Welcome to the North American Subaru Impreza Owners Club Tuesday January 19, 2021
Old 01-09-2021, 12:42 PM   #1
IDriveFords
Member#: 518804
Default Grimmspeed up pipe extra thick gasket
Does anyone have any experience using the Grimmspeed extra thick up pipe gaskets? I torqued it to the factory spec of 26 ft/lbs but it just looks like it might still have a slight gap; however, that could just be how it crushed in.
Thanks,
-Rob-
IDriveFords is offline   Reply With Quote
Old 01-09-2021, 01:30 PM   #2
kopele
Member#: 363007
2008 STI
In my experience these gaskets don't compress enough to seal gaps due to misaligned or bent flanges. If the gap is small you should be able to seal it with RTV, which is a good idea to use on exhaust connections anyway.
kopele is offline   Reply With Quote
Old 01-09-2021, 05:33 PM   #3
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
I've spent SO LONG trying to get my stock headers to seal with my Cobb up pipe with no luck to the point that I had to replace the headers. How well it mates up can also depend on if your up pipe has a flex section or not. Flex up pipes leak much less often at the manifold because they can move when torquing to completely seal up, unlike solid up pipes.
If you haven't already, try loosening everything and tightening the 2 bolt joints first (up pipe-manifold, and manifold-crosspipe). If you can't get the flanges to perfectly mate when everything is completely loose, that means your flanges aren't true and flat or you have something misaligned.
Grimmspeed 2x thick gaskets CAN fix issues with leaks like this sometimes, but it didn't work for my issue that seems very similar to yours, neither did using copper RTV, nor doubling up on gaskets.
Have the flanges trued if you are still having a gap, but 2x gaskets with RTV may be worth a try.
Copper RTV didn't work for me personally but it may for you.
K3rm1tth3fr0g is online now   Reply With Quote
Old 01-10-2021, 11:11 AM   #4
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
I use red RTV, put bead on both sides of the 2X gasket, let it tack up for 15 minutes then install.
Max Capacity is offline   Reply With Quote
Old 01-10-2021, 11:14 AM   #5
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
+1 always on hand
Bluestreak03 is offline   Reply With Quote
