06-11-2004, 12:46 PM | #1 |
Member Sales Rating: (29)
Member#: 53517
Vehicle:STi Outback STi |
'00 2.5 RS parts for sale
For Sale
1 JC Sports intake with yellow hoses, and red filter. JCsports dyno tested this intake at an 8% increase over stock power which is a 13.2 HP gain and 13.3 lb/ft gain in torque. Asking $100 2 JC Sports front strut tower bar. Black in color with silver JC Sports logo in center of the bar. (can be easily seen thru the hood with the hood scoop cover removed from under the hood) Asking $75 3 Factory 120 watt sub and wiring harness Asking $75 4 Cusco lower arm bar. blue in color. Asking $ 40 5 JC Sports 21mm rear sway bar. The RS comes stock with a 13mm. Improves turn in and eliminates alot of body roll. With this bar the car has less roll than a WRX. Asking $60 6 Front skid plate to protect the bottom of your engine. Asking $ 30 All parts are in great shape and kept clean at all times. The sub was never turned to max power and kept at minimum gain while in the car. Shipping is $15 for each part or if all parts are to be shipped to same buyer shipping will be $30 and I'll cover the rest. US shipping only!!
06-11-2004, 03:32 PM | #4 |
Member#: 53517
No pics right now. It is however the approx. 12"'s in length and uses 4 12mm bolts to bolt it down to the frame by the rear differential housing. I'll check on a pic to forward to you.
06-13-2004, 02:48 AM | #8 |
Member Sales Rating: (8)
Member#: 39482
Vehicle:2005 LGT |
can i get pics of the front skid plates to [email protected]? and i live in md so could i come and pick them up? thanks
06-13-2004, 12:31 PM | #9 |
Member#: 53517
I currently have no pics of the skid plate. It is however the factory skid plate that is approx 1/8" thick that mounts to the lower frame of the car by the 10mm bolts that are currently on the car. there is no cutting or welding anything. It is an option that can be bought from the dealer for $120 and comes as an optional part on the Impreza Outback wagons as well. If you want to drive down to pick up the part and look at others I have that is possible. I'm just 20 minutes west of Danville and I can meet up with you if needed either at my job or at another location.It will be approx 5 hours to get here from DC.
06-14-2004, 10:33 AM | #11 |
Member Sales Rating: (19)
Member#: 21118
curious about the arm bar. send a pic to [email protected].
06-15-2004, 02:48 AM | #13 |
Member#: 53517
There should be no additional parts used to install the sway bar on the L. All I had to do was jack the rear of the car and loosen the factory sway bar at the end links on the rear control arms and remove the brackets holding the bushings and reverse the order to tighten everything with the new bar in place.
With this sway bar installed on the RS, it was a more stable car than the '02 WRX. |
06-15-2004, 10:19 AM | #16 |
Member Sales Rating: (3)
Member#: 821
I knew that you did, but the seller doesn't.
You need the lateral links with the drop link mount, the drop link, swaybar mounting brackets, and all of the accociated hardware. There may be other parts. People have reviewed this, if you look hard enough you should be able to find the threads with it detailed. cheeRS, Greg |
06-15-2004, 10:48 AM | #17 |
Member#: 53517
Thanks,
I wasn't for sure of the difference on the L's compared to the RS's. I know some of the older L's were fwd only but I couldn't say for sure on the newer awd versions. |
06-16-2004, 12:10 AM | #18 |
Member Sales Rating: (1)
Member#: 33991
Vehicle:1998 Legacy GT Wagon Black |
I've got a 2001, so it's the newest possible version, but sadly, still no sway bar. I am still interested in the bar however. Can you get me a shipping price to 14004? Thanks.
Section 8, if I managed to get the stock mounting hardware from an RS, would I be able to use that? |
06-16-2004, 06:55 AM | #21 | |
Member#: 821
So in this case, go intercourse yourself with a chainsaw. |
06-17-2004, 01:02 AM | #24 |
Member#: 53517
Paypal addy is
[email protected] As soon as I receive payment I will notify you of the shipping date and the tracking info. It may take a few days to ship since I'm having to work days over weekend. But it would definitely be shipped by no later than Tuesday. Thanks! |
06-17-2004, 01:05 AM | #25 |
Member#: 53517
I still have the intake. I'll get you a pic of it asap.I'll have to check to see if I already have a pic on file or if I need a new one.
FS: (NY) '00 2.5 RS Parts Car - 68k miles $1900 | GC8WSI | Private Vehicle 'For Sale' Classifieds | 4 | 12-01-2009 12:35 AM |
PA: 02 rs 2.5 motor parts for sale | whitesti04 | Engine/Power/Exhaust | 8 | 06-04-2007 10:48 AM |
2.5 RS parts for sale | DreaminDemon | Private 'For Sale' Classifieds | 17 | 12-03-2004 10:06 AM |
2.5 RS parts for sale | Imprezo | Bay Area Impreza Club Forum -- BAIC | 2 | 10-03-2003 01:19 PM |
2001 2.5 RS Parts for Sale | emat5 | North West Impreza Club Forum -- NWIC | 22 | 05-09-2002 09:40 PM |
