Welcome to the North American Subaru Impreza Owners Club Thursday December 5, 2019
Old 07-31-2015, 11:07 PM   #151
teds-rex
Member#: 400886
2004 STi
open up your rom in ecuflash and click on the ROM INFO section... device will show up as Memory Model: __________
teds-rex is offline   Reply With Quote
Old 07-31-2015, 11:29 PM   #152
mikeyPSF
Member#: 236475
If you have a USDM 04 STi, you have a 7055 processor. The instructions on our site are for a 7058. For the 7055, you wire it the same but have to use the Renesas Toolkit.
-Mike
Tactrix
mikeyPSF is offline   Reply With Quote
Old 08-01-2015, 10:27 AM   #153
camronnie
Member#: 403765
2012 Forester
I have a 2012 Forester, using the 7058. I tested the EUflash again last night, everything seemed to work, no checksum errors, and it said it was complete. After pulling the ECU off the test board, it still wouldn't talk. No fuel pump prime, and my coolant light was still flashing red and blue.
This morning I am trying to use the renases toolkit, but haven't had any luck yet. It keeps saying:
Clock Frequency = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH/7058F' on 'COM5'
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM5' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device: 0x80
Attempting 4800
Attempting 2400
Attempting 1200
Error No 15024: Boot failed
Has anyone seen that before?
camronnie is offline   Reply With Quote
Old 08-01-2015, 12:38 PM   #154
camronnie
Member#: 403765
2012 Forester
GOT IT!!! Thanks to this thread and everyone's input. I added the Vcc to the RST on the 555 timer, and I saw I forgot a capacitor between Vcc and GND. Once I did that, ECUFlash FLEW thru the program, no hiccups, no double writes, and I just did a flash back onto the ECU to make sure it works thru the OBD, no problem.
However, it's time to diagnose why I can crank but why it wont run. Woooo out of the frying pan and into the fire.
Old 08-01-2015, 12:42 PM   #155
teds-rex
Member#: 400886
2004 STi
Your reflash connector is disconnected right?
Also, regarding the above you saw... i saw similar immediate response correct but still failed if i didn't turn the key one RIGHT when i started the connection... just like normal ecuflash mode.
Old 08-01-2015, 01:10 PM   #156
mikeyPSF
Member#: 236475
Looking at you last Renesas log, it shows 7058. When it actually worked, did you have 7055 selected? If not, you may need to rewire and reflash once more using the 7055. From my notes, here are the settings I use:
Recovering SH7055 using Renesas Toolkit FTD Development Toolkit 3.05 Basic
select device: SH/7055F
select port: COM3
CPU crystal frequency: 10 Mhz
select connection: BOOT Mode
Old 08-01-2015, 05:08 PM   #157
camronnie
Member#: 403765
2012 Forester
When I finally got it to work it was using ECUflash. I couldn't get renesas to work, but ECUflash was what I tried first after my circuit corrections.
Are you wondering if the non-ignition could be due to the SH boot? Or were you just curious based on which chip I used for the renesas setup?
Edit - yes, everything is disconnected. Solder points are still there, but everything is off my breadboard.
Old 08-01-2015, 10:33 PM   #158
teds-rex
Member#: 400886
2004 STi
If it was flashed with the wrong target selected that could maybe cause issues, but with ECU flash i expect it determines the correct ECU based on the ROM - so expect its OK there. did you make sure the green connector at the driver footwell is disconnected?
Old 08-02-2015, 12:44 AM   #159
camronnie
Member#: 403765
2012 Forester
I think the connector you are talking about is only needed on older ECUs. I've never had to do anything other than plug into the OBD and flash. I found a nice 14 page diagnostics walkthru of engine starting failure, so I'm just going to plan on walking thru that tomorrow and see what's up as best I can.
Old 08-02-2015, 12:47 AM   #160
teds-rex
Member#: 400886
2004 STi
Yeah that might be... I've only worked on 06 and older... Good luck with the debug
Old 08-02-2015, 04:16 PM   #161
camronnie
Member#: 403765
2012 Forester
I won't go into too much detail or discussion because it isn't directly related to this thread, but I found a blown ignition fuse. Replaced, cranked, it blew again. The rear 2 cylinder coil overs had shorted burnt up. I've also been having CEL issues with too many misfires lately, I wonder if they were just slowly eating themselves and finally gave out.
