Welcome to the North American Subaru Impreza Owners Club Tuesday January 26, 2021
Old 06-10-2020, 11:01 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default gr intercooler on gd wrx question
Will the red sti elbow reach a td04 turbo on a 06 wrx?
jeff6666p is offline   Reply With Quote
Old 06-11-2020, 10:06 AM   #2
jeff6666p
Member#: 400078
black
I think it will fit but I can't install the intercooler with the stock td04. It hits the wastegate actuator
Old 06-16-2020, 02:33 PM   #3
danger1138
Member#: 279525
06 Fxt
your intercooler should'nt have a problem clearing TD04 wastegate arm. ive run stock STI inter-coolers on both a TD04 , VF48 , and Blouch 16gxt, and did not clearance issue.
have any engine bay pics with the issue your mentioning?
danger1138 is offline   Reply With Quote
Old 01-03-2021, 02:07 PM   #4
jeff6666p
Member#: 400078
black
This. Is the 2015 intercooler itís wider then the older one. It wasnt hitting the arm it was hitting the actuator. It sits higher on the td04 then the others
Old 01-05-2021, 05:20 PM   #5
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
I used about a 1.25" thick washer to elevate the inter cooler on the passenger side to allow proper clearance when installing the bolt on that side.
K3rm1tth3fr0g is online now   Reply With Quote
