Welcome to the North American Subaru Impreza Owners Club Thursday December 13, 2018
Old 12-10-2017, 05:58 PM   #1
1ofakind03
Member#: 472184
Default Fuel pump won't turn on, replaced relay
Hey Guys, have a 93 Jdm wrx, could easily be a very stupid question. But I'm in the process of putting my motor back in my car (not currently in) but I wanted to drain the majority of the old fuel out. So with the motor out I figured I'd just cycle the key to get it to prime into a bucket under the hood, no dice. Wouldn't prime? So I got a couple new relays and swapped them, again no luck. I got power at the relay 12v checked with the multimeter and obviously no power at the pump since the relay isn't clicking..
so I jumped the relay with a wire and the pump turns on and pumps fuel nicely. Now that it's all drained what's going on? Is it because my motor isn't in yet? Or do I have another issue?
Sorry if this is the dumbest question but id like to be able to just pop the motor in and not have many hiccups.
Thanks all for the help!
1ofakind03 is offline   Reply With Quote
Old 12-11-2017, 12:20 AM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I'm not sure if all of them are this way, but I've noticed that a number of Subarus will not prime the fuel pump if the ECU doesn't see certain engine sensors plugged in.
It's nice because there's nothing quite so annoying as draining the tank while pushing a car out the back of the shop because the fuel pump relay is buried up under the dash.
In your case, I'd just take the fuel pump relay out and run a jumper between the 12v hot lead and the load lead.
CosmoTheCat is offline   Reply With Quote
Old 12-11-2017, 12:33 PM   #3
IanT-EJ22
Member#: 477892
2000 Impreza Wagon
Hes right, the way the power is routed, the ecu stands in the way of the fuel pump relay. I would like to know exactly how the flow of current goes but something between the fusebox, ignition, fuel pump and its relay is such that the pump only runs with certain other circuits completed.
IanT-EJ22 is offline   Reply With Quote
Old 12-11-2017, 01:31 PM   #4
1ofakind03
Member#: 472184
Well I managed to get the fuel pump relay out and jumper it. Drained all the fuel and now it's almost ready to drop the motor in. Thank you for confirming I figured it might be a safety thing Subaru had incorporated
Old 12-16-2017, 06:49 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Good stuff.