Old 08-08-2015, 03:17 PM   #162
talon2.5RS
Member#: 55033
2001 Impreza 2.5 RS
Project 2.5RSRX Underway!
I made an account on the Renesas site but I don't see where to go to download the FDT application from the "My Renesas" page. Do the downloads on the link provided in the OP contain everything? They appear to only be upgrades to previous versions.
talon2.5RS is offline   Reply With Quote
Old 08-08-2015, 09:48 PM   #163
teds-rex
Member#: 400886
2004 STi
The "updates" are full versions. I downloaded this:
Flash Development Toolkit V.4.09 Release 02 Upgrade
installed without having any previous versions and unbricked mine.
Old 08-09-2015, 12:36 AM   #164
VanHalen5150
Member#: 424035
2011 Impreza 5 door
OK, First let me say this is an awesome project!
Now, a few observations.
For the love of God, Please, Start using a grounded static mat, wrist strap etc.
If you're planning on doing a bunch, go get a wiring harness cut from a junk yard and wire the power connections, and double check everything, 12v to the wrong pin even for a moment COULD perma-trash your ECU.
Also, If anybody wants to set up a fixture, I worked for a major in ICT design and build company. A Delrin jig with wire wrap pin sockets and some gold spring loaded test probes could make hooking up a matter of seconds.
VanHalen5150 is offline   Reply With Quote
Old 08-09-2015, 12:52 AM   #165
teds-rex
Member#: 400886
2004 STi
Agreed... That's why I connected to my car during the process instead of on the bench. Building a full jig and offering unbricking service would be cool though not sure if this exists at the moment.
Old 08-09-2015, 10:45 PM   #166
talon2.5RS
Member#: 55033
2001 Impreza 2.5 RS
Thanks teds-rex! Now I'm waiting for my hardware to show up so I can build the adapter. I was shocked when I bricked my ECU because I've flashed the 16 bit ECU in my Impreza a ton of times and never had an issue. I flashed the ECU in my FXT once and for some reason it didn't take even though it said the flash was good. I tried again and it errored and bricked. WTF?!
Old 08-09-2015, 11:08 PM   #167
mikeyPSF
Member#: 236475
How do you know it didn't take? Did the car no longer start after you received a message for a successful reflash?
Did you save the error log?
-Mike
Tactrix
Old 08-10-2015, 07:01 AM   #168
talon2.5RS
Member#: 55033
2001 Impreza 2.5 RS
-Mike
Tactrix
The car came with A2WC400I and I flashed A2WC412I with a few CEL turned off as a test. Newer version of the same rom. I connected with RomRaider and it said I still had A2WC400I. Downloaded the rom and it was still 400I. Flashed 412I again and it gave me an error. Left the key on and flashed again to try and save it. Car would not start after that.
Edit - had a little time before work to check. I didn't realize the log was not automatically saved. No log for me.
Old 08-10-2015, 08:38 AM   #169
teds-rex
Member#: 400886
2004 STi
Mike, hoping you might have some insight on the watchdog and the real requirement. I used a clock generator the first time i unbricked just because I couldn't get the 555 locally. I setup the clock for 125Hz per the notes. Afterwards i ordered some 555 and built up the circuit as a JUST IN CASE THIS HAPPENS AGAIN but the resistor values on the SHBOOT schematics don't generate 125Hz like it says, but instead around 150Hz. Either of these sounds wicked high for a watchdog, but then again I work in consumer electronics and not mission critical ECU so maybe the difference lies there. Should the clock be 125Hz or 150Hz?
Old 08-10-2015, 04:04 PM   #170
mikeyPSF
Member#: 236475
The only thing I can think of there is that maybe you clicked on the test write button instead of the normal write icon. The test write walks through all of the communications without actually changing any bits, so it would look similar in the logging output. I've never in the five years of working here had anyone say that they had a successful write to an ECU, but then read out something different afterward.
If you feel like you're having frequent issues, send me an email to support at tactrix dot com and we can setup some additional debugging output. Also, be sure to use the latest version of EcuFlash from our site.
Either of those values should be fine.
