08-31-2005, 10:31 PM | #1 |
Member#: 57891
Vehicle:2005 9-2x Aero Black |
Mis-timed and now does not fire
The car: 1997 Impreza OBS 2.2L SOHC.
I was replacing my timing belt tensioner rod and pulley and accidentally replaced the belt (new from 5k ago) over the crank/cam improperly aligned. Car started and sputter but kept running rough till I shut her down. I'm quite certain this motor with the older 2pc tensioner and pulley is non-interference. Re-did the belts but now she does not fire, cranking is strong though. I removed the spark plugs and they were wet with fuel, now do I only have a flooded engine that I can leave overnight, replace the plugs and good to go?
08-31-2005, 10:52 PM | #2 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Check to make sure you have the crank sensor plugged in. It's right above the oil pump. And make sure the maf is also plugged in.
09-01-2005, 12:53 PM | #3 |
Member#: 57891
The crank sensor and MAF plugs were not removed and they are sitting tight. I hope it's just a case of fuel fouled plugs.
09-01-2005, 12:57 PM | #4 |
Member#: 6486
I'd probably double check the timing belt one more time.
09-01-2005, 05:55 PM | #5 |
Member#: 57891
Thanks tim, I've checked the timing belt again and the crank gear has the notch at 12 o'clock, arrow at 3 o'clock. The cam gears both have their notches pointed at 12 in line with the plastic cover notches and arrow at 1 o'clock positions.
For the belt I place it with the three white lines on the belt lined up with the notches on the crank and cam gears. Arrow on the belt is pointed right when seen from the front of the car. Getting new plugs and firing her up tonight. Keeping my fingers crossed. |
09-02-2005, 01:03 AM | #6 |
Member#: 57891
Well tried with fresh plugs, still wouldn't start. I floored the throttle between starts to stop the fuel flow but still soaked the new plugs
During my attempts to start there was backfire popping intermittently.....have I destroyed the cats??? Sensors are plugged in, timing is correct with crank and cam gears lined up and belt put in with the three white marker lines in line with the crank/cam gears. HELP!!! |
09-02-2005, 10:02 PM | #7 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
Do a compression test. I bet bent valves or timing is still off on the belt. Popping is not a good sign. I am sure an 97 engine is interference.
09-04-2005, 10:08 PM | #8 |
Member#: 57891
Even on the 2.2L SOHC the motor is interference? I'll do a compression test ASAP....
I always thought only the DOHC motors are interference |
help!!converted to hids and now fogs not working | 5.0Ranger | Electrical & Lighting | 1 | 04-27-2006 10:12 PM |
Otters that went to church at one time and now don't | -=C=- | Off-Topic | 59 | 03-02-2006 07:44 PM |
97 Legacy GT 2.5 timing off #1 cylinder not firing | nvrgnadi | Service & Maintenance | 4 | 11-26-2004 11:07 AM |
Help! Had my car to the dealer 4 times now and they can not figure out the problem | Scooby do | Brakes, Steering & Suspension | 9 | 10-15-2002 09:05 PM |
Rock and windshield does not mix well... | ashtaron14 | Vancouver Impreza Club Forum -- VIC | 13 | 02-12-2002 07:24 PM |
