Now you have to take a $149 efi class before you can download it. It used to be free and easy to get.
Its as simple as checking a box and reflashing, but you need the software.
This is also a 30 second fix in Romraider but then you need a whole new map.
You probably need to beg a tuner in person to do you a quick favor make sure your current tune isn't locked otherwise you need to back to same tuner.
Hopefully a nasioc user has this software and will do you a solid.
PVNRT is offline   Reply With Quote
Old 06-24-2018, 07:44 PM   #4
JarHarms
Member#: 138994
06 WRX Ltd
Forced readiness went away when regulatory agencies applied legal leverage over aftermarket flash MFRs. I guess our small 1% moddified community is really impeeding their air quality purification.
Old 06-28-2018, 08:39 AM   #5
DirtyBugeye02
Member#: 431475
2002 Impreza WRX
Thanks for the information info guys, so force ready is no longer an option in the Cobb software, correct? My plan was to see if someone on here with the software would check that force ready box for me.
