Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 04-23-2013, 11:32 AM   #1
AWDrifter21
Member#: 51112
2004 WRX-sold T_T
now 2005 STi ^^
Default STi head apart what should i do?
I searched but could not find good or at least recent opinions.
I got an 05 STi and I have it apart, heads taken off.
Im already $1000 in the hole for labor and no parts and I have about $1500 left to spent.
I need to maybe get a valve adjustment and new head gasket, and other misc things. What do you recommend I should do now?
Maybe clean pistons/valves? Got some decent carb build up.
port and polish head (expensive)?
Im pretty knowledgeable but no expert on internal engine modifications.
As I advised I only have maximum $1500 to spend thats all tax and labor and parts so everyone with experience, please chime in.
Thank you!
AWDrifter21 is offline   Reply With Quote
Old 04-23-2013, 12:39 PM   #2
singincanary
Will mod for Guinness
Member#: 77921
'09 Ruby Red spec.B
'14 Tribeca, '08 OBXT
Wrong forum. I'll move it for you.
singincanary is offline   Reply With Quote
Old 04-23-2013, 12:46 PM   #3
AWDrifter21
Member#: 51112
2004 WRX-sold T_T
now 2005 STi ^^
actually i wanted opions from local NJ people actually so I can see what shops in the area they went to , etc.
Old 04-23-2013, 01:37 PM   #4
singincanary
Member#: 77921
'09 Ruby Red spec.B
We have our vendor lists, a vendor review thread and forum and a search will reveal lots of info.
Old 04-23-2013, 01:58 PM   #5
sultan81
Member#: 309943
2012 STi
Head gasket, Head studs definitely. The rest of it depends on what your goal is. Power, Reliability?.
The best thing to probably do would be pistons/rings, as that is the weakest part in the motor.
sultan81 is offline   Reply With Quote
Old 04-24-2013, 05:51 PM   #6
AWDrifter21
Member#: 51112
2004 WRX-sold T_T
now 2005 STi ^^
Thank you, I am looking more for reliability than power.
I would like to use stock subaru OEM head gasket, but you recommend studs?
If so, which brands? and what is major benefit for stock motor and turbo.
Thank you again.
Old 04-24-2013, 06:01 PM   #7
sultan81
Member#: 309943
2012 STi
OEM Head gasket, and ARP Head studs. Many people i know don't like to re-use head studs. The benefit of the stronger pistons is, you are less likely to grenade them and turn the motor into scrap.
Old 04-24-2013, 08:41 PM   #8
StackSmasher
Member#: 316928
2012 STI limited
Are ARP head studs even needed if you arent making big power? I havent seen a single thread about these being a cause of failure.
StackSmasher is offline   Reply With Quote
