Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 12-08-2017, 03:18 PM   #1
mrkyle3
Member#: 272675
2011 WRX
2002 Corvette Z06
Default Part # for 2011 WRX passenger headlight harness
I'm posting this as a last resort because my internet research and calling several Subaru parts departments has not yielded the answer.
I have the well-documented issue with the right turn signal flashing rapidly secondary to the harness being too tightly bound from the factory. For years I would just intermittently push the wires back into the socket and that fixed it, but that is no longer working.
Hence I am looking to replace the turn signal socket and unfortunately it appears that you can't buy just the socket/pigtail and replace that; you have to buy the entire harness.
Which leads to my question: I have found two part numbers that appear when I select the halogen headlamp option on the parts website. Both also show up when selecting the HID option. So I believe that one is for the HID setup and one is for the halogen setup, but I can't figure out which is which:
84931FG011
and
84931FG081
Anybody know?
Here are pics of the socket for reference:
mrkyle3 is offline   Reply With Quote
Old 12-08-2017, 05:04 PM   #2
mrkyle3
Member#: 272675
2011 WRX
2002 Corvette Z06
I believe I found the answer.
84931FG011 is listed as fitting 2010-2014 WRX. 2010 is when HID headlights became available on the limited trim. So this should be the HID harness.
84931FG081 is listed as fitting 2008-2014 WRX and so I believe this must be the correct part # for the halogen headlights.
Just updating for future people with the same problem who come across this via google.
