Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 06-24-2013, 01:42 PM   #126
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Originally Posted by jaov2k View Post
So kns for brake stuff?! Got it... Ty guys!
Any recommendations on fluid? I heard motul is good...
I'm also getting ss lines and the xp8's... Stock rotors...
This is for first time autox in the next few weeks...
I've used Motul and ATE SuperBlue. Never noticed a difference between them, but I did mostly autocross and one or two track days. Unless you are doing a lot of hard driving I think you'd be find just using the cheap bottles of high-temp fluid from the autoparts store, and simply flush it more often. The advantage to using the SuperBlue is the color. You know when you've flushed the lines.
If you're just going to autocross then I wouldn't bother with the XP8's you'll never get them hot enough for best performance at an autocross. You'll have to drag the brakes to the starting line to get them warm and it may take 2 or 3 corners before they build any heat. When you're done with your run you'll sit in grid for a few minutes waiting and they'll cool off. Autocross is almost the perfect application for the Stoptech Street Performance pads. Better initial bite and better overall friction than OEM pads while still having a relatively good temperature range so they'll work when cold at an autocross.
For autocross I usually ran Carbotech Bobcats. I think they've renamed them now. I also used the BHP XPS pads, but they were discontinued and I don't know if they were ever available for stock brakes. I was running a Stoptech BBK at the time.
Scooby921 is offline   Reply With Quote
Old 09-10-2013, 03:07 AM   #127
landforscher
Member#: 367934
Cool
I have changed many sets of brake pads, recently I try to by from chain stores founded by. They works well, and I perfer the ceramic brake pads bestly. I run it in the front axle, performacne seems great by now.............om
landforscher is offline   Reply With Quote
Old 10-21-2013, 12:47 PM   #128
bredzy
Member#: 358182
2001 20K Impreza
Greetings all. Just wanted to ask a simple question. I have a 2002 Subaru Impreza IS Wagon from Japan. Will the disc pads from America fit the Japanese Impreza?
bredzy is offline   Reply With Quote
Old 11-22-2013, 01:59 PM   #129
Otaya
Member#: 374312
2003 WRX Wagon
Rally Blue
This is probably a dumb question but was curious if anyone knew if front 4pot and back 2pot Subaru caliper upgrades came with the same basic disc pad? Mine were upgraded but not sure from which year or or even what Subaru model? Its is a 2003 Subaru WRX Impreza Wagon. Not sure if that helps. Need to change the disc pads relatively soon and the local Subaru store wants to charge 200 plus just to diagnose what kinda pads I need. Any help is appreciated! Thanks!
Otaya is offline   Reply With Quote
Old 11-22-2013, 05:17 PM   #130
bredzy
Member#: 358182
2001 20K Impreza
Can't you take them off yourself and compare?
Old 11-23-2013, 08:46 AM   #131
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
I was going to take my car for the 40000 km maintenance and the dealer quoted me $380! This included, engine oil/ filter, cabin and air filter and also brake maintenance. Needless to say i did everything myself for a lot less except for the brakes. What type of maintenance is required? I have never worked on brakes before but for that kind of cash i most certainly will start!
Thank you,
Caocao is offline   Reply With Quote
Old 11-23-2013, 09:24 AM   #132
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
^^Exactly, that's why I learned to do my own brakes a couple of years ago. You can save a lot of money doing your own brake work.
At 40,000 km (25k miles for us in the US), I wouldn't think your pads or rotors are worn out yet unless you're an aggressive driver with lots of city miles. But the only way to know is to do what the dealer probably would have done, which is to remove the wheels, remove and inspect the brake pads, inspect the rotors, grease the slider pins, and reassemble.
I also flush my brake fluid every 2 years regardless of mileage, but I'm guessing that wasn't part of the dealer's $380 service.
Old 11-23-2013, 01:59 PM   #133
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
Yeah, i think that they would just have done an inspection. Thanks for the reply
Old 12-17-2013, 02:19 PM   #134
Jtreemoose
Member#: 376380
07 WRX STi
white
Subaru Stars brake pads
Need to replace my pads on my 07 WRX STi. any suggestions. Want the same performance. Just Stock 07.
Jtreemoose is offline   Reply With Quote
Old 12-17-2013, 02:27 PM   #135
KNS Brakes
Member#: 125739
2007 1500HD
Need Brakes? 919.420.0021
StopTech pads are good, great bite, moderately dusty, and fairly cheap.
-Nick
KNS Brakes is offline   Reply With Quote
Old 12-17-2013, 06:14 PM   #136
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Then get OEM pads?
Old 01-25-2014, 05:29 AM   #137
KidKaBOOM
Member#: 379452
2014 Impreza
Dark Grey Metallic
Default soft brakes
I own a 2005 Impreza 2.5RS with about 110k miles and the brakes are starting to feel a little soft and squishy. The amount of foot pressure required for the car to begin breaking has increased. I need to depress the peddle about 1/3 to 1/2 way down before any active braking occurs. So my question is, how should I fix this?
Will new brake pads and rotors be enough?
I heard about getting stainless steal brake line cables or something like that to increase pressure to the brakes? Does this sound familiar?
My budget for parts is around $800-$1000.
Any help would be greatly appreciated.
