Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 12-29-2015, 03:21 PM   #1
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Default *** Phatbotti Tuning 2015 WRX Grimmspeed Intake Comparo + New Spark Plug Comparo ***
Event: Dyno Tuning
Ambient Temp: 80
Elevation: 0
Weather: sunny
Car: 2015 WRX
Tuner: Ron aka PhatRon
Tuned With: Cobb APv3
Dyno Info: Mustang-500-SE
Transmission: 6spd
Gear: 3rd
Peak HP at RPM: 336whp @ 5800rpm
Peak Torque at RPM: 370tq @ @ 3600rpm
Baseline hp/tq for a stock on same dyno: 207whp/208 wtq (91octane)
Target Boost: 23 psi tapering to 16psi
Fuel: e63 (from zeitronix gauge)
Modifications: Cobb APv3, IAG TGV Deletes, IAG AOS, IAG EGR Deletes
Mods Added for this testing: New OEM Spark Plugs. Grimmspeed Stealth Intake
First up is the spark plug test. I had 34k on my original plugs and decided to change them out and see if there was any difference. No noticeable difference between the 34k mile plugs and the freshies.
I will say to be careful when getting plugs though. Subaru gave me 3 correct plugs and 1 plug for an NA car. So always be sure to check your part numbers before you leave the dealership. Cost me 2 hrs sitting in traffic to go back and get the correct plug.
Next up is the Grimmspeed Stealthbox intake. The testing was done on the same car, same fuel, same day, same boost, same AFR, and same timing. Peak gains were 10whp and 7 ft*lbs of tq. Now for the question everyone asks
Can I Run This Without a Tune
- Of course, you can run anything without a tune if you're willing to accept the risks. However, I would not recommend it on 91 octane.
- Fueling will change ~10-15% across the entire maf scale. IE, it will lean the car out by a point at wide open throttle.
- Boost will increase 1-3 psi. Being that the stock tune already spikes to 23.5-24psi, this mod would probably cause you to hit overboost fuel cut and be very annoying. Of course the overboosting will vary from car to car and test to test on stock vehicles depending on the ambient temp at the time of the pull due to Subaru aggressively reducing the wgdc when the temps decrease.
All 3 plots together
Boost Plot of the 3 pulls
PhatBotti Tuning TKR is offline   Reply With Quote
Old 12-29-2015, 03:25 PM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Subbing myself
Old 12-29-2015, 04:09 PM   #3
wuuusaa
Member#: 92894
2015 Wrx
Ron since Cobb hasn't come out with the Flex Fuel kit for 2015 + Wrx's. What kit are you using?
Also what exhaust system are you planning on using?
wuuusaa is offline   Reply With Quote
Old 12-29-2015, 04:53 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
Default *** Phatbotti Tuning 2015 WRX Grimmspeed Intake Comparo + New Spark Plug Comp...
I just have maps on the ap for 5,7,9,12 and full e85. Manual flex fuel.
I can run the 5gallon map with 7 or 9 gallons too. Since these cars can stay in closed loop at wot it's not really a huge deal.
I won't be putting an exhaust on. I'm old now and don't really like how they sound on these 15's.
Old 12-30-2015, 08:28 AM   #5
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Very nice!!!
Happy New year to you!
west_minist is offline   Reply With Quote
Old 12-30-2015, 12:07 PM   #6
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
This is awesome!! Thanks for the info.
Lol @ you being 'old', you've said that for years You've just been in the game a while
wgr73 is offline   Reply With Quote
Old 12-30-2015, 05:13 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
I'm way closer to 40 than 30. That's old
Old 12-31-2015, 12:00 PM   #8
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Hahahaha
Old 12-31-2015, 10:55 PM   #9
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
How do you like the intake? I haven't found a video of the sound it makes.
2gnt2wrx is offline   Reply With Quote
Old 01-01-2016, 12:01 PM   #10
XGWAR
Member#: 435171
How did the OEM plugs work out?
XGWAR is offline   Reply With Quote
Old 01-01-2016, 01:01 PM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
In what way? The graph is in the post.
Old 01-01-2016, 01:25 PM   #12
XGWAR
Member#: 435171
I was just doing a compare on my WRX FLEX FUEL , sorry didn't noticed you said the original plugs were good..
Old 01-04-2016, 08:09 PM   #13
MZR2FA20DIT
Member#: 426776
2016 WRX
lapis blue pearl
Wow! 129hp increase from baseline with just a few intake mods and E mix.
I'm impressed.
MZR2FA20DIT is offline   Reply With Quote
Old 01-04-2016, 08:53 PM   #14
stealth06wrx
Member#: 131568
2006 WRX to 2015 WRX
OB Swirl / DGM
I definitely like the idea of just an intake and flexfuel instead of a turbo back...more power and more quiet! also getting old!
stealth06wrx is offline   Reply With Quote
Old 02-05-2016, 11:52 AM   #15
labGTO
Member#: 156528
What fuel pump are you running on your WRX?
labGTO is offline   Reply With Quote
Old 02-05-2016, 12:39 PM   #16
Dobbs
Member#: 28291
2015 WRX
finally an HONEST review of an intake on a '15 with data to back it up. well done sir.
do you have the same test for the TGV deletes?
Dobbs is offline   Reply With Quote
Old 07-05-2016, 12:49 AM   #17
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
Good review of a part made by someone other than the tester!! Please put up more!!
hekler is offline   Reply With Quote
Old 07-10-2016, 06:56 PM   #18
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
stock
not sure where the charts are now as i did it like a year and a half ago...but they picked up a solid 10-15hp across the whole powerband.
Old 08-12-2016, 01:41 PM   #19
hekler
Member#: 388366
CBS w/eyesight
Bump for a great post and a great tuner here!!
Old 01-07-2019, 01:00 PM   #20
thwrightstuff
Member#: 358745
2017 Subaru WRX
World Rally Blue
Originally Posted by PhatBotti Tuning TKR View Post
stock
Sorry to revive this post, but I have a very difficult time believing that only an AOS, TGV/EGR deletes and a GS intake gave you a 129HP increase when pro tuned. All of the other research I've done indicates that intakes give at most 15hp increase and the deletes provide similar figures (+15hp-ish).
Am I misreading your graphs or the information in your post? The typical stock tune at 5800rpms is around 220-240hp. Where is this massive jump coming from?
thwrightstuff is offline   Reply With Quote
Old 01-07-2019, 01:11 PM   #21
anarekist
Member#: 468117
2017 WRX
DMG
its running ethanol
anarekist is offline   Reply With Quote
Old 01-07-2019, 01:13 PM   #22
thwrightstuff
Member#: 358745
2017 Subaru WRX
World Rally Blue
Originally Posted by anarekist View Post
its running ethanol
Hmm, that explains it
