Welcome to the North American Subaru Impreza Owners Club Thursday November 15, 2018
Old 06-30-2011, 05:47 PM   #1
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
Default clutch stuck to the floor, not sure what to try.
I read a couple posts that say a couple of things could be wrong if the clutch pedal is stuck in but can be pulled out by hand. The fork looks ok and is in position, i dont know how a slave cylinder should feel but that was going to be my first try. However, when i push the clutch ALL the way to the floor i hear a pretty loud noise coming from the tranny. Leads me to believe its not just the slave cylinder. Any ideas or things i could try?
Also the car was always pretty hoppy trying to get into first gear from a stop. I have an aftermarket clutch put in.
b0nd18t is offline   Reply With Quote
Old 06-30-2011, 05:58 PM   #2
dsmtweaker
Member#: 265405
2013 Audi
Might want to ask in the proper forum. http://forums.nasioc.com/forums/forumdisplay.php?f=55
But my advice would be what you have already said. Its a common simptom you find when the slave cylinder goes bad.
dsmtweaker is offline   Reply With Quote
Old 06-30-2011, 07:00 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
agree that typically this is the symptom of a bad slave cylinder....
Old 07-01-2011, 01:04 AM   #4
tstevensWrX
Member#: 269681
Not only could it be a bad slave cylinder but I'd check your Master Cylinder as well. When I had a clutch stick to the floor it ended up being the Master Cylinder but I had to replace the Slave shortly there after. Check both
tstevensWrX is offline   Reply With Quote
Old 07-01-2011, 01:55 AM   #5
z
Member#: 41762
04 STi
in ur Floriduh
have a friend step on the clutch while you watch the action on the slave.
(top of the trans, inside the engine bay.... under the intercooler)
Is the piston being pushed out of the slave and pushing the clutch release fork forward?
If the piston isn't being pushed out, it's the slave, or master or somewhere in between. If the slave has failed, most likely you'll see brake fluid coming out of it.
z is offline   Reply With Quote
Old 07-01-2011, 08:05 AM   #6
xrturbo
Member#: 86298
98 LGT Wagon
Full WRX driveline & dash
Was anything done prior to this? Normally they won't just fail out of nowhere. Don't forget the obvious and check the fluid level and try to bleed it out before replacing parts.
xrturbo is offline   Reply With Quote
As an IT guy, I receive emails like this all the time. Not sure what to do with them plunk10 Off-Topic 55 02-24-2011 01:33 PM
Steer me in the right direction..Not sure what to do next? BuGiReX21 Newbies & FAQs 32 11-22-2010 11:26 PM
So the time has come to get new brakes, but not sure what to get - HELP! DJS_02_WRX Newbies & FAQs 31 12-30-2009 01:53 PM
Argh. Clutch slippage (not too bad, but not sure what to do) RaceTM Transmission (AT/MT) & Driveline 3 09-21-2009 03:39 PM
Not sure what to make this title called so I'll just make the title really long -=C=- Off-Topic 21 07-28-2005 09:42 PM
