Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 12-08-2017, 05:12 PM   #1
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Default H11 headlights/fog lights bulb
Hey all,
Went with new housing and adapters to put h11 fogs on my 2012 2.0i. the cheap bulb that came with the housing finally blew. Check pic...never touched it, but sure looks like a hot spot developed.
Wanted to ask, my oem Subaru headlights look to be about 3700k-4k color. Trying to get a better match than these cheap ones were. Anyone know the actual color range spec for these?
I drive lots of dark wooded backroads. The light I have now is usually good for me, but wouldn't mind adding a little distance and brightness, but don't want to replace the bulbs every year. Also, are the osram nightbreakers still the bulb of choice?
dcon9999 is offline   Reply With Quote
Old 12-08-2017, 05:50 PM   #2
SG02WRX
Member#: 151814
2014 WRX SWP
Have you checked out Tutorials on H11 to H9 conversion?
I searched for a the brightest bulb on the H11 category. Almost every bulb its very dim.
I'll wait for someone else to chime in.
SG02WRX is offline   Reply With Quote
Old 12-08-2017, 08:46 PM   #3
cknowlen
Member#: 189077
2011 STI limited
To answer your question about the nightbreakers. I friggin love mine. Never had any problems with them firing right up and now flickering. Plus the kelvin rating is perfect and accurate. I tried morimoto bulbs before the Osram's and i went through 3 sets of returns to theretrofitsource.com before I said "screw it" im going Osram. You won't regret the purchase.
cknowlen is offline   Reply With Quote
Old 12-09-2017, 09:58 AM   #4
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
I did, but I have reflectors.
Old 12-09-2017, 11:03 AM   #5
Paranoid Fabrications
Member#: 140712
2008 WRX STI
If you are looking for an option that will reach out farther and much brighter we have a nice option for you
We have a Baja Designs kit for that car.
uses the super bright Baja Designs Squadron light (either sport or pro)
Full plug n play setup
https://www.paranoidfabrications.com...gn-fog-bracket
Paranoid Fabrications is offline   Reply With Quote
Old 12-09-2017, 01:15 PM   #6
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Like the look. What bulbs does it use? What are the lumens/color of them?
Old 12-09-2017, 05:15 PM   #7
Member#: 140712
2008 WRX STI
they are full light replacements, no bulb.
here are the specs of the sports
Baja Designs Features:
• Satisfaction Guaranteed - 30 Day Money Back
Guarantee
• Limited Lifetime Warranty - Complete Purchase
Protection
• uService® - Replaceable Lenses And Optics
• ClearView® - All The Light, Right Where You Need It
• MoistureBlock™ - Waterproof, Rain Proof,
Submersible
• CopperDrive® - Only LED Driven At 100%
• 5000K Daylight - Less Driver Fatigue, Natural Color
Specifications:
• Lumens: 1,800 Utilizing 4 Cree XP-G2
LEDs
• Candela: 72,675 (CD)
• Weight: 12 ounces
• Wattage/Amps: 20W / 1.4A
• Dimensions: 3.07” x 2.77” x 3.07”
• LED Life Expectancy: 49,930 Hours
• Front Lens: Hard Coated Polycarbonate
• Housing: Powder Coat Bezel -Hard Anodize
• Hardware & Bracket Material: Stainless Steel
• Exceeds MIL-STD810G (Mil-Spec Testing)
• Built-In Overvoltage Protection
Standards of Compliance:
• MIL-STD-810G Certified - (Low Temperature Test,
High Temperature, Temperature & Humidity,
Thermal Shock Cycling, Dust, Random Vibration,
Mechanical Shock, Low Pressure & Drip Box Water)
• IP69k Certified – (Submersible to 9ft)
• IK10 Compliant – (Mechanical Impact Testing)
• Salt Spray Certified
Old 12-09-2017, 06:38 PM   #8
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Clarifying: the you sent me was for fog mounting brackets....?
Old 12-09-2017, 07:25 PM   #9
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
*link
Old 12-10-2017, 12:45 AM   #10
ab0815
Member#: 464530
2017 Impreza
Ice Silver
LOVE this look! Any love for us 2017 Impreza people? Already have the factory fogs installed
ab0815 is offline   Reply With Quote
