Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 06-15-2006, 12:32 AM   #1
MaLT
Visiting NASIOC Timeout
Member#: 117377
06 WRX Wagon
Steel Grey
Have a Nice Day? Stalling at Idle after Minor Mods
Just put a TurboXS Ti Turboback, TurboXS short RAM intake, and bov-rfl on my 2006 wrx. I am having problems with an inconsistent idle. sometimes it will be fine around 600-800rpm and other times will spike up to 1500 then back down to almost stalling repeatedly until it evens out at the 600-800 mark or simply boggs out and stalls. How do i fix this? Is it strictly ECU and o2 sensors misguaging the A/F ratio? If so hoe do I approach this prblem?
MaLT is offline   Reply With Quote
Old 06-15-2006, 12:51 AM   #2
mdd1986
Member#: 83450
2000 Audi S4 Stage 3
no, the problem is coming from your rfl bov. Those things leak so much air at idle and really screws everything up. Put the stocker back on and im sure you will notice a difference.
mdd1986 is offline   Reply With Quote
Old 06-15-2006, 01:12 AM   #3
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Did you disconnect your negative battery terminal and drain the rest of the power before doing your mods?
wrxfactor is offline   Reply With Quote
Old 06-15-2006, 11:41 AM   #4
OMEGA SUPREME
Member#: 89995
05 Broke STI
+1234 take it off and check, if you want to try and keep it on you may need to add some washers in it
OMEGA SUPREME is offline   Reply With Quote
Old 06-15-2006, 01:51 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
I agree you are leaking air somewhere. For a more general approach, use brake cleaner and spray around the RFL and the intake manifold to find the leak. When the cleaner gets sucked into the engine it will cause a momentary surge.
Old 06-15-2006, 01:57 PM   #6
Division By Zero
Member#: 7555
Actually, you might want to take a clear plastic bag or plastic wrap and put over the BOV orifice. With the engine on, midly blip the throttle to see if that valve is leaking. This is how I tuned mine along with actually driving etc. I bet yours is hanging open momentarily after it rests back down to idle.
Division By Zero is offline   Reply With Quote
Old 06-15-2006, 11:42 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....yergonnablowitupwithoutem.....and yer MAF is likely backwards
Old 06-15-2006, 11:46 PM   #8
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
it is your bov! and i am 100% positive on that! take it off and take it apart. clean it and lubricate the piston with something lite! if it still does it then sell it to sum dum dum on nasioc.
gingertooth is offline   Reply With Quote
Old 06-16-2006, 10:05 AM   #9
Division By Zero
Member#: 7555
His TXS valve most likely uses washers to adjust the tension.
Old 06-16-2006, 10:09 AM   #10
Division By Zero
Member#: 7555
Do you think blanketed comments like that are helping?
Old 06-16-2006, 01:23 PM   #11
justboosted02
Member#: 78285
2003 EVO
red and black
its the rfl. i had the same problem, either get a new bov or go back to the stocker. TXS bov's are horrible. ive had 2 (rfl and type-h). i use a tial now
justboosted02 is offline   Reply With Quote
Old 06-16-2006, 01:31 PM   #12
Division By Zero
Member#: 7555
I'm using the RFL with zero issues. Works as advertised. Just took some adjustments to get it right.
Old 06-16-2006, 01:59 PM   #13
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
It's probably the stupid blow-off valve or the intake. Both generally considered not the best of mods.
conker69 is offline   Reply With Quote
Old 06-16-2006, 02:03 PM   #14
GraphicWRX
Member#: 57743
2017 17' Golf R
Copper Penny
I hate to flame,, why do people insist on the CAI and the BOV? I think you are better off filling your tires with nitrogen...
GraphicWRX is offline   Reply With Quote
Old 06-16-2006, 02:04 PM   #15
GraphicWRX
Member#: 57743
2017 17' Golf R
Copper Penny
Just kidding, there are alot of lessons learned from the two though
Old 06-16-2006, 02:15 PM   #16
conker69
Member#: 59692
WRB-Gold
I thought the car wouldn't even start with the MAF on backwards?? Just curious.
Old 06-17-2006, 05:51 PM   #17
OMEGA SUPREME
Member#: 89995
05 Broke STI
thats correct. I was having probs with my car aftere my install and i tried switching the maf sensor around and the car ran for about a second. Most intakes are idiot proof anyways.
Car Stalling at Idle after minor Mods MaLT Newbies & FAQs 21 01-10-2012 04:58 PM
Stumble at idle after mods 3XRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-28-2007 01:36 AM
Fine tuning a dyno tune after minor mods? kharris4 Engine Management & Tuning 0 09-01-2005 10:39 PM
--> <-- this close to stalling at idle. RaceCarRiot Normally Aspirated Powertrain 4 01-29-2002 08:39 PM
Stalled at idle... RallyImprezive Normally Aspirated Powertrain 3 04-10-2001 02:30 PM
