#1 |
Member#: 276118
SCIC
Vehicle:1969 VW BUG Rust? |
![]() Does anybody know what the factory injector scale for a 2005 Legacy GT is? It has sidefeed yellow top injectors and I'm using Cobbs access tuner software.
Im running an EJ25 that I pulled out of an 05 Legacy GT to put in my VW bug. The wiring harness and ECU is form an 07 WRX so Cobb will only grant me access to their 07 WRX map through the access tuner software but I would imagine the top feeds that came in an 07 WRX have a different injector scale. Just don't want to chase my tail with tuning issues, or id like to at least make sure they are the same so I can write that off if I have any issues. The stock 2007 WRX CCF map value is 4916 Any help appreciated!
#3 | |
Member#: 276118
SCIC
![]() Quote:
#4 |
Member#: 461898
Vehicle:2004 Forester XT MT 01G |
![]() I just glanced at this and immediate ??? went through my head.
Those sidefeeds should be the same as the STI and FXT 2004-2005. That scaling is actually 520.59 and that does not do you a lot of good without the latencies: 6.00 4.96 9.00 1.78 11.50 1.01 14.00 0.68 16.00 0.54 |
#5 | |
Member#: 276118
SCIC
![]() Quote:
If the car was more normal id just run the MAF to scale the injectors and then switch to speed density. Unfortunately I'm not able to run the factory MAF at this point so I figured I would be able to find someone with an 05 LGT and accesstuner who could give me the scale value |
#6 |
Member#: 461898
![]() ok then, I am still confused (?) RR is in cc/min iirc. And, you stated you needed cc/min (?)
> nvm, I figured out how I misread your statement. Last edited by kharmicresonance; 01-05-2021 at 03:22 PM. Reason: clarification |
#7 | |
Member#: 276118
SCIC
![]() Quote:
Cobb will only grant me access to this map since my ECU is from an 07 WRX. My engine having come out of an 05 LGT came with those yellow sidefeeds. I just need the Cobb Accesstuner value since they seems to use a different system than other tuning software My "Fuel Injector Latency" table comes loaded with the following values: 6.50 - 3.01 9.00 - 1.69 11.50 - 1.10 14.00 - 0.77 16.50 - 0.63 |
#8 |
Member#: 363007
Vehicle:2008 STI Black |
![]() RR has a dropdown on the top menu bar that you can change from "Default" to "Raw Value" after you've opened a table. That will show you the Cobb value, the formula is buried somewhere on RR forums.
#9 |
Member#: 446364
BAIC
Vehicle:'17 STI LMT '08 LGT DGM / QSM |
![]() Might I suggest that you poke around the LegacyGT.com forums. There might be additional resources there.