KidKaBOOM is offline   Reply With Quote
Old 01-25-2014, 07:20 AM   #138
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I think stainless brake lines would be a waste of money. You might need new rotors and pads, but an inspection would tell you if that's the case. You should also consider flushing your brake fluid, if you haven't done that in the last two years. Brake fluid is probably the most frequently neglected fluid in most people's cars.
If you're doing the job yourself, you can get rotors and pads for all four corners of the car for approximately $300. And brake fluid is cheap.
Old 01-25-2014, 09:47 AM   #139
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Have you inspected your pads, rotors, fluid and lines? As the poster above said you may only need some inexpensive maintenance.
Old 01-27-2014, 01:26 AM   #140
KidKaBOOM
Member#: 379452
2014 Impreza
Dark Grey Metallic
Fluids, check. The rest, not so sure... I had the fluids checked a couple weeks ago. I haven't had a brake inspection for a while actually. Nor have I replaced the rotors since I bought the car in 2010. New rotors and pads are probably in order now that I think about it. I've been wanting to upgrade anyway. I'll do some more research and check back once I decide on parts. Which won't be to far off since I rented a car the last weekend and it made me realize my brakes are far to squishy.
Old 01-27-2014, 08:55 AM   #141
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
When you say you had the fluids checked, did that involve more than checking the fluid level in the reservoir? Brake fluid absorbs water, and should be replaced every 2 to 3 years regardless of mileage.
Old 03-26-2014, 02:50 PM   #142
Udigod
Member#: 384258
05 Impreza WRX
Obsidian Black
My 05 WRX has been sitting in my garage for about 3 weeks without moving it. While it was sitting there i was changing my whole front end body parts to the JDM ones. after i got done, i tried reversing but was stuck. i tried going forward and was stuck too (no. nothing was under my tires) my rear brakes are locked up. does anyone know how to unlock them? SOMEONE PLEASE HELP!
Udigod is offline   Reply With Quote
Old 03-26-2014, 03:13 PM   #143
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
If you had your parking brake engaged the whole time, then your pads might be seized to the rotors. Continue doing what you already tried (engaging forward and then reverse, repeating as required) in an attempt to break the pads free from the rotors.
In the future, if a car will be sitting for a long time, don't use the parking brake to avoid this problem.
Old 03-26-2014, 03:26 PM   #144
Udigod
Member#: 384258
05 Impreza WRX
Obsidian Black
Yes, i did have my parking brake on the whole time. When i put my parking brake down, the brake light does go off. wouldn't that mean it has nothing to do with my parking brake?. i'll try rocking it back and forth again, but if it doesn't work? would i have to remove the rear tires and try doing it manually?
Old 03-26-2014, 03:41 PM   #145
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
No, the light would be meaningless in this case; that just means the switch up near the parking brake's handle is working. It doesn't mean that the parking brake's shoes have actually moved.
This will be a difficult repair for you if rocking the car doesn't work. On Subarus (and many other brands), the parking brake is a drum/shoe configuration, which means that the parts I'm theorizing are seized are not visible even with the wheels removed. If rocking the car as described doesn't release the shoes from the drums, you might literally need to have the car towed (don't forget to request a flatbed!) to a garage for repair.
Good luck!
Old 03-26-2014, 03:47 PM   #146
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
The light on your cluster has zero to do with the position of the e-brake pads that are prolly stuck to your rotors; only with the position of the handle. Keep rocking it.
edit: Jeesh, I gotta type faster...
Could also pull wheels, and back off the e-brake adjuster wheel thru the backing plate, then pull the rotors and clean up/service to remove rust n crap that caused the seize. Check service limits of pads (emerg and regular) and rotor (again both) while at it. GL bro
oaklandish_WRX is offline   Reply With Quote
Old 03-26-2014, 04:14 PM   #147
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
If his e-brake shoes are seized to the inside of the drums, wouldn't you expect that backing off the brake adjuster wheel won't have any affect, since the shoe is stuck to the drum?
Old 03-26-2014, 04:50 PM   #148
LIChuck
Member#: 266122
2007 WRX Limited
UGM
The drums have two (2) threaded holes in them. If you put a bolt in each one and slowly tighten them evenly, the drum will come free.
LIChuck is offline   Reply With Quote
Old 03-26-2014, 04:54 PM   #149
Udigod
Member#: 384258
05 Impreza WRX
Obsidian Black
Thank you all so much! I'm going to try my best to get these brakes unlocked once I get off work and give you guys updates!
Old 03-26-2014, 05:24 PM   #150
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, good to know. Thanks for the info.
But I don't know how comfortable the OP is with doing brake work. Before he could remove the rear rotors to expose the parking brake shoes (using your two-bolt technique), he would also need to remove the main calipers and pads. He will need to decide if he's comfortable with that process.
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS MWSOC Vendor Classifieds 10 09-10-2007 11:43 AM
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS Suspension/Brakes/Handling 10 08-13-2007 02:43 PM
Brakes Brakes Brakes cool13b Legacy Forum 2 03-22-2002 06:08 PM
Brake Lines, Brake Lines, Brake Lines: Rate malaki Brakes, Steering & Suspension 0 05-03-2001 07:55 AM
brakes! brakes! brakes! greg Mid West Subaru Owners Club Forum -- MWSOC 16 12-07-2000 09:36 AM