-Mike
Tactrix
Old 08-14-2015, 05:24 AM   #171
VanHalen5150
Member#: 424035
2011 Impreza 5 door
Tell you what. If you'll send me a dead ECU, Say one that can't be unbricked I'll build you a drop in programming jig. Just send me a diagram of the points you need access to. I'll do this provided you offer the service at a decent discount to NASIOC members. It will save you a fair amount of time not having to solder I believe. Essentially its a block of a fiberglass type material that's machined to accept the board with alignment pins. then there are sockets that accept these little spring loaded in circuit test probes to make the connections. You just drop, lock and go.
When I was building military grade palm pilots I built one. Before that you had to disassemble the unit and pull a board to flash one of the CPLD devices. After I built the fixture I could do them in the case in a matter of thirty to forty five seconds each. Well worth it.
Old 08-14-2015, 07:33 AM   #172
teds-rex
Member#: 400886
2004 STi
I've used similar built from FR4 or even Plexiglas before with spring contacts loaded on it. If works well but like you said the board needs to be locked in somehow. Need to look how this can be done. Possibly a sandwich that slides on from the side but need to check clearance of the rear of the case. Also not sure if all the different models have test points in same location or not? The boards must have some differences as some use different micros but not sure on test point location / arangment. Maybe folks unbricking can share photos of their test points to compare. All I have in my driveway is an 02, 04, and 06 which I can probably pull and check this weekend.
The harder part than soldering as I have done so far is powering it. Really need to get a harness cut up and wired for power. I hadn't seen a clear list of power pins and again. If sure if this varies at all from car to car, any thoughts?
Old 08-14-2015, 01:24 PM   #173
mikeyPSF
Member#: 236475
They all use the same numbered connections (P407,P405,etc.) but those connection points are at different locations on different boards. I can't recall off the top of my head but I think it's a single digit number of variations you'd have to account for.
Early 16 bit ECUs aren't recoverable so don't bother opening up the 02 in the driveway. That's a ~$50 junk yard swap. If the 04 is a WRX, that's the same solution, but if it's a STi, then you can map it for recovery as those have the 7055.
Agreed. Soldering to the circuit board is pretty simple as long as you have the right soldering iron. The only ECU that I've not been able to repair is one that someone tried to fix themselves using a really hot soldering iron inappropriate for circuit board use. Figuring out the powering up of each ECU is a little more work.
-Mike
Tactrix
Old 08-14-2015, 01:29 PM   #174
teds-rex
Member#: 400886
2004 STi
Yeah the 04 is an STi with the 7055 as you said... and this one was already unbricked once
The 06 is a 2.5i so not sure which ECU it uses.
Mike, i had a previous question about the watchdog, do you know if it should really be 125kHz or 150kHz? The SHBOOT text says 125k, but if you do the calcuations on the resistors in the schematic for the 555, it comes out to 150k. I unbricked mine at 125k, but just wanted to check what the suggested value was.
Old 08-14-2015, 01:52 PM   #175
mikeyPSF
Member#: 236475
The 06 2.5i uses the 7058. If you want to figure out memory model for a particular car, just navigate to the definition in your EcuFlash install by browsing in Windows. Go to this folder with the preview pane open in Windows Explorer
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\subaru\Impreza 2.5i
Then just arrow down until you see the 06, and you'll see the following info at the top:
Code:
<rom>
	<romid>
		<xmlid>E2UE202L</xmlid>
		<internalidaddress>2000</internalidaddress>
		<internalidstring>E2UE202L</internalidstring>
		<ecuid>4D12084106</ecuid>
		<make>Subaru</make>
		<market>USDM</market>
		<model>Impreza</model>
		<submodel>2.5i</submodel>
		<transmission>MT</transmission>
		<year>06</year>
		<flashmethod>sti05</flashmethod>
		<memmodel>SH7058</memmodel>
		<checksummodule>subarudbw</checksummodule>
	</romid>
I answered the watchdog question in my reply on August 10th. It's about 5 posts up. Either 125 or 150Hz (not kHz) should work fine.
-Mike
Tactrix
How to Make an STI Look Like a Sleeper? FostersAFB General Community 92 10-12-2017 10:24 PM
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 10:26 AM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 09:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 03:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 04:28 PM
