![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
Member Sales Rating: (45)
Member#: 187877
Vehicle:04 FXTi |
![]() 2005 Saab 9-2X Aero 128k Miles Part Out
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask. Engine & Drivetrain EJ257 Short Block (Spun Rod Bearing) $400 EJ205 Cylinder Heads - Supertech Valves, Retainers and Springs (30k miles) $800 Cosworth Camshafts (30k miles) $600 OEM Cam Gears $50 STi Cat Back Exhaust $200 Invidia N1 Street Cat Back Exhaust $200 Catless Downpipe (Slip on style/No flange for cat back) $75 ACL Streetlite Flywheel $100 Walbro 255 LPH Fuel Pump $50 800cc Injectors $200 Intake Manifold $100 Throttle Body $50 Top Feed OEM TGV Deletes $100 Coil Packs $100 Radiator Fans $25 each Coolant Expansion Tank $35 Coolant Crossover Pipe $35 5 Speed Transmission $500 Shifter Assembly $50 Rear Differential $100 Axles $75 Driveshaft $100 Engine Crossmember $100 Transmission Crossmember $50 Rear Crossmember $100 Rear Differential "T" Crossmember $100 Alternator $100 STi Steering Rack #34110FE580 $250 Power Steering Reservoir $25 AC Compressor $100 AC Lines $25+ AC Condenser $50 Washer Fluid Tank $25 Clutch Master Cylinder $35 Clutch Slave Cylinder $30 Clutch Fork $20 Clutch Fork Rod $20 Wiper Motor & Linkage $40 Purge Valve $20 Purge Solenoid $20 Charcoal Canister $40 Cruise Control Actuator $40 Rear O2 Sensor $35 Front 02 Sensor $50 Top Feed Fuel Rails $50 Fuel Pump Controller $50 Fuel Pump Hanger $50 OEM Boost Controller $20 Boost Controller Bracket $10 Outer Timing Covers $15 Killer B Radiator Shroud SOLD Killer B Alternator Cover SOLD Group N Tranny Mount SOLD Group N Pitch Mount SOLD Group N Motor Mounts SOLD PTP Turbo Blanket Lava SOLD Invidia Catless Downpipe SOLD STi TMIC with Mishimoto Hose SOLD Cusco Turbo Heat Shield SOLD Cobb AP v2 001 Unmarried (02-05 WRX) SOLD ARP Head Stud Kit SOLD Gimmick Inlet SOLD Tomioka TD06-20G SOLD Tomei JDM UEL Header & Uppipe SOLD Radiator SOLD Mass Air Flow SOLD Power Steering Pump SOLD Power Steering Lines SOLD Power Steering Pump Bracket SOLD Engine Harness SOLD Bulkhead Harness SOLD ECU SOLD Perrin Ram Air Intake SOLD Inner Timing Covers SOLD Suspension, Wheels, Tires & Brakes BC Coilovers $500 Rota DPT 17x8" +48 5x100 & 5x114 Bronze $400 Saab Enkei 16x6.5" +55 5x100 Silver $400 Subaru Baja Wheels 16x6.5 +48 with 215/65 Winter Tires $300 Adjustable Front Lateral Links & OEM Rears $100 Knuckles $75 Control Arms $50 Trailing Arms $40 Front Calipers $75 Front Rotors $25 Rear Calipers $50 Rear Rotors $25 ABS Sensors $25 Brake Master Cylinder $25 Brake Booster $50 Proportioning Valve $20 Kartboy Front & Rear Endlinks SOLD Cobb 25mm Front Sway Bar SOLD Cobb 25mm Adjustable Rear Sway Bar SOLD Cobb Rear Sway Bar Mounts SOLD ABS Module SOLD Exterior Taillights $75 Hood $150 Scoop $50 Doors $150 Mirrors $50 Fenders $100 Front Bumper $200 Front Bumper Beam $50 Rear Bumper $200 Rear Bumper Beam $50 Hatch $200 Side Skirts $100 Chassis $500 WRX Wagon Roof Rails $75 Thule Fairing #770055 $50 Grille $50 Gas Lid $20 Wiper Arms $30 Rear Wiper Assembly $30 Trim & Weather Stripping $10+ Fog Light Surrounds SOLD Fog Lights SOLD Tow Hook Cover SOLD Headlights SOLD WRX Wagon Crossbars SOLD Interior 06 WRX Front Seats $400 06 WRX Rear Seats $100 Perrin Adjustable Short Shifter $50 Ostrich Skin Door Cards $100 OEM Door Cards $100 Carpet $100 Dash $100 Glovebox $50 Gauge Cluster 128k Miles $150 ProSport 52mm Oil Pressure Gauge Green/White (New) $40 OEM Front Speakers $25 Infinity Bass Link 200 watts 10" Subwoofer $150 Cluster Surround $20 Steering Column $75 Ignition with Key $50 HVAC Controls $40 Window Motor $25 Door Harness $25 Headlight Switch $25 Wiper Switch $25 Fog Light Switch $10 Hazard Switch $10 Mirror Switch $15 Master Switch $35 Window Switch $10 E-Brake Handle $30 Clock & Trim $45 Cup Holder $20 Rear View Mirror $25 Map Light $25 Dome Light $20 Rear Hatch Light $20 Visors $40 Clutch, Brake & Gas Pedals SOLD Shifter Bezel & Boot SOLD Heated Seat Switches SOLD Pioneer Double Din Head Unit AVH-P4200DVD SOLD Composite Shift Knob SOLD Center Console SOLD Radio/HVAC Trim SOLD Ebrake SOLD Boston Acoustic Rear Door Speakers With Adapters SOLD ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#3 |
Member#: 187877
Vehicle:04 FXTi |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() EJ257 Block, EJ20 Heads & Camshaft Pictures: https://img.nasioc.com/album/uv5D/?sort=date_asc&page=1 More Pictures: https://img.nasioc.com/album/uFZQ/?sort=date_asc&page=1 Last edited by BlobeyeSTi; 03-02-2021 at 02:04 AM. |
