Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 07-08-2015, 11:24 AM   #25001
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
A squealing belt glazes the pulleys, which creates more squealing.
A brand new standard belt on glazed pulleys may continue squealing.
I've never had this problem with Gatorbacks.
Commander Keen is offline   Reply With Quote
Old 07-08-2015, 11:31 AM   #25002
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by flyboy1100 View Post
I would think so, but we only have 1 serpentine belt.
Thought you ordered new a new belt when we were discussing this about 2 months ago
I did, but I haven't installed it yet. I ordered the belt proactively because the price was so good, but I hadn't detected any squealing yet at the time I ordered the new belt. The a/c squealing is a brand new symptom.
sgoldste01 is offline   Reply With Quote
Old 07-08-2015, 01:22 PM   #25003
myrt1987
Member#: 323103
2018 WRX
Pure der
My Gatorback is working as expected. Squealing stopped. Never heard anything from turning AC on.
Old 07-08-2015, 03:03 PM   #25004
vt_scoob
Member#: 404917
12 Impreza Sport
Anyone know what the flat plates directly behind the brake rotors are? Some kind of heat shielding? I'm getting a rubbing noise from the front left, and that plate doesn't look symmetrical and feels kind of warped around the edges. Im suspecting that plate might be rubbing the rotor somewhere. Its feeling a bit jittery under hard braking as well, so hopefully the rotor isn't warped too. Any thoughts/ help would be appreciated, as i usually leave the brake work to the dealership.
Part in question
vt_scoob is offline   Reply With Quote
Old 07-08-2015, 03:10 PM   #25005
Obviously Tyler
Member#: 395955
2018 Mazda 3 GT
2018 Crosstrek
That would be your dust shield. Keeps brake dust off of suspension components.
It's possible that the shield is the source of the noise/vibration but unlikely if it hasn't been touched or damaged.
I would just bring the car in and have it looked at.
Noise and vibration can be a number of things. Brakes, tires, suspension, alignment.
Obviously Tyler is offline   Reply With Quote
Old 07-08-2015, 04:04 PM   #25006
Jimpreza111
Member#: 407850
2014 Impreza 2.0i
Quartz Blue Pearl
That shield thing has caused me some concern in the past, usually a little rock/pebble gets lodged between the rotor and the shield and squeals like crazy. Usually have to pull off to the side and reverse a couple feet and it frees the pebble.
Jimpreza111 is offline   Reply With Quote
Old 07-08-2015, 04:52 PM   #25007
vt_scoob
Member#: 404917
12 Impreza Sport
Good info, thanks guys. The frequency of the noise I'm getting is pretty clearly once per tire rotation, so i think ill take obvtylers advice and bring it in. Up for the 60,000 mile service soon anyway.
Old 07-08-2015, 05:01 PM   #25008
race24x
Member#: 425263
I need some help before buying a 2003 Impreza RS with a 2.5. The motor is blown, but I have a 2.5 from a 98 Forester. They are both 6th VIN ^ charecter engines. Will they swap or is it alot of work?
race24x is offline   Reply With Quote
Old 07-08-2015, 05:03 PM   #25009
race24x
Member#: 425263
I forgot to mention the Impreza is a standard and the Forester is an automatic
Old 07-08-2015, 06:08 PM   #25010
drpoop
Member#: 421858
2012 Impreza
Has anyone tried messing the box that holds the HVAC controls to see if it has a switch you can disable to allow you to run defrost without AC like the older models?
drpoop is offline   Reply With Quote
Old 07-08-2015, 08:42 PM   #25011
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
This question would probably be better directed to the "naturally aspirated powertrain" sub-forum. Right now, you're on a thread specifically about 2012+ Imprezas.
soobie doo is offline   Reply With Quote
Old 07-08-2015, 10:37 PM   #25012
race24x
Member#: 425263
Sorry wrong spot I will try again.
Old 07-09-2015, 02:11 AM   #25013
SubaruLee
Member#: 350664
2013 Impreza limsprt
Default 2012 Impreza thread
Originally Posted by drpoop View Post
What's the service interval for the belts on the front of the engine?
105k I believe. Just changed mine out at 115k was a bit stretched, only squealed at startup a couple of times towards the end. 1 belt
SubaruLee is offline   Reply With Quote
Old 07-09-2015, 07:12 AM   #25014
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
just sharing this for fun
woo finally got my jap style plates with the grimmspeed wrx plate relocater customised to fit the impreza lol and im still waiting on my plain delete plate to be painted the same colour as the car
mini lan is offline   Reply With Quote
Old 07-09-2015, 07:46 AM   #25015
CLL_OBP
Member#: 310435
'12 Sport Limited
PUP 5W30 168,832 mi
In the SM, it only tells you to Inspect the belt every 30k. YMMV. I replaced mine at 60k. It wasn't giving me any trouble but since got replacement belts at a great price off Amazon, I just went ahead and did it rather than wait for the belt to deteriorate.
CLL_OBP is offline   Reply With Quote
Old 07-09-2015, 05:56 PM   #25016
SueBLove
Member#: 425354
Default Beautiful
This car is beautiful. Have the same body style what have you done performance wise. Can you include links for the parts. I haven't done much on mine and I'm looking for things a beginner can do.
SueBLove is offline   Reply With Quote
Old 07-09-2015, 05:57 PM   #25017
SueBLove
Member#: 425354
What models will this fit?
Originally Posted by foghelmut View Post
Selling my Sport Mesh Grille, obsidian black pearl
http://forums.nasioc.com/forums/show...7#post43576047
Old 07-09-2015, 06:16 PM   #25018
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
Thanks
Engine:
avo turbo kit
Avo throttle controller
Suspension:
Bc br Coilovers
Avo rear stabilser mounts
Avo front sway bar end links
Avo front d mount bushes
Cusco front and rear strut brace
Old 07-09-2015, 06:19 PM   #25019
Jimpreza111
Member#: 407850
2014 Impreza 2.0i
Quartz Blue Pearl
Yes we're all waiting for mini to post some vid of that boosted impreza at the track.
Such a clean looking car and has the power to boot!
Old 07-09-2015, 11:32 PM   #25020
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
I'd even be happy with a pic of the turbo installed
gregorz4 is offline   Reply With Quote
Old 07-10-2015, 12:06 AM   #25021
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
He posted one a while back
Old 07-10-2015, 12:28 AM   #25022
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
sorry for the delay but here are some pics of it all bolted up any questions or specific pics ask and i can take some and answer the questions best i can cause i fitted about 80% my self
woo got a couple pics over the weekend and someone took a nice pic of the engine bay and with a proper camera and not my pictures with potato phone lol
Here.
Tha Chakal is offline   Reply With Quote
Old 07-10-2015, 12:45 AM   #25023
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
If you want me to put a pic of the manifold etc let me know and cant wait to put it on the dyno monday after school
Old 07-10-2015, 01:07 AM   #25024
Tha Chakal
Member#: 372100
Short vid of a pull, maybe?
Old 07-10-2015, 01:09 AM   #25025
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
Ill record it on the dyno and ill try to record it in the car also
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
