Welcome to the North American Subaru Impreza Owners Club Tuesday January 19, 2021
Old 01-02-2021, 01:16 AM   #1
Silverevlis
Member#: 519059
Default Stock EJ257/EJ255 Internal Specs
Has anyone found any Subaru literature that lists the stock specs for:
EJ257 Piston Dish Ccs
EJ255 (Most recent version, not renamed EJ257) Piston Dish Ccs
W Casting Heads Ccs
D Casting Heads Ccs
Oem Head Gasket Bore
Oem Head Gasket Crushed Thickness
Piston to Deck Clearance
Oem Rod Length
Subaru does not list these specs in the FSM, and while countless people (Myself included) have CC'd the heads and pistons, I have never seen a definitive spec sheet from Subaru. If anyone has access to this I would be super appreciative if you could share.
Silverevlis is offline   Reply With Quote
Old 01-02-2021, 01:41 AM   #2
Jp925
Member#: 510046
https://www.flatironstuning.com/blog/what-is-the-difference-between-an-ej255-and-an-ej257
This isn’t everything, but it covers a lot of it.
Jp925 is offline   Reply With Quote
Old 01-02-2021, 02:24 AM   #3
Silverevlis
Member#: 519059
Thanks, Ive read that article and am a huge fan of the Flatirons crew but their measurements are also performed in house and not based on Subaru literature
Old 01-02-2021, 04:09 AM   #4
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I believe all 2.5l gaskets are 100mm
spoolinsti05 is offline   Reply With Quote
Old 01-02-2021, 11:55 AM   #5
Silverevlis
Member#: 519059
Where have you found this information?
