Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2020
Old 05-30-2020, 07:24 AM   #1
AVANTI R5
Member#: 73805
Default What Makes GMís Oversized 2.7-Liter Turbo Four-Cylinder Special?
One of the most intriguing engines released by GM in recent years is its 2.7-liter four-cylinder known as the L3B. In this video, Jason from Engineering Explained talks about what makes this engine interesting.
The first thing is its displacement; 2.7-liters, making it the largest displacement four-cylinder currently on the market. In a press release announcing the L3B engine, which you can view here, Chevrolet continually referred to it as being a ďtruckĒ engine that was ďdeveloped from the outset as a truck engine.Ē
While calling the L3B a truck engine is all very well and good, the only issue is that it is also fitted beneath the hood of the Cadillac CT4-V, a sports sedan thatís about as far removed from a pickup truck as you can imagine. In CT4-V form, the engine pumps out 325 hp and 380 lb-ft (515 Nm) of torque and in the Chevrolet Silverado, the only truck that it is currently offered with, is rated at 310 hp and 350 lb-ft (475 Nm).
One of the most intriguing things about the L3B engine is that it features a dual volute turbocharger, meaning it has two volutes and operates in a similar fashion to a twin-scroll turbocharger. Jason says an advantage of a dual volute turbocharger is that it enables engineers to separate the exhaust pulses so they donít interfere with each other. This results in better response, improved low-end torque, and greater efficiency.
Video at link
Old 05-30-2020, 01:28 PM   #2
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
Nice torque numbers for sure.
oichan is offline   Reply With Quote
Old 05-30-2020, 04:24 PM   #3
lil'redwagon
Member#: 10854
'02 WRX; '08 OBXT;
'08 G37 (S/C'd); '09 XF
So the difference between this turbo and a standard twin scroll is that the volutes are beside each other in a twin scroll, but with this one, there is an inner and an outer volute. I'm surprised this hasn't already been tried.
lil'redwagon is online now   Reply With Quote
Old 06-01-2020, 06:58 AM   #4
rexster
Member#: 22863
2015 WRX Premium CWP
Worse mileage than the v8. Because less is less...
rexster is offline   Reply With Quote
Old 06-01-2020, 09:28 AM   #5
heavyD
Member#: 194216
2020 X3M Competition
I havenít checked but is that true? That doesnít make a lot of sense especially when you consider this engine should make for a lighter truck.
heavyD is offline   Reply With Quote
Old 06-01-2020, 09:37 AM   #6
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
The I4T is rated better around town but worse on the highway, the average for the I4T is slightly better than the V8, I'm talking 1 or 2 MPG IIRC.
Sid03SVT is offline   Reply With Quote
Old 06-01-2020, 10:50 AM   #7
heavyD
Member#: 194216
That's pretty mediocre efficiency IMO making this engine not so special after all. I suppose every MPG counts for manufacturers even if the reality is lipstick on a pig.
Old 06-01-2020, 05:42 PM   #8
shake-rattle-n-roll
Member#: 448186
Maybe its running on 4 cylinders on the highway portion of the test?
shake-rattle-n-roll is offline   Reply With Quote
Old 06-01-2020, 06:16 PM   #9
wrxsubaru
Member#: 65133
I am guessing the 4 cylinder idea was just botched by bureaucracy that is GM. I am not sure that small of an engine could push a half ton around at 70MPH on two cylinders.
Should have kept the 4.3 and added the new transmission. But in general i am not in favor of smaller turbo gas engines on trucks.
If you really dont use the truck as a truck then a smaller gas turbo can be ok, but for fleet or heavier fleet use the turbo side can cause sooooo many issues.
wrxsubaru is offline   Reply With Quote
Old 06-01-2020, 08:14 PM   #10
shake-rattle-n-roll
Member#: 448186
Things are just become way to over-complicated v8s running as v4s, then v4s running as v2's
Old 06-01-2020, 09:25 PM   #11
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Or we could just have a couple drive motors and a battery pack
Old 06-01-2020, 09:51 PM   #12
AWDspider
Member#: 43748
I don't know man, I have 3 Ecoboost trucks/vans that haul/tow daily and the only mechanical issue I've had has been the driveshaft on the transit van. We have two 3.5's and one 2.7, the youngest has almost 200k and the oldest has about 400k. They are all less than 6 years old.
AWDspider is offline   Reply With Quote
