05-04-2014, 11:28 PM | #1 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
EFR 7670 MPS LR 2.34L, 556whp 551 ft-lbs on C16
Dyno: AWD Dynojet with load control module Temp: ~low 90's Elevation: ~1150' Tuner: Ian from FSR Motorsports Car: 2007 STi Limited, Full Race 7670 rotated turbo kit Target boost: 36si falling to 23 psi on C16, 23psi on 91+ 50/50 meth, 17 psi on 91 octane Target AFR: 11.8 on C16, 11.1 on pump + meth Hp: 556 whp on C16, 499 whp on pump + meth, 405 whp on pump Tq: 551 ft-lbs on C16, 416 ft-lbs on 91 pump + meth, 340ish ft-lbs on 91 octane Fuel: C16, 91 + meth, 91 octane Vehicle Weight: 3351 Engine: Long block assembled by MPS. 2.34L long rod motor with S20 2.0L heads 9.0:1 CR, fully blueprinted and balanced. Here are a couple pics installed Saenz +4mm custom rods J.E. MPS custom pistons (MPS piston and rod GB) Stock 75mm crank MAP H11 head studs Fluidampr harmonic damper Benson Sleeved block 99.5mm bore Hand ported DPR racing heads S20 heads with modified C.C. Cosworth 272 non-AVCS cams (2.0L spec) Supertech dual valve spring kit Supertech +1mm intake valves Supertech +1mm Inconel Exhaust Valves MPS radius exhaust valve job MPS massaged 10mm oil pump KB oil pick-up Cosworth Oil baffle plate Cosworth timing belt guide Crawford Performance AOS Fuelab FPR Aeromotive fuel rails and custom lines Garrett intercooler core Custom FSR Motorsports FMIC piping, reverse intake mani PnP TGV housings, manifold and TB NGK Iridium 1 Step Colder Spark Plugs FIC 1150 cc injectors Omnipower 4 Bar MAP Sensor Link G4 Xtreme Pro ECU Aquamist HFS-3 meth/water inection running a 1.2 and 0.9 nozzles (50/50 mix) Exhaust: Greddy Evo 2 3" exhaust Full Race twin scroll exhaust, uppipe, and downpipe w. titanium wrap DEI T4 turbo blanket Borg Warner EFR 7670 turbo, .92 IWG exhaust housing Intake: Omnipower 4 Bar MAP Sensor Custom FSR 3" cold air intake Custom reverse IM FMIC kit, 2.5" piping GM IAT sensor for IAT and turbo outlet temp Running gear: Tein Flex coilovers Stock STi rims with a wicked powder coat job Cobb sways, F/R Whiteline adjustable swaybar links Engine Management: Link G4 Xtreme Pro ECU with the following external sensors:
The rpm pickup on the dyno was acting up at high rpm so most of the dyno plots have mph on the x axis instead of rpm but I do have a truncated C16 run plotted agains rpm. This run ran out to 8200 rpm but the rpm signal got funky over 7600 rpm so they truncated the run. I really wish the would have started at the same rpm as the pump tunes Here are all three whp plots on one graph, C16, 91+ meth, and straigh 91 Here are all three TQ plots on the same graph. The rpm pickup gets a little wonky after 7600rpm when the plot goes a little erratic All I can say is C16 is re-goddamdiculous in this motor. The midrange is insane, the top end is insane and you can get the car sideways in a hearbeat with just a jab of the throttle. I do need to secure a few hoses for constant duty @ 36 psi but the engine absolutely love the good stuff. I've changed my mind about E85 and will be building my fuel system for E85 by next year just so I can get a little closer to the C16 feel everyday Took a road trip from LA to San Diego this weekend for about 300 miles of pump and meth flogging and the car is just plain ole awesome in every way. Don't get me wrong about the pump + meth tune. Its no slouch but its absolutely no comparison to driving it for those two days with C16 in the tank. I'm already thinking about either going with the 8374 with EWG housing or just swaping out my current 7670 .92 IWG housing for the 1.05 EWG housing and see what 30 psi is like at redline instead of 23 psi.
05-05-2014, 12:03 AM | #2 |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
The spool and torque you are making with a 75mm crank, no AVCS and legit large cams is awesome! How far does it rev out to?
Could not have happened to a more deserving person; congrats! |
05-05-2014, 12:22 AM | #3 |
Member#: 32669
SCIC
Rev limit is set to 8200 rpm for now and I'm cool with that. When I get a turbo that can hold 30 psi out to redline we will revisit that. I have about 6K miles on the MPS motor so far and the engine is a top that just keeps on spinning.
I only have a tank of pump gas through the car so far since the tune but I will post some boost plots up soon of what it does on the street. I should be hitting 23 psi somewhere around 3700 rpm. |
05-05-2014, 12:33 AM | #4 |
Member#: 255714
Vehicle:2005 STi psm |
Hell yeah good stuff Kelly
Glad to see a fellow group buyer (lol) all set up. Super jealous |
05-05-2014, 01:01 AM | #5 |
Member#: 32669
SCIC
People would ask me why I gave up AVCS and would I miss it... I can't say that I do with these results
05-05-2014, 01:09 AM | #6 |
Member#: 166005
I JUST noticed the IWG spec even though you repeatedly mention more turbo and EWG in the cards for the future.
I'll go ahead and say I am smitten. |
05-05-2014, 08:42 AM | #7 |
Member#: 232458
SWIC
Vehicle:2005 & 2008 STi Cobb 20g & EFR 7670 |
Great results Kelly!
Are you still fighting the boost taper due to the iwg (small housing + 8200rpm doesn't help haha)? I noticed your spool with the .92 housing and wow, pretty big vs the 1.05. With your setup I think you'll like the 1.05 + ewg. You'll hold boost a lot better. |
05-05-2014, 10:19 AM | #8 | |
Member#: 32669
SCIC
More importantly though, I need more fuel pump before I go any farther. |
05-05-2014, 10:50 AM | #9 | |
Member#: 232458
SWIC
You've got to be happy with that, such a sick setup dude!! Last edited by wgr73; 05-05-2014 at 11:48 AM. |
05-05-2014, 12:05 PM | #10 |
Member#: 32669
SCIC
Here is a rough matchbot for my setup @ 25 psi. I need to tweak a couple of things once I get a new sensor for compressor outlet temp. That sensor decided to die on the dyno.
http://www.turbos.bwauto.com//afterm..._wrsin=100522& |
05-05-2014, 06:41 PM | #11 |
Member#: 176128
South East
Vehicle:5862 ...baby boosted |
bravo sir, excellent build
05-05-2014, 06:45 PM | #12 |
Member#: 134211
cant get over that power curve and no avcs to boot?..wow
05-06-2014, 12:05 AM | #13 |
Member#: 32669
SCIC
Thank you kind Sirs. I blame it all on the combo of the 2.34L and a kick ass EFR turbo. Even with the falling boost levels it still kicks a bit of ass. |
05-06-2014, 12:58 AM | #14 |
Member#: 255714
time for some videos!
05-06-2014, 09:34 AM | #15 |
Member#: 176128
South East
didnt see it...what fuel pump?
05-06-2014, 09:49 AM | #16 | |
Member#: 176128
South East
why did you give up avcs? not arguing the results obviously, just want to know the logic. you willingly gave it up, i dont have it in my car and am considering going through the work or money to get it. |
05-06-2014, 10:29 AM | #17 | |
Member#: 32669
SCIC
The only reason I gave up AVCS was because I didn't want to spend the money for another set of PnP heads, valves, springs, and cams when I believe I already have some of the best heads on Earf. I figured with the 7670, any losses down low would be minimal. Good heads and headwork cost a bunch so in the end it was about cost control. |
05-06-2014, 02:23 PM | #18 |
Member#: 162699
Vehicle:02 GDB WRX STI Silver |
Glad to hear your long term project ended (well ended for now that is with great results! Good work Kelly!
-- Have a great day, -- Miles Hechtman Fine Line Imports Inc. www.finelineimports.net www.fliblog.wordpress.com [email protected] 707.525.1536<img> PH 707.575.4134 FAX |
05-06-2014, 09:35 PM | #19 |
Member#: 319017
Vehicle:15 Prius 2JZ miata Death Trap |
2.34Ls gettin it
Crazy spool compared to my setup. |
05-06-2014, 10:09 PM | #20 |
Member#: 32669
SCIC
05-06-2014, 10:13 PM | #21 |
Member#: 32669
SCIC
WGDC need a little tweaking too. It kinda wavy near target
05-07-2014, 12:51 PM | #22 | |
Member#: 32669
SCIC
Thanks Miles, the Link you guys sold me and the support you gave helped get it done. |
05-07-2014, 07:28 PM | #23 | |
Member#: 162699
-- Have a great day, -- Miles Hechtman Fine Line Imports Inc. www.finelineimports.net www.fliblog.wordpress.com [email protected] 707.525.1536 PH 707.575.4134 FAX |
05-08-2014, 11:16 AM | #24 |
Member#: 204421
NWIC
Glad to see some results. Now put a bigger turbo on it!
05-08-2014, 12:09 PM | #25 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
good stuff! very nice build.
any particular reason for the 11.1:1 while squirting meth? i would figure a few more ponies slightly leaner.. |
